Question about Dell UltraSharp 1800FP 18.1" LCD Flat Panel Monitor
Dell 1800FP I need to know how to test for 5v and 12v of Power Supply for Dell 1800FP Do I touch ground w/ muti meter lead and then touch each output pin that goes to ribon cable? I am getting zero voltage. Even going across two pins at the same time, I am getting zero. I think the supply is bad but I am not sure I am testing it correctly. Any advice would be appreciated. Tripp English
    Novelist:
  • 138 Answers
What's wrong with your monitor?
Posted on Feb 10, 2008
Can I tap a -5v into a BESTEC atx-250-12z-rev d2 power supply ?
The output from the power supply is
Output Max. Load +5Vsb 2A -12V 0.3A +12V 13A +5V 30A -5V 0.3A +3.3V 20A Pin 18 out of 20 white -5 volts (optional)
20 out of 24 white -5 volts (optional) See the definitive connector definition.
All about the various PC power supply cables and connectors
Mar 05, 2015 | Computers & Internet
Checking a power supply with a multileter
Checking power with a multimeter is easy but requires the power supply to be loaded. Yellow is 12V and red is 5V. the black lead for the multimeter is plugged into the black wires, and the red lead is used to check the power supply wires. make sure you DO NOT wear any metal jewlery, no grounding straps, don't touch metal.
Mar 16, 2014 | Dell Dimension 4500 PC Desktop
Start up light flashes once and it won't power on
Most probable cause is the power supply. Look at the back of the computer, check the voltage settings located near the power cord. This will be the small red tab indicating two different settings, If your in the US it should be set to 115. Also, the power supply should run the internal fan when it is turned on.
To test the power supply try this:
Open your computer case and locate the gray box that is the power supply unit. Trace the wires from the power supply to the boards and devices and disconnect all the cables by unplugging them.
Find the big connector plugged on the the motherboard, make sure it is disconnected and short the two pins: (GREEN & BLACK) Short green pin (14) to GND (any black) to switch power supply ON, disconnect green from GND to switch OFF.
This will switch the power supply, you should hear or see the fan in the power supply spin. If you do not see the fan spinning, and your sure you have shorted the correct wires, you have a faulty power supply. If you see the fan spinning, you can now test the voltage coming out of the power supply.
Place a volt meter on the following colors to test voltage:
The color code for the wires is: Red = +5V, Black = Ground (0V), White = -5V, Yellow = +12V, Blue = -12V, Orange = +3.3V, Purple = +5V Standby (not used), Gray = power is on (output), and Green = Turn DC on (input).
Feb 12, 2011 | HP Pavilion a6110n PC Desktop
I need the pinout diagram for a AC power adapter model # DPSN-186EBA from a XBox unit to verify voltage outputs .
I found the answer at http://azsurplus.com/index.php?main_page=product_info&cPath=1_38&products_id=2981
However you cannot just hook your meter to +12V and ground as the power supply remains in standby. You have to draw from the 5V pins at the top labeled 5Vsb. I did this by shorting the 2 pins with a resistor between 39 and 1220 ohms. I did not try any other values as these were the first 2 I found in my junk pile. Once current is being drawn on the 5V connection the 12V is then turned on. I measured 12.3V with less than 1 mV AC ripple.
need-pinout-diagram-ac-power-adapter-vznl3exjh3gd11c5sznjfexu-2-1.jpg I purchased my power supply for $1. I needed something to power my mini cooler when not plugged into my van. I cut the multi pin plug off, soldered an 82 ohm resistor across the red and blue, a cigarette lighter socket onto the yellow (+12V) and black (ground), taped it up and now I have a very regulated power source for my fridge.
Oct 17, 2009 | Microsoft Xbox 360 Controller
Dell 1800fp
Find and replace the ICE2AS01 on your power supply
Apr 28, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
1800FP green LED is on, screen is black
power pack has issues could be a chip on the power pack or some capacitors on the power pack. the power pack supplies power to the inverter.
Feb 20, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell 1800FP, no signal found (analog). Green LED on, get message
check if your signal cable is properly connected to your system unit and make sure that non of the pins of your signal cable is broken.if any of the pins are broken,try and change the whole signal cable and re-connect it again
after following the above instruction,reboot your computer
thank you for contacting as with your problems,you are always welcomed
Jan 26, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell moniter
The power supply has most likely gone out. Check for 12v and 5v output and also the solder arround d903 and d907. The site www.lcdrepair.us sells the part as well as a repair kit and has instructions.
May 24, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell UltraSharp 1800FP 18.1" LCD Flat Panel Monitor Logo
196 people viewed this question
Alun Cox
