Question about Sunon (16-02-006) Fan Kit
Which kind of fan i should choose?
The cooling fan of my sotec 3123xs is broken. when it works, it makes big noise. i want to buy another sonon fan, i am not sure which kind of fan i should choose
  • 4 Answers
The fan in my Sotec 3123 xs also made noise, but there was an easy fix. All I had to do was to:
(*) turn the PC over so that the bottom faces up.
(*) remove the small plastic plate next to the plate that covers the fan. The small plate is attached with two small Phillips screws. On my PC, the Microsoft license sticker is attached to the small plate.
(*) use a small blade to pry off the plastic plate that covers the fan inlet.
(*) push on the center disk of the fan. This pushes the fan back where it is supposed to be so that the fan blades do not hit the fan housing.
(*) use a moistened cotton swab or similar to clean the dust from the fan.
(*) pop the plastic fan cover plate back in place.
(*) reattach the small plate with the two screws that covers the memory.
You are done!
Posted on Dec 28, 2013
  • 51 Answers
If you want a quality fan id go for the Cooler Master brands
but if you want a cheaper fan go for the fans off EBAy
hope this helps, Maxicube
Posted on Feb 10, 2008
What kind of cpu cooling fan can I use in a Acer America ASE380-UD420A desktop computer?
Cooling fan to CPU are come along with the CPU. You can use any other fan, having speed regulator pin, ie, the connector wire to it will have three conductors. Keep a close look at the size and seating screws to its body to the heat-sink of the CPU.
Jul 22, 2014 | Averatec Sotec 3200 Series Fan with...
My EEe PC904HA is having a strange noise when I open it. It sounds like a fan noise and this is the first time I experience it,
You may have dirt buildup in the ports where the air normally flows, buy a can of compressed and do a complete blow out of the fan and ports this can make a big difference, if there is no change you may need to replace the cooling fan
Mar 28, 2012 | ASUS Eee PC 904HA PC Notebook
I have a fan error on startup and pc shutdown
This might have to do with how the fan is being connected for power...if it is not connected to the motherboard and you are using some sort of controller....then you have to go into the BIOS (Setup) settings and tell it to stop monitoring the fan in question. All this is assuming that the fan in question is working!
Jun 25, 2011 | Averatec Sotec 3200 Series Fan with...
Air conditioner fan is making a loud noise
1. Could be a caught foreign object between A/C (air conditioning) fan and cooling radiator, producing this loud noise.
2. Could be a damaged fan blade, mowing the cooling radiator.
3. Could be a loud noise comming from the fan's electrical motor.
4. Could be a broken off fin (small wing) of the cooling radiator, striking the A/C fan, producing this loud noise.
Jun 14, 2010 | Dodge Grand Caravan Cars & Trucks
SOUNDS IN MY LAPTOP DOES'NT WORK
dear coneect to internet and find his drivers for further assistance contact with me at
sherdil20@yahoo.co.in
Dec 26, 2009 | Averatec Sotec 31100 and 3200 Series...
My CPU is making lot of noise especially when I'm using programs like Adobe reader
The CPU wont make noise unless its frying. So its either your hard drives, cd drives, or your fans.
If its your fans i sugest buying newer "Cool Master" fans that are powerful but less noisy
Oct 20, 2008 | Mesh 80mm Aluminum Fan Filter Fan Kit
Fan error
You mite not want to reset this. This could be telling you that your fan is faulty/Dieing. If so then if it doesn't turn off your comp, your CPU will fry from the heat. Try replaceing your CPU fan within your computer. "Cool Master" is a good brand. you can find them at any Fry's Electronics Store.
Oct 05, 2008 | Averatec Sotec 3200 Series Fan with...
Averatec cpu fan
IF you check your BIOS and everything is fine, and also you run a stress test, and everything clears. They you have no problem, usually you see this error in custom builds.
rate pls
Jan 19, 2008 | Averatec Sotec 3200 Series Fan with...
Mother Board Fan Making too Much Noise
There are 2 main reasons for the CPU fan to run noisily.One is that there is film of dust accumalated on the cooling fins thus not allowing air to circulate and cool the CPU properly.The second is that perhaps the fan needs to be oiled because the sleeve bearing has gone dry.The most common problem for a noisy CPU fan is accumalation of dust.You will have to remove the fan and clean it thoroughly with a soft brush.
Dec 21, 2007 | Asrock 845GV (P4I45GV) Motherboard
Sunon (16-02-006) Fan Kit Logo
405 people viewed this question
Top Sunon Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Sunon Computer and Internet Expert? Answer questions, earn points and help others
