Question about Bose & Wave& Music System
Skips mp3"s My Bose wave music system will play commercially recorded and purchased cd's with no problems. CD's or mp3's recorded from i-tunes or other downloads have drop outs of varying lengths.when played, i.e., from a couple of seconds to 5-10 minutes. This has not always happened. The problem started a while ago. Bose could not identify the problem when contacted and indicated I needed to send in the system for them to diagnose for $75 plus shipping and handling. I have the sneaky suspicion they're going to tell me the system needs to be replaced. Any ideas??
  • bosebummer Feb 23, 2008
    That's exactly what I mean. It will play and then just stop. It will start again and then stop, etc.
  • ventcrew Feb 24, 2008
    My bose wave radio/cd plays some cd's but not others. At first I thought it just would not play cd's that were burned from i-tunes etc., but it also does not play some that have been bought brand new. I will take the cd that will not play and put it in another player and it works. Any suggestions?
    Thank You
Three solutions: One, Optical pickup/Eye needs replacing or cleaning (see other Post for more detailed info.). Two, try using Higher Quality Blank CD's note do not use "DATA" storage CD's but "MUSIC" CD's. Third, try using another type of Software Program to burnt your CD's, some formats are not compatible to some opticals.
Posted on Mar 21, 2008
  • 178 Answers
What do you mean drop outs? Like it will play and then stop?
Posted on Feb 13, 2008
CD player skipping and pausing at start up
CD player lens run on a ratchet teeth system that moves up and down. When you hear it clicking, it could be that the mechanism has either fouled, or has teeth missing, or is damaged. It might be possible to correct the problem, sometimes with superglue. But it needs looking at to determine the damage.
Sep 09, 2017 | Bose & Wave& Music System
Not playable cds
If your CD's get scratched by being stacked on a table and shuffled around, you can often get them to play again with something like Skip Dr:
You may also be able to take them into your local video or video game store and have them professionally resurfaced.
If the CD's are not scratched, and are commercially bought (ie. not cd's that you bought blank and burned music onto yourself) I would probably try contacting Bose.
Feb 12, 2013 | Bose Wave music system Multi-CD Changer...
Can't play burned cds through bose
get a 3.5mm male to 3.5mm male cable(one end to the laptop headphone jack and the other end to the AUX jack of the Bose wave music system), you are good to go...
Jan 01, 2010 | Bose Wave Music System CD Shelf System
My front loader reads disc error or unplayable no matter what disc I insert. It worked just fine for about 2 years. It doesn ot get heavy cd use, but everyday radio/alarm use.
To resolve this issue, try one or all of the following:
  • The Wave® music system is designed to play commercial CDs, CD-Rs, MP3-encoded CDS and CD-RWs. If your system has trouble playing MP3 CDs, make sure the discs were recorded with compatible formats. See Cannot play MP3 CDs
  • The system may not be able to play certain CD-RW discs. Playability is dependant on how the disc was recorded, including the format it was recorded in and the actual disc used for recording.
    Note: iTunes defaults to AAC as the encoding format. In order to use iTunes to make CDs that will play on the Wave® music system, you’ll need to change the format to MP3 How to Choose Import Options
  • Different brands of CD-Rs and CD-RWs use different materials which may affect the ability of a player to read them. If you are burning your own CD-Rs or CD-RWs, experiment with different brands of discs
  • If a commercial disc won’t play, check for scratches, fingerprints or other physical damage. Try the CD in another player. If it still won’t play, there may be a problem with the disc
  • Reset the system by disconnecting the power cord from the wall for one minute, then plug the system back in
Dec 05, 2009 | Bose Wave Radio
The cd player is not reading the discs. The read out flashes and blinks but it does not read the music off the disc.
Try removing the cover and clean glass laser eye lens with rubbing alcohol and cotton swab. If cleaning doesn't work, then laser lens circuit will need to be tested and replaced. You can use an ohmmeter to test the capacitors and circuit.
Nov 13, 2009 | Bose Wave Radio
I have a bose acoustic wave,single disc model CD-3000. The CD is not working,the CD spins but won't play. The radio works great.
Had the same problem. Mine the cd drive got out of alignment. Sorry to say the fix is to have it replaced. BOSE will do this for about $150. Typically this includes the one year service agreement, a full system "tune up" and a one year warrenty.
Call BOSE and they will take care of you.
Jul 29, 2009 | Bose Acoustic Wave music system II -...
Recorded audio CD will not play
Most likely the recorded format is wrong and that is the cause.
May 05, 2017 | Bose Wave Radio
Bose Wave Music System - CD Says "Not Playable"
I turned mine upside down pressed play and it started working.
Turned it back over and it's working fine.
Dec 22, 2008 | Bose & Wave& Music System
Bose Wave Radio skips CDs
it seems taht motor that spins the cd is going bad.
Jan 31, 2008 | Bose & Wave& Music System
Cd play problem
Laser is dead. Call bose and they will service it for you for about $75.
Aug 17, 2007 | Bose Wave Music System CD Shelf System
Bose & Wave& Music System Logo
108 people viewed this question
Top Bose Audio Players & Recorders Experts
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
