Question about GE Dryers
Ge electric dryer quit running, it threw a breaker , will not turn back on when breaker is thrown back on
Does this mean it's the dryer switch or does the dryer have it's own fuse
  • fixmeow Feb 12, 2008
    the breaker didn't shut all the way off had to throw it all the way off then back on taduh
HAVEN'T GIVEN UP GOING TO GET TWO FUSES TRY THE FIRST ONE THEN IS IT BLOWS THEN I'LL KNOW IT'S THE DRYER ALSO GOING AFTER LAMP GUTS HAVE TWO LAMPS FROM THE FIFTIES I'M RESTORING
Posted on Feb 10, 2008
Our Hotpoint RB525D all of the sudden wont turn on. It seems like it might be a power issue. Is there a fuse that might be blown?
First thing to do is to find your electrical panel box. You will have fuses or breakers. Locate the one that is associated with your range. If you have fuses it will be at least a 30 amp. If it is dark in the glass viewer, change it out with a new one. If you have breakers, find the correct one by the list that the installing electrician wrote on the inside of the panel box cover lid. Once located move the breaker switch to the right very firmly. Then flip the switch back to the left, you will hear a definate sound to indicate that you have switched the breaker on. If the switch stays in place and is not thrown back to the middle or right, go turn your oven on. If it threw the switch you have a short of some kind, I recommend calling an electrician or an appliance repairman at that point.
Sep 14, 2010 | Hotpoint RB525BC Electric Kitchen Range
I have a Kenmore (Whirlpool) Elite HE5 Steam front load dryer. Everything seems to work fine except there is absolutely no heat. I checked the breaker, and it wasn't tripped. I checked the lint filter and...
I think I know what the problem is, this actually happened on a dryer I repaired at one point. Low line voltage to me means that one or more hot leads is not feeding enough voltage to the heating elements (and the heating elements need both hot leads to run) which means the circuit breaker, although on, may be malfunctioning or weakening. You can check this by running your dryer and taking the cover off your circuit panel and checking voltage on the breaker. You should see 110V on each terminal to ground (put leads from one terminal to the grounding bar in the panel). If you see less than 110V on each lead to ground and less that 240V across the terminals it needs to be replaced. (You can get one for under $25.00 depending on brand). NOTE: THE BREAKER USUALLY POPS RIGHT OUT OF THE PANEL, BUT WHEN WORKING IN PANEL TURN MAIN BREAKER OFF TO THE HOUSE AND HAVE SOMEONE HOLD A FLASHLIGHT FOR YOU. IF YOU TOUCH THE LIVE BUSS BAR THAT BREAKER GOES INTO YOU WILL GET SEVERELY HURT. TURNING OFF MAIN BREAKER WILL DISENGAGE THE POWER FROM THE BUSS BARS; NOTE THAT MAIN WIRES ARE STILL POWERED SO BE CAREFUL.
Mar 22, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Won't start all of a sudden. Power is getting to the unit, no breakers thrown. Interior light works... just won't run. What do I check first? GE model DPSR475EWOWW
First, find your breaker box and locate the breaker that runs the dryer. Now flip the breaker off and then back on. Now try the dryer. If it made not change. Gain access to the back of dryer. There is a small panel toward the bottom that you can take off. After unplugging the dryer, take the little panel off. Look inside and check the belt. Make sure it is tight and still going around the motor shaft and pulley. With this model, there is a switch that turns the dryer off so that it will not run when the belt comes off. If the belt is on, you will have a bad thermal fuse and bad cycling thermostat. The thermal fuse is located on the top of the element housing and the cycling thermostat is located on the blower housing. When the cycling thermostat goes out the dryer then cycles on the thermal fuse until it goes bad. This then cuts the power on one leg of the 220V coming to the dryer. Remember, a dryer runs off of 220vs. This consist of two 110v legs. The element is the only component inside the dryer that works off of both 110v legs. Some component work off of one leg and the other component work off the other. When you loose one leg, some things will work and others will not. I hope this makes since. It's the best way I can explain it. If I can explain any of this or help anymore, please send a comment back to me.
Please rate solution and good luck.
Sep 07, 2009 | GE Profile DPSR475EW Dryer
My electricity went out during a storm. Now my
Yes its in the rear under the panel, I would look at the breakers in the electrical box first the dryer is on a circuit alone. The breaker could be thrown, it mite not look as it is just turn it off and then back to on.
Aug 09, 2009 | Dryers
Dryer was working, quit in middle of cycle. Will
It's rather unusual for any internal failure to cause the dryer to just stop in cycle. Check the circuit breaker that supplies the dryer. It should be a double-pole breaker of at least 30 amps. Turn the breaker off and back on to ensure it is reset. Internal causes could be the motor, door switch, thermal safety switch, timer, or a broken wire.
Apr 30, 2009 | Maytag PYE2300AY Electric Dryer
Breaker tripping
The problem may not be with your dryer but with the circuit breaker...
Locate the circuit breaker for the dryer. Run the dryer for awhile and with the back of your finger pressed against each of the two switches (it will be a double breaker), see if the breaker is getting warm or wait until the dryer quits then check the breaker for any noticeable increase in temperature. With properly rated breakers, they should not get warm. If getting warm, it is a sign the breaker is bad and should be replaced.
Jun 14, 2008 | Roper REX4634KQ Electric Dryer
Dryer want turn on
Hi Airis0299,
Check the following:
  1. The door switch needs to be checked. Is the tab on the door inserting into the hole where the door switch is and making the switch activate?
  2. Is the Dryer plugged in good?
  3. Is the Circuit Breaker feeding the dryer tripped? This is on the electrical supply cabinet for your home. You will see a ganged(meaning two switches paired together) Circuit breaker. Turn the switch off all the way and back on to reset.
I hope this helps you get your dryer back running.
Oct 30, 2007 | Dryers
Dryers Logo
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
