Question about Panasonic CQ-VD6503U Car DVD Player
Not video what do i do if brake bypass don't work? i connected the light green and the black grounds together is there anything else i should do?
  • magik626 May 11, 2010
    what will this do if i Connect the light green wire and the black wire to chasis ground.?
    Problem Solver:
  • 19 Answers
Posted on Feb 10, 2008
Yes im tring to find the parking wire i dont know what color it is trying to watch video not working
The parking brake wire for this unit is light green. Try connecting it the unit's ground wire (black) and test for video. If it does not show video when connected to ground, install a two wire toggle switch. Connect one wire of the toggle switch to the light green wire and and the other wire of the toggle switch to ground. In this manner you will be able switch the screen on and off when viewing videos.
Nov 23, 2010 | Kenwood DDX514 Car DVD Player
There is no video on my kenwood ddx8017, why? Do i have to bypass the parking break wire? which one is it, the solid green, or red with black, or pink?
If you want to watch videos on your unit it is necessary to bypass the parking brake wire from the Kenwood unit. The parking brake wire is light green and the best possible way to bypass the unit is by installing a toggle switch. The toggle switch should be a two wire device. Connect one wire to ground and the other wire to the parking brake wire from the unit. This will allow you to switch the supply on the wire to ground when needed.
Also, in some older Kenwood units you could just as easily connect the parking brake wire to ground and be done with it but, it does not always work.
Oct 08, 2010 | Kenwood DDX8017 6.5" Wide Dual DIN Indash...
When i put a dvd in the disk drive it only plays the audio. the video screen just says something like ''warning dont drive while watching video'' this happens all the time even if im in park.
You have to bypass the parking brake arrangement, which usually means just wiring that wire (it's the one the manufacturer wants you to have connected to the handbrake, Pioneer uses a lime green color) to the black ground wire. This works with most, but I have noticed that newer models work around that so you may need some sort of bypass toggle switch.
Oct 04, 2009 | Car Audio & Video
No picture after bypass of pioneer AVH-P4000DVD
remove the toggle switch and pray you didnt do damage to your delicate stereo system
Sep 27, 2009 | Pioneer AVH-P4000DVD Monitor
Parking brake bypass
Connect the hand break wire (light green) to the ground wire (black). It tells the system the hand break is up and even movies work :) .
Dec 11, 2008 | Pioneer AVIC-F700BT Car GPS Receiver
Dvd player while driving
he is right to an extent i have installed many of these the yellow black wire off the rca harness you have to pull the pin out of the harness and move it up one space and ground it out just an fyi if you vss wire is connected it wont work either let me know if you have any other questions
Sep 12, 2008 | Pioneer AVIC-D3 Car DVD Player
I got a ?
Normally, the emergency/parking brake has to be activated/engaged for the video player to operate.
By bypassing, you are simulating this condition even if in reality, the emergency/parking brake is not activated/engaged.
Solution > ground the video player's brake sensor wire rather than connect it to its intended connection point.
In some brands/model/versions of the video player, this would be light green (Pioneer, Clarion, JVC), green (Kenwood),
In some other rands/model/versions of the video player, there would be a bypass switch underneath a sticker, others would need a special adapter, still others have bypass option/feature in the menu/setup and some would require a toggle switch that would connect the dvd brake wire from positive to ground.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information. A reminder pls, in some regions bypassing is not allowed.
Good luck and kind regards.
Jan 05, 2008 | Dual AM/FM/CD/DVD/WMA 2.5 MONITOR Car...
Brake bypass jvc kd-av7010
ground the e-brake wire to something other than the e-brake start the dvd when you hear sound press "stop stop" then enter the code 26604 then press "enter" you will have to do this every time you want to watch a movie but it works.
Dec 06, 2007 | JVC KD-AV7010 DVD Multimedia Center Car...
Panasonic CQ-VD7005U in dash dvd 7'' touch screen
Connect the light blue parking brake wire coming out of the back of the radio to the black ground wire also out of the radio to the black ground wire on the wiring harness.... Basically just ground the parking brake wire.. Itll work, I promise. I have the 7001u.
Dec 03, 2007 | Panasonic CQ-Vd7001U
Bypassing the parking brake feature
just earth the handbrake cable (light green) on a good earth point.
May 01, 2007 | JVC KD-AVX1 Car DVD Player
Panasonic CQ-VD6503U Car DVD Player Logo
98 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
