Question about HP OfficeJet 6110 All-In-One InkJet Printer
Chatters When I turn it on, my HP6110xi starts normally, and the cartridges move to the middle of the rod, but then a chatter sets in. It goes "dit dit dit" (pause for 1/2 second) "dit dit dit" (pause) ad infinitum until I turn it off. What is wrong?
  • AlWash Feb 10, 2008
    Thanks for trying, but the chattering continues
    Guru:
  • 731 Answers
i belive that your printer needs to be resetted. Just try the reset options which are for HP 6110xi.
POWER DRAIN:-Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON buton for 30-60 seconds.
PARTIAL RESET:-Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the buttons.
----(for below reset cartridges must be removed out)---------
SEMI_FULL RESET:-Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes,or wait for 20 seconds,hen release the button.If the printer goes off dont worry release the button and Push the ON button.
FULL NVM RESET:-Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold OK and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
(Notes - resets will take a while)
Thank You
Posted on Feb 10, 2008
Hp960c When printer is turned on the on light and middle light flash on and off and the printer makes a chattering noise. the ink cartridges will not move from the right side of printer.
sir ur printer is struck...for how long u didnt use ur printer?
this is what hp site says
if the lights r blinking alternativy
Carriage stall Turn the printer off. Open the top cover and check for any thing blocking the ink cartridge carriage. Turn the printer back on.
Jul 06, 2008 | HP Office Equipment & Supplies
Loud chatter on start and rattle from timing chain area
The timing chain area also takes in the alternator and water pump. To isolate the source of the noise, use the old mechanics trick.
Place a 3 foot 1/4 inch brass rod against the flap at the opening of your ear and push until it closes. Place the other end of the rod against various engine components and listen. The noisy problem will conduct the noise up the rod to your ear and you can hear quite precisely where the problem is. Much safer than laying your ear all over a running engine.
You can also loosen the fan belt and run the engine without alternator or water pump (briefly) to see how that affects the problem. Chatter on start makes me think of starter and Bendix gear problems. Sounds like a 2 person diagnostic team to me; one to start the car and one to listen and probe.
Don't know if Subaru Forrester has an engine that has valve interference at piston Top Dead Center. If it is and the timing chain breaks, you are looking at major $$ to recover.
Nov 06, 2012 | 2004 Subaru Forester
Car doesn't start. when ignition is turned (new ignition) I hear a relay chatter and my horn sounds intermittely, Battery is new & tested goo
The chatter is due to low voltage. Check all the connections. The battery may have corrosion that lowers the voltage.
Oct 20, 2012 | 1999 Dodge Neon
A relay in my rooftop model 57915.33 chatters intermitently and trips the shore power breaker.
The reason the lights are not flickering and breaker not tripping when 6 pin harness disconnected that goes to roof unit is because the compressor and fan are disconnected, which would be the major draw that causes it. There is a few ways you can narrow down the cause, or defective relay, but my guess is if it's causing lights to flicker and breaker to trip, it's on the compressor circuit. The fan coming on and off unless capacitor faulty wouldn't draw it down that much, and obviously capacitor is good otherwise it wouldn't operate good when turned on normally. I'd start by inspecting wires to and from thermostat for possible rubbing or touching against one another at a bare spot perhaps. Can't rule out 100% that thermostat isn't defective as well. When thermostat set to cooler temperature, and on, does it turn off and on in normal cycles, to maintain temperature?
Nov 27, 2011 | Dometic Rooftop RV Air Conditioner
Servos chatter? When I power up to take lift, the sevos start chattering and I lose control. Any way to fix problem?!?!?! Joe
replace the servo's or check the link rods make shure that thay move free and smooth
Mar 25, 2010 | Toys
Our bathroom faucet ''chatters'' when you turn it on. What can I do?
this is a common problem its normally the copper piping inside the walls are not secured to the beams well enough and it causes water hammer in the lines...
if its only just started doing it recently you may get away with cleaning out your taps or replacing them but alot of the time you cant do much about it as the pipes are concealled in the walls
Jan 02, 2010 | Price Pfister Ashfield Single Control...
1995 jeep wrangler starting problems
would replace starter and inspect battery, cables/terminals also if problem still chattering u may have damaged the fly wheel the chattering is the starter not fully engaging the fly wheel. most likely starter but bad battery cables would also cause same symptoms hope this helps u
Apr 02, 2009 | 1995 Jeep Wrangler
When I turn on the power to the printer, the print carriage cycles to the right as normal then carriage sticks and begins to continually chatter.....at the same time the light bar on the scanner trys to...
There is usually a sensor on one side or the other of the carriage. When you power up the machine, the carriage will be moved to that end, setting off the sensor. Then it will move back and forth to test carriage motion. If the end sensor is faulty, the carriage will still attempt to move until it triggers the sensor, but when it gets to the extreme end, the motor will continue to attempt to move it, causing the chatter. After a time, it will stop with an error message.
Look at the carriage where the cartridges are, and you should see some kind of tab or ear on it. If it's broken, then you may get the symptoms I mentioned above. Also if you can see the sensor, make sure that it's not broken or moved out of place.
Mar 15, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
173 people viewed this question
Seeker5211
Seeker5211
