Question about SanDisk Sansa e250 MP3 Player
No battery icon
How come my battery icon on my mp3 player is no longer there?? so there for it wont charge or connect why?? i have tried everything rebooting the battery formatting the whole nine yards and nothing helps.
  • pammy38 Feb 17, 2008
    huh dont understand none of this, never got a disk with the player only came with one disk and that was to install ur media converter. but thanks for trying
    pam
    no it doesnt connect either, is it the battery itself? that needs replaced?
  • 69 Answers
So... does it connect to the computer?... then wanna have some fun? :p well i think you should use ubuntu you can get it here: http://www.ubuntu.com/getubuntu/download
then you boot with the live cd and a fast guide how to go into diffrent modes here :
manufracting mode hold (on) and push center button while turning your sansa on..
recovery mode hold(on) and push rec buttin while turns player on
in rec mode it should come a 15 or 16 mb partition showing on the computer in there it is some files
when using ubuntu download :
http://chrisjs.com/PP5022.mi4
http://daniel.haxx.se/sansa/e200/BL_SD_boardSupportSD.rom
then replace the original files with those and then emty the trash and unmount the player and unconnect it it should uppgrade system on sansa auto... when finished exit sansa and boot in normal mode hold (off) and don´t push any buttons while start the sansa if it won´t work email me on skrap94@hotmail.com wite sansa problem in beginning of message i will reply as fast as possibel if u having troubel.
Posted on Feb 11, 2008
  • johan jollens
    johan jollens Feb 17, 2008
    well ... if you don´t understand this i guess i can´t explain much better...
My player turns on and displays the pearl icon and no longer moves
Hi
Try removing the device's battery.
Leave the player in the frozen state until the battery dies.
Connect the mp3 to a computer and turn the computer on.
Leave it charging for 15minutes an then try playing music while its still charging.
Feb 28, 2012 | Audio Players & Recorders
My sansa when its connected to my computer comes on works syncs and everything so as i disconnect it from my computer it' s dead and wont turn on
Three possibilities;
1) You have a dead battery because the battery is no good.
2) You have a dead battery because your Sansa is no longer charging the battery.
3) You have a dead battery because you didn't leave your Sansa tethered long enough to charge it up.
When you have the Sansa c250 tethered to the computer, you should see a tiny yellow lightning bolt flashing, and a battery icon that shows the amount of charge on the battery.
If you see the lightning bolt, but the battery does not charge after being tethered to a working computer or charger for 24 hours, you may need a new battery. You can get one on Amazon.com. Here's a link:
http://www.amazon.com/HQRP-Replacement-Battery-Universal-Protector/dp/B001NZ981S
If you see the lightning bolt, and the battery charges after 24 hours, AND your player works when unplugged--Problem solved! You just need to let it charge for a longer time.
If you do not see the lightning bolt when the player is tethered, and the battery indicator shows "empty," It's likely that the internal plug to your Sansa c250 has broken. Your Sansa is no longer able to charge the battery.
If you happen to be an electrical engineer, or otherwise have a shop full of electronics equipment (including signal injector, volt-ohm meter, needle-tip soldering iron, and stereo magnifying goggles with work lamps) you may be able to fix it yourself. Otherwise, forget it-- your Sansa is dead.
If it's still under warranty, try to get it replaced. Failing that, it's time to get a new MP3 player.
Hope that helps! Please post a message to let others know what happened to your Sansa player.
Nov 22, 2011 | SanDisk Sansa c250 (2 GB) MP3 Player...
MY Zen WONT TURN ON. It also wont charge.
Connect the player to a USB port on the back of a desktop PC.. Check the display for the charging icon . As the display times out after a few seconds, press any button on the player to reactivate the display. If the battery is fully depleted, the charging icon may not be displayed. Cup the player in your hands to check that the blue power LED behind the Play/Pause and Options buttons is blinking on and off repeatedly. This indicates that the player is successfully charging. After 1 hour of charging, power on the unit to activate the display. The charging icon should be displayed. Allow the player to charge for at least 6 hours. During this time, if charging from a USB port, please ensure your PC does not enter a power conservation mode (Standby, Sleep, or Hibernate) as this will interrupt charging. If the player does not indicate a charge, or will not power on after at least 6 hours of charging, please contact Customer Support.
You might try updating your ZEN V or ZEN V Plus firmware to take advantage of new features and functionality.
http://support.creative.com
Jan 16, 2010 | Creative Labs Zen Micro MP3 Player
My fully charged MP3 player wont stay on. It
Yeap , time to replace the battery. after a certain amount of used hours all MP3 players will start to do this until it no longer has power.
Jun 03, 2009 | Audio Players & Recorders
Is there any such thing as charging my mps nextar MA933a via the USB port? I just get sleepy z's on the display when I connect it to my computer.
Here is what I found:
Connected the player to the PC with and without prior power on successfully
OSD first displays message “Starting…” then:
Icon appears on screen with a picture of a computer monitor to right and mp3 player icon to left
When mp3 player is communicating with computer or sending information, an appropriate directional arrow appears between the two icons; when transferring files using Windows Explorer, the arrow reverses direction appropriately; when there is no activity either way, a series of “Z z z” ‘s appear on screen
Battery indicator icon also appears to right – new AAA battery resulted in a fully charged icon upon startup; no battery whatsoever resulted also in a fully charged battery icon appearing
-Tha Mp3 Doctor
Feb 02, 2009 | Nextar MA933A MP3 Player
My Sansa Sandisk express flash drive mp3 player wont come on
firstly you should only remove a usb device "correctly" otherwise problems can occur with device ,pc or both.....when usb device connected there is a small icon on taskbar with a green arrow on it....to renove device right click this icon and choose apprpriate device to STOP....there is a reset button that you can press to reset settings...look for a 1mm hole and put a pin into it and push...goos luck
Nov 16, 2008 | SanDisk Sansa m240 MP3 Player
Opal MP3 playe
yea i try everything and nothing have happen
Aug 03, 2008 | RCA OPAL M4001 MP3 Player
My mp3 player
The user guide (p 7) mentions pressing the Power On/Off/Stop button (presumably only once, but see below) to charge the battery if the charging does not start automatically when the uncharged player is connected via USB.
The following is from Memorex online FAQs. Hope it might be helpful:
Connect the player with the supplied USB cable. After the cable is connected, press the power button twice. The battery icon in the upper right corner will start filling with bars as it charges.
Jul 29, 2008 | Memorex MMP8565 MP3 Player
Ipod stuck, reset wont work, disk mode wont work
the sad face tells about a hardware problem and needs service
then here is the online service assistant
https://selfsolve.apple.com/GetWarranty.do
You can check your warranty there and if you still got warranty it should be free for you.
Let me know if you need anything else
Thanks,
Ekse
Jul 05, 2008 | Apple iPod MA446LL/A MP3 Player
SanDisk Sansa e250 MP3 Player Logo
54 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
