Question about Mitsubishi WD62627 62" HDTV
No luminance We have a very poor dark predominantly red picture through the HDMI port. No video can be seen when trying to view input from any RC jack inputs. There is no change in video when contrast or brightness adjusted up or down with input from both HDMI port or any RC jack input. What video can be seen from the HDMI port can be adjusted from nothing to poor when adjusting the color adjustment. The menu can be seen perfectly. There is the same problem as the RC jacks when attempting the tuner input. Audio works fine. The TV boots properly with no flashing lights. The TV is two years old and has been trouble free. It is used on the high end of normal. It is getting close to lamp replacement but there has been no degredation of image, this was working one day the next morning, no video or very poor video.
  • 2 more comments
  • BRJohnson Feb 10, 2008
    The Televisions Make and Model is a Mitsubishi WD-62627 62" DLP
    Are there CRTs in a DLP television?
    Yea it looks all red and nasty but that is on the HDMI port only and it wasn't a slow process, it happened overnight.
  • BRJohnson Feb 16, 2008
    Hey Nick, I replaced the bulb and no go. It may be a bit more of a crisper bad video but predominately red and still no luminance. The only video that can be seen is through the HDMI input still. No big on the bulb replacement we were getting close anyway. Anymore ideas?
    Genius:
  • 3,422 Answers
if everything else works - there is sound and high voltage (static on the screen) - but there is no picture (including no on-screen menus), this limits the likely area of problems is the video output circuitry or CRT filament connections. Check to see if the CRT filaments are glowing. If they are not glowing, check for bad soldering on the CRT neck board and around the flyback transformer. Where the picture is erratic - coming and going entirely or changing brightness suddenly, with power off, remove the picture tube socket (carefully!) and clean the pins with fine sandpaper and use contact cleaner on the socket. This source of bad connections can result in a variety of erratic symptoms. Check for bad solder connections on the CRT neck board.
Is there anything else i can help you with??
If you are satisfied with my solution then please don't forget to rate me as fixya..
Posted on Feb 10, 2008
  • Priya darshan Feb 10, 2008
    sorry for that..
    The problem can be with the bulb as nick said but if you have nothing on the screen at all?? not even menus. then you need
    a repair. there are several parts that could cause this. the most
    common is the ballast that fires the lamp. a repair cost for this is
    around $400-$500.
    Master:
    Sergeant:
  • 440 Answers
Poor very dark is sighn of bad bulb ok after 3000 hours they get dark they wont die just get darker in darker like what going on now and have stuff looks like red nasty get new bulb ok
  • 2 more comments
  • nick helpap
    nick helpap Feb 10, 2008
    cool guy dude this isnat crt dont asnser stuff u dont know cool guy
  • nick helpap
    no ther isnt do what i said sir dlp is dlp bulbs digital proccsion crt okld style monitors coolguy dont know what hes talking about half time just tryes to anse rto get cash fast with wrong anser all day long why his feedback so poor sir change bulb ok
  • nick helpap
    ya and u tryed new hdmi cable ? still dark super low picture is bad bulb
  • nick helpap
    and u tryed differt port ecxt in menu u do have black level exstender in options u can play with but dought will help thx nick
I can't get the picture clear on my sharp aquos tv
Try using different input ports on the TV. Experiment with HDMI and component cable inputs if yu have a DVD player or cable box with those type of outputs
May 02, 2017 | Sharp Televison & Video
How to plug a wii to a proscan "32" tv
If the TV has an unused HDMI port, use the HDMI cable that comes with the WII . If not , then use the 5 cable Hi def cable . Match the colors RGB on the cables to the same color input jacks on the TV The red and white cables are the audio. Make sure you don't get the wrong red cable mixed up. Note the input number near the jacks you use on the back of the TV. Select that number with the input button on the remote to see the picture.
Jun 17, 2015 | Video Game Consoles & Games
How do I connect the wireing
The VCR portion is connected to yhe TV via yellow-end cable(video) from "video out" to TVs "video in" and red and white-end cables(audio) from "audio out" to TVs "audio in". The DVD plays via HDMI cable from "HDMI out" to TVs HDMI in. S-video cable can be used if no HDMI terminal is available on TV. External tuner in (cable TV, Satellite) is connected to the video and audio in terminals or better yet if S-video out is available on the tuner box.
Aug 24, 2014 | Magnavox ZV427MG9 DVD Recorder/ VCR
Vizio xvt3d580cm has red contour lines in dark regions of picture. What causes this?
