Question about Sony Cyber-shot DSC-W55 Digital Camera
Blank LCD Screen
I accidently left my camera in the car overnight-not sure of the temp. but I'll say 28-30 degrees. It turns on but the LCD screen stays black. It's hard to do any troubleshooting if you cannot read the screen. Thanks for your help.
  • 2,130 Answers
Does it still take pictures and you can see them by downloading them to a PC? If so, your LCD screen is probably bad and will need to be replaced. I have replaced these before, its not hard to do if you can purchase a replacement screen.
- Jim
Posted on Feb 10, 2008
Fuji HS20EXR wont turn on after turning off
A defective rechargeable battery caused this on my camera, not sure about the blue haze though. Make sure battery is good or use fresh alkalines.
Mar 24, 2014 | FUJIFILM HS20 EXR Digital Camera
I accidently left my camera in the car in the heat. Now the LCD screen is black around the edges. Can this be fixed?
To answer you main question YES, you need to bring it to a camera shop and have a new lcd ordered for it. As the sun burned in the liquid and thus the screen will need to be replaced.
please be considerate and leave positive feedback and ratings for your free answer today/
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 27, 2010 | Kodak EASYSHARE M1063 Digital Camera
Sony DSC-W5 camera and the LCD screen is blank (white)
Remove the Battery pack from the Camera then press and hold the power button for 30 seconds.
Next, reinsert the Battery pack in the Camera and try to turn it ON. Make sure that the Battery pack is fully charged. If the LCD remains white then the LCD screen needs to be serviced or replaced.
Nov 25, 2009 | Sony Cyber-Shot DSC-W5 Digital Camera
LCD Scree went blank/black
No problem. Discovered that fix by accident when my camera did the same thing. Since the screen was blank, tried arranging camera setting using the camera's AV cable with the TV, and discovered that fixed it. Apparently corrosion builds up on the AV cable plug switch (which also turns the screen off when inserted), and inserting/removing the plug several times can fix it.
Jul 10, 2009 | Canon PowerShot SD10 / IXUS I Digital...
Blank LCD screen on shooting mode, but does show settings. Will not take pictures. Replaying mode works, shows pictures taken before screen went blank. New batteries. What is going on??? Is it...
The Display button manually turns the LCD display on or off to save batteries. If you accidentally had turned the LCD off, It should only take one press of the button to turn it back on and leave it that way. As such, it's not you but the camera. The A570 IS is relatively new. Your camera is likely still under warranty. If so, contact Canon for warranty repair (see the following link):
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2113&fcategoryid=221&modelid=14905
Mar 15, 2008 | Canon PowerShot A570 IS Digital Camera
LCD Screen Turns Blank with i rotate it 180 degress
Seems like the cable is damaged. You should get it fixed by SONY.
Feb 24, 2008 | Sony Handycam DCR-HC30 Mini DV Digital...
Blank lcd screen
Did you accidentally hit the DISP button (bottom left button) ?
Feb 15, 2008 | Canon PowerShot A540 Digital Camera
Balnk white screeen on my A610 powershot
unfortunately since the problem is on the hardware (lcd screen), there is no way of fixing it except from the people of the service center.
Jan 14, 2008 | Canon PowerShot A530 Digital Camera
LCD Blank
the flex wire of the lcd monitor is already cut and already left is on the touch screen that why is functioning ...go the sony service for the replacing flex wire...or to the other service center for fixing the flex wire....
May 02, 2007 | Sony Handycam DCR-HC40E Mini DV Digital...
Lcd monitor screen stays black
there may have been some kind of damage to the lcd. sounds like you are going to have to send it in to have it fixed.
Jun 13, 2006 | Casio Exilim EX-S500 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
115 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
