Can move the pointer, but when ''double-clicking'' the pad, nothing happens.
Also, mouse won't work either.
(Netbook is Asus. Can't remember the mouse.)
My stupidest problem: I can't get the external optical drive open (Asus).
Know the answers are probably really simple, but so am I.
Thanks.
Apenas solucione este problema hace unos minutos,localiza en la esquina inferior derecha el icono que dice Dispositivo Señalador de Synaptics, clic derecho y seleccionas "Toque Rapido para Hacer Clic" y listo!!! si no te aparece el icono tienes que ir a Panel de Control, vas a Mouse, en la pestaña Configuracion de Dispositivo, seleccionas Icono de Bandeja Animado en la Barra de Tareas, ya con el icono en la barra de tareas haces clic derecho sobre este y seleccionas "Toque Rapido para Hacer Clic"
Espero haberte ayudado, bye
Just fix this problem few minutes ago, located in the lower right corner icon that says Synaptics Pointing Device, right-click and select "Quick Touch to click, 'and ready! if you do not see the icon you have to go to Control Panel, go to Mouse in the Device Settings tab, select Animated Tray Icon in the taskbar and the icon in the taskbar, right clicking on this and select "Quick Tap to click"
Hope that helps, bye
Step 1
1. Open Mouse by clicking the Start button, clicking Control Panel, clicking Hardware, and then clicking Mouse.
2. Click the Pointer Options tab, and then do any of the following:
• To change the speed at which the mouse pointer moves, move the Select a pointer speed slider towards Slow or Fast.
• To make the pointer work more accurately when you're moving the mouse slowly, select the Enhance pointer precision check box.
• To speed the process of selecting a choice when a dialog box appears, select the automatically move pointer to the default button in a dialog box check box.
• To make the pointer easier to find when you move it, select the Display pointer trails check box, and then move the slider towards Short or Long to decrease or increase the length of the pointer trail.
• To ensure that the pointer doesn't block your view of the text you're typing, select the Hide pointer while typing check box.
• To find a misplaced pointer by pressing the CTRL key, select the Show location of pointer when I press the CTRL key check box.
Change mouse settings
http://windows.microsoft.com/en-US/windows7/Change-mouse-settings
Step 2
If you are using touchpad, try reducing the Touchpad sensitivity and check
1. Click on the "Start" icon in the lower left corner of the screen. Select "Control Panel." Next select "Mouse" under "Hardware and Sound." You can also left-click the touchpad while the cursor is anywhere on the desktop. From that screen, choose "Mouse Pointers."
2. Select the "Buttons" tab at the top of the dialog box that opens. This shows the type of touchpad device installed on your laptop.
3. Set the touchpad for right or left-handed use from this dialog box. You can adjust the double click speed of your computer as well. When you finish making any changes, click "Apply."
4. Pick the "Device Settings" tab from the dialog box now. You can see the touchpad for your Vista machine highlighted on this screen. Select "Settings."
5. Read the information provided in the next dialog box. It gives you options for tapping your touchpad, using the buttons, scrolling, pointer motion and sensitivity.
6. Make any changes you want from the various topics. When you make a change, click "Apply." Click "OK" when you finish making all your changes.
7. Do some work on your computer for a while, If the touchpad is still too sensitive, return to the "Mouse" menu and continue to adjust the settings until you get them just the way you want them.
Step 3
If the issue persists try to perform a clean boot and check whether the issue is still persists.
Follow the steps mentioned in the article given below.
How to configure Windows Vista to start in a "clean boot":
http://support.microsoft.com/kb/929135
Note:Once the troubleshooting is over, reset the computer to start as usual.
Also I would suggest you to keep in touch with mouse manufacturer
Step 1
Step 2
Step 3