Does it do this using more than one input? Have you tried using a different source such as DVD? IF using HDMI inputs does it do it on all of them? I have seen this trouble because of configuration issues with some satellite boxes also have seen similar issues because of a bad HDMI input.
Oct 13, 2013 | Vizio VO37LHDTV10A 37 in. LCD TV
Digital Lifestyle LT32323 screen color keeps going red
Try changing the input device to something you are sure, works such as a DVD player. Look for any loose contacts in RC jacks/sockets/Cable.
Aug 05, 2012 | Digital Lifestyle s LT32323 LCD TV
We need to connect a wii and a dvd player up to our 32 in Emerson? Unsure of which jacks to use?
First, you must figure out If your TV has component video inputs. This is a set of five cables (red, blue and green for video and red and white for audio) and will give you the best picture on an hdtv
Then, If your TV does not have the component video cables, you will be using the red white and yellow composite yellows the system came with. A very simple connection.
Last, If your TV does have the component video inputs, you will need to buy a set of the Nintendo Wii Component Video cables from Walmart, Target or any other gaming store. These will enable widescreen view and the best picture quality.
To connect your DVD player, you need to located the composite video inputs and s-video. Composite video is a yellow, female RCA jack, normally found next to two audio jacks, one red, the other white. The three jacks together provide an interface for audiovisual connections. The red RCA jack connects the right channel of a stereo system, while the white RCA jack connects the left. The yellow composite video jack rounds out the set.
When playing the Wii, you will need to be on the correct video input "Component"
When playing the DVD, you will be on "Composite/Svideo."
Dec 29, 2010 | Emerson LC320EM9 32 in. LCD HDTV
I no longer have the manual for the product and I want to hook it up to my TV via a cable box; we have Charter cable. The cable box is a Motorola and it says Dolby digital on the front of the cable box. ...
The white, yellow, and red RCA phono jacks on the back are called VGA inputs and outputs. The Red is
right channel audio, The white is for left channel audio. The yellow is the video. Look carefully on the back of the unit and the input jacks and output jacks should be clearly marked.
There are several other input/output ports. One is HDMI which is flat and wide. Another, not common, is composite video which uses the three above mentioned RCA jacks as indicated plus two more colored jacks. This combination gives a better picture.
A third option is a screwed on cable for input and output. This is called a "F" connector and is only used if the receiver equipment has a built in tuner. The output of a cable box is usually an "F" connector and the above described outputs
If you connect the cable box to the DVD player input and the DVD player output to the TV input, you often must have the DVD player turned on so the signal will feed to the TV.
If the TV has multiple inputs, it is best to connect the cable box to one of the TV inputs and the DVD player to another TV input. Using the TV remote you can chose which input you want to watch. The remote should have a button labeled "input"
Apr 29, 2017 | Cyberhome CH-DVD 402 DVD Player
Motorola DSR505 HDMI problem
Check to see if input 5 has a audio in source via RCA jacks. Many times manufactures will give you multi HDMI inputs but only one that has RCA jacks in case you are running a DVI/HDMI cable. If input 5 does not have those RCA jacks you will not have sound. I know this unit has multiple HDMI inputs. Look to see if any of the other HDMI inputs also have RCA jacks.
I hope this helps,
Skyassoc
Jun 22, 2009 | Televison & Video
Broken HDMI Port for HP-R5072
The HDMI input along with others is located on the a/v control panel of which would have to be replaced. I haven't seen an input jack yet with a part number attached for any model. I would suggest call a service center for a diagnosis.
Jan 24, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
PANASONIC HOMETHEATER SYSTEM TO PLASMA TV
Some where on the back, bottom or sides of your plasma tv you will find input jacks for the audio and video. You must know what type of inputs you want to use.
Most have have 4 types
HDMI (audio and video signal combined)
Component (red, blue, green RCA jacks for video only)
Composite (yellow RCA jack for video only)
S-video ( larger round black jack with video only)
The Panasonic should have all of those also. I am certain it has HDMI and Component.
Connect the HDMI cable into the output HDMI jack from the Panasonic into the HDMI input jack on the TV.
Then using your remote for the TV make sure you select the HDMI input for viewing.
If you use any of the other video outputs on the Panasonic just connect it to the same type of input jack on the TV. Once again check the owners manual for more detailed instruction if you need them.
You must always be sure to have the proper input selected on the TV to be able to view it.
You can also respond back with more questions if you have any.
I am happy to help.
Dave
Jun 27, 2008 | Audio Players & Recorders
Mitsubishi WD62627 62" HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
