Question about Acer Aspire 5630 Notebook
Inbuilt speakers are not working
My new laptop inbuilt speakers are not working ,but it works with external speakers and with headset, and device properties areworking normally,i have updated it and everything is upto date, ireally dont know what to do,it would be great help if you can help to resolve it
  • Anonymous Feb 16, 2008
    I have IBM thinkcenter PC which has inbuilt speakers. Unfortunately music cannot play through it. However loging in/out sound is coming. Is it a hardware problem or the music player (totem) not detecting it? Please help.
  • mrjk Apr 23, 2008
    Genius:
  • 3,587 Answers
Hmmm....only thing that might be the issue is the mute button is checked in the volume settings. OR, the connector underneath the keyboard, might be off a bit. This is a simple system, so it's either of those. If both speakers are out, then it's most likely the small connector that you can access under the keyboard. It's not too hard to get to, but be careful when pulling up the masking plastic prior to removing the screws.
Got backup?
Posted on Feb 10, 2008
I can hear people but theycant hear me on my headset
microphone should be change,,,or use headphones
Mar 21, 2015 | Acer Computers & Internet
Skype not working
Sir,
Click this link for more information........
http://support.skype.com/index.php?_a=knowledgebase&_j=questiondetails&_i=35
Also Check........
On a PC with external speakers and also a headset with microphone. Windows XP is configured so that standard audio are external speakers and standard microphone is the headset. Skype is configured to use the headset for audio in and out.
This way one can listen to sound from the PC and from MP3 players through external speakers and if there is a call to make or take, this is going through the headset.
But now there is the problem that the noise level for the headset is too low. Increasing volume has no effect on the headset, it only affects the external speaker's volume.
Now the solution: Going to the control panel and opening the sound setting, go to the audio tab. The external speakers are selected as default. Just temporarily select the headset and then click on volume just below. You can now set the volume for the headset, click OK and click cancel (!!!) on the sound control dialog box. This way the external speakers remain as default output.
Skype-->Tools -> Options -->Sound Devices-->audio device/USB/etc Audio Device (do NOT use windows default device)
You can also tick the ring pc speaker check box as this is a good backup to alert you even
if the main speakers are off or turned down.
Windows:
Start-->Control panel-->Sound and Audio devices
On the audio tab set the default playback device to your main soundcard(AC97/Audio-chip/add-on-adapter), etc.
Your installed audio device must be present there.
If not, reinstall audio device
thanks
good luck
Oct 29, 2008 | Altec Lansing Stereo Headset with...
Headphone jack of my laptop does not work properly. I get sound from both the laptop speakers and in the headset. So i bought a USB audio device. Still the sound comes from laptop speakers and there is no...
You have to set the software in order to connect the wright way. with a USB device it will never work.
go to the properties of your audiocard and theire select what you want
Feb 13, 2010 | Logitech 250 Headset
External mike doesn't work
I'm assuming you have Windows Vista. If so, you may need to change the default microphone, particularly if you have a built-in microphone on the computer.
1. Right-click the speaker icon next to the clock in the system tray.
2. Select "Recording Devices"
3. Select "Microphone" or whatever item you want to record with.
There will be a VU meter showing the input level. Try talking into you mike and see if the VU meter goes up. If so, you're good to go.
If not:
1. Click the "Properties" button in the screen mentioned above
2. Move the "Volume" and "Boost" sliders up.
3. Click "OK."
4. Check your VU meter again.
If this does not work it is possible you selected the properties for the wrong device. Click on another device and repeat the last 4 steps again.
Jun 02, 2009 | Dell Inspiron 9300 Notebook
Toshiba Satellite Laptop - No sound when connected to earphone
possible solution: go and check your audio properties. the line-out might have been disabled, muted or simply turned down.
May 25, 2009 | Toshiba (4CH-VOUT) Sound Card
No sound come through external headset or desktop speaker
Sometimes the headphone jack has its own volume control separate from the internal speakers. Check the levels in the volume mixer.
Apr 22, 2009 | Acer Aspire 5500 5570-2609 Laptop
Hi, I have a problem with Acer Aspire 5570. When the sound output is all fine with inbuilt speaker but when i connect to the external headset or to any desktop speaker, I dont receive sound. My device...
This is a common problem with all DJ's I know. Sometimes this is due to the fact INADVERTLY one connects powered equipments to the jack. The card is OK, but the jack gets fried. One nice solution is using USB sound cards (the ones that resembles Pen-Drives) and be in business again.
Apr 16, 2009 | Acer Aspire 5500 5570-2609 Laptop
Headset and inbuilt speaker works at same time
Can you not just disable the built-in speakers in control panel while you're chatting on the mic?
-Aaron
Jul 30, 2008 | Acer Aspire 3680 Laptop
I want to use external speakers and USB headphones in harmony
right click at my computer then click properties then click hardware then click the device manager did you see the yellow ?mark right click the device then update the driver then choice the best driver for your C-Media A97 list of drivers will appear then the best one
Mar 23, 2008 | Computers & Internet
Help
See if the latest drivers are installed for the device, by going to Acer's website.
If it is an old laptop and the same was working on the earlier installed operating systems, and now it is not working with new os .. check for the drivers.
And if all of a sudden this happened check for a cable connector which might be right below the keyboard of the laptop. be carefull when you open the keyboard, and just follow the cable from the speakers and you will be able to locate the connector , check whether the connector is loosened of disconnected. Hope your problem will be solved, Cheers-parveen
Feb 10, 2008 | Acer Aspire 5630 Notebook
Acer Aspire 5630 Notebook Logo
144 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
