Question about Garmin StreetPilot C330 GPS Receiver
POIs for Street Pilot 2610
I requested help with this on 02/02 2008.
No solutions have been forthcoming and I have discovered the Unit is not designed rto accept POIs.
I am now seeking a refund of my $US10..00 in terms of your MONEY BACK GUARANTEE.
Thanks
Tedslaven
  • 504 Answers
Sometimes going to Garmin's web site can help answer questions like this. Garmin has discontinued the StreetPilot 2610, which means it has not been produced for some time. This is from the manual of the 2610/2650:
CD-ROM:
Accepts downloadable map detail from
Garmin PC-based MapSource® City
Navigator™ DVD (included), which
provides street-level detail, addresses,
listings of nearest restaurants, hotels,
ATMs and more. Note: Requires
CompactFlash® card (128 MB CF card included)2
Posted on Feb 10, 2008
Garmin street pilot 2610 not picking up satellite during heavy cloud coverage??please advise. Thank you jimd
The GPS signals will not be affected by clouds, rain, fog,
snow, etc. You probably need to relocate the position of the gps in your vehicle due to weak signal where it is now located.
Dec 28, 2016 | Garmin StreetPilot 2610 GPS Receiver
I have a Street pilot 2610 I have downloaded V8 to my unit but while it was transfering the unit showed no change that it had accepted it how do I find out on the unit if has been...
Please check the version of the download software and check the version in the street pilot if both are same then the transfer is done.......
Good luck.....
Jul 04, 2008 | Garmin GPS
Model# BWH30NLTB
Unit goes under sure heat name also.
My unit emitted unburnt gas smell the minute pilot started,
and was annoying during burner operation.
I discovered they built unit with primary pilot that had 2 ports.
They used LP and sealed off natural gas,instead turning lp/nat
knob on back activates second pilot for natural gas use.
This means natural gas goes thru LP pilot orifice and burns
slightly off during normal natural gas use(by design).
The unused natural gas orifice has 1 air mix hole and the LP orifice
has 2 air mix holes.
I carefully plugged 1 of the holes in the LP orifice and suddenly
pilot gas flame seated correctly on orifice port.Gone was the
unburnt odor of natural gas.
The typical flame in a flame appearance now was exhibited by
the small pilot,secondary pilot remained consistent with manual
picture.
Of course, to use with LP I would have to open blocked air mix
hole in addition to the other changes per manual.
Hope this helps someone with similar condition.
Dec 31, 2012 | Reddy Heating & Cooling
Garmin street pilot c330 goes on and then goes off
Try to charge the unit for 4 hrs by using a wall adapter and then try power on it again and if still the same after you full charge the unit try to contact the manufacturer check if there is a latest firmware update for the unit.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
Jun 09, 2009 | Garmin StreetPilot C330 GPS Receiver
Touch screen dos not work on garmin GPS street pilot 7200
Try resetting the unit by using a ball point pen or other sharp thing and press it for more than 10 seconds. It would be on the left/right/back side of your unit.
Also, try to hold your finger on the power key for approximately 15 seconds until you see a message "This operation will erase all waypoints, do you want to continue?"
Tap yes and the unit should reboot then attempt to acquire satellites. You will lose any favorites you have saved but it may save you a trip to the factory.
Please ask for further clarifications.
Please rate this solution as FixYa if found useful.
Thanks
Rylee
Mar 08, 2009 | GPS
2610 trouble
when i hook it up to the computer it want work
Apr 11, 2008 | Garmin StreetPilot 2610 GPS Receiver
2720 street pilot replacement
The screens are not interchangeable. The 2610 screen is 3.3x1.7" and is 305x160 resolution. The 2720 is the exact same size but 454x240 resolution.
Jan 13, 2008 | Garmin 010-00358-00 GPS Receiver
Cracked screen on Garmin street pilot 330
Given the cost of buying a new LCD with touchscreen is about $130 USD + shipping. Your best solution is to sell the existing unit and buy a new Nuvi or recondition C330.
Garmin will repair the unit for $150 and provide the lastest update and map.
Jan 01, 2008 | Garmin StreetPilot C330 GPS Receiver
Map problem
There are two type of maps in the unit. There is the basemap which shows the states and major highway and roads and then there is the actual Mapsource maps which shows the streets. If you go to Mapinfo and it doesn't show anything, then Mapsource maps are missing.
With the 2610 you can use a card reader for the Compact Flash Memory card to load the maps. This is much faster since the card reader is USB 2.0 while the Garmin USB is 1.1 Under device look for the drive letter which correspond to the Campact Flash card.
Oct 15, 2007 | Garmin StreetPilot 2610 GPS Receiver
Garmin street pilot III
Push the power button to turn it on then count to 5 then hit enter. Then count to 5 again then hit enter. Once there hit the power button with a real quick press. The power button is also the screen brightness button. Someone may have turned it all the way down. OR the back light could have gone out.
Aug 16, 2007 | Garmin StreetPilot 2610 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
81 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
