Question about Indesit W 123 Front Load Washer
W123 dial continuesto rotate
Continuity to heater new interlock secondhand pcb/timer clear pump/hoses
10 flashes from indicater please help as iknow this machine has lots of symtons kind regards daz
  • dsw1 Feb 11, 2008
    can i get firmware myself .or is this indesit only/ or chip data
    many thanks dsw
  • dsw1 Feb 12, 2008
    thankyou 4 your help it is appreciated.dsw1
No you will need an engineer to program the control board sorry.
Thanks J
Posted on Feb 11, 2008
  • 417 Answers
Hi there I had the same machine and the program board was faulty you will need to replace said board and the firmware needs to be installed to it as well.
Thanks J
Posted on Feb 10, 2008
I have a indesit w123 and when i put it on it starts to fill up and then the dial keeps going round, can you help please...
try and clear prog memory .what to do is set prog knob to an off position where the black spot is then switch on machine the red light will flash quickly then slow down. when it does switch machine off then select program and switch on and it should be ok.if not it could well be a main fault on pcb .indesit boards are not very good .hope this helps.
Jun 07, 2011 | Indesit W 123 Front Load Washer
I want to reset the timer for hours of on-off for out water heater but can't figure out how to push the little white teeth in or out. Model is 265-1.
1) Open following link to read about re-circulation systems:
http://waterheatertimer.org/Water-heater-recirculation-system.html
2) Image below show typical FM1 analog timer dial with pins:
Move pins with fingernail or small tool.
To test if pins need to be moved in or out, set pins each direction and manually rotate dial clockwise and listen when pump turns on-off.
How timer operates: clock motor rotates dial continually, pins on dial move lever that turns circuit on-off.
To set current time, manually rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Some timers have a selector switch: move switch to Auto, or Timer, or Timer ON. Again you can manually rotate dial and check which setting is correct.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 14, 2011 | Taco 265-1 / 563-2 Combination Analog 24...
I turned the timer not meaning to and now i have no water i dont know what to do i think i am making it worse by messing with it
1) The Taco timer should control the recirculation pump only, but the recirculation pump should not interfere with water heater operation.
Open link below to get clearer picture how recirculation system works:
2) It is unclear if you mean that no water is coming out of faucets?
Or if recirculation system is simply not working correctly.
3) To reset recirculation timer, manually rotate timer dial until current time lines up with pointer located on inner dial.
The dial should rotate as time passes, and small pins located on edge of dial push a switch that turns pump on-off.
4) If water heater is not working, then that is a separate problem.
Look at label on side of tank, and repost another question with brand and type of water heater, and we might be able to find a manual and help you solve water heater problem, or you might have to call a plumber if you do not have skills to work on water heater.
5) Please add a comment to this post, and I will answer back.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Feb 14, 2011 | Taco 1/2" 006 BC4-TAC Circulator Pump/...
My water heater needed to be restarted and my comfort recirculation system isn't working now.I"m hoping it is just the timer. I need to reset the timer and I don't know how. I can't find my manual....
Grundfos timer and pump operate by plugging into ordinary 120V outlet.
1) If outlet has power, then dial on timer should rotate.
If dial is not rotating, then check power to outlet.
2) If outlet has power, but timer is not rotating then timer has gone bad > if grundfos pump is working but timer is not working, you can buy cheap plug-in timer and use that as the timer.
3) If outlet has power and pump is not working, then manually rotate timer dial to see if pump will start.
If pump will not start, then you need a new grundfos.
There are no repair parts for these pumps, and nobody at Fixya has reported taking Grundfos apart and repairing it.
My Grundfos pump will not come apart.
4) Following link has links to Grundfos installation manual, website, product manuals, and contact.
http://waterheatertimer.org/Water-heater-recirculation-system.html#Grundfos
5) To set timer: Grundfos timer dial has movable pins that are used to set on-off times.
When pins are pushed out, timer turns pump ON.
6) Rotate timer dial clockwise until current time lines up with arrowhead located on inner dial.
Dial rotates as time passes, and pins move a lever that turns pump on-off.
For a price, expert speaks with you over phone while you work on Grundfos or any do-it-yourself project.
Feb 09, 2011 | Grundfos Comfort System Recirculator ...
We have the intermatic timer Model EJ351 and when I go to set the timer at the beginning it does not flash. It is when I start from off to on. Mary Ann
Mary Ann:
It appears that it will start flashing when you move from off to on. Here are the directions from the web site.
Gary
Move the control lever to the OFF-CLEAR position for about
20 seconds. The red indicator light will go off and any previous
time settings will be cleared from memory.
Move the control lever to the ON position. The Red indicator
light will start flashing.
Rotate the time dial clockwise at least one click, stopping at
the half hour nearest to the present time.
NOTE: During programming, be careful not to press the
dial while turning it. If you press the dial, you will accidentally
set a wrong time.
Press the dial once to set the present time. The Red indicator
light will go off.
Rotate the time dial clockwise to the first desired ON time.
The Red light will pulse momentarily with each click.
Press the dial once to enter the ON time. The light controlled
by the switch timer will turn ON.
Rotate the time dial clockwise to the desired OFF time.
Press the dial once to enter the OFF time. The light controlled
by the switch timer will turn OFF.
Repeat Steps 5-8 for each additional ON/OFF setting.
Continue to rotate the time dial until the Red indicator light
comes ON and stays ON, indicating that the switch timer is in
AUTOMATIC mode.
Dec 02, 2010 | Solar Intermatic Ej351c Indoor Wall Switch...
Hello I lost my instructions for theej351c, can you help?
1. Move control lever to OFF-CLEAR for at least 5 seconds; red indicator light will go
off, and all previous time settings will be cleared from memory. (If timer fails to set, leave in off
position for 15 minutes.)
2. Move lever to ON. RED INDICATOR will start FLASHING.
3. Check a clock; then rotate time dial clockwise at least one click, stopping at the half
hour nearest to present time. NOTE: When rotating time dial, do NOT accidentally PRESS at
the same time. (While rotating dial, keep pressure, pulling out on the dial to avoid accidentally
setting an incorrect time.)
4. Press pushbutton once to enter present time. RED INDICATOR will go OFF, present
time has now been recorded.
5. Rotate time dial clockwise to desired ON time; RED light will PULSE momentarily
with each click.
6. Press pushbutton to enter ON time; controlled light(s) will turn on.
7. Rotate dial to desired OFF time.
8. Press pushbutton to enter OFF time; controlled light(s) will now be off.
9. Repeat Steps 5-8 for each addition ON/OFF period.
10. Continue to rotate time dial for at least 24 hours from the first ON time to complete
this program, at which time the RED INDICATOR light will come ON and stay ON,
indicating timer is in AUTOMATIC mode. NOTE: Dial does not rotate automatically
after setting to indicate time of day.
Oct 26, 2009 | Intermatic Programmable 24 Wall Switch...
W123 holding some water and dial keeps spinning around checked the filter all clear
may be a blockage in the sump hose or pump feed hose or the pump itself may be faulty. the dial will click round to tell you there is a fault. to reset turn the dial onto every DOT and turn on for 10 secs then off and onto the next dot it will flash for a couple of seconds to confirm.
Mar 17, 2009 | Indesit W 123 Front Load Washer
Dial keeps rotating
This a common problem with Indesit washers..
It is not a timer but a programme selector switch.
What you need to do is the following.
Switch the m/c on, let the drain pump empty the water, then switch the m/c off.
set the selector switch to one of the black dots on the dial, which is stop/reset.
Then switch washer back on, if the dial still keeps going round and round, then you are going to have to call an engineer, as you have what is called an Anomaly (fault).
Plz leave feedback for this solution.
Thanks
Dec 09, 2008 | Indesit W 123 Front Load Washer
Hotpoint aquaruis extra WMA A34 WASHING MACHINE
hellooooooo
Well its either the door interlock or the pcb behind the control panel....
What sometimes happens is that the door lock will blow the the pcb obard if there is an electrical short and if so you will need to replace both..
however sometimes its just the door interlock..
if you need advice on how to get to it then let us know cheers
Jan 11, 2008 | Washing Machines
Indesit W123 - 8 Flashes Error Code
thats a problem with your heater, or the heater relay on the main pcb. best off replacing heater first as its the cheapest option.
hope this helps
kj
Oct 26, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
171 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
