Question about Hunter 30200 \ 30010 (Set) Air Purifier
Wont run after I cleaned it
I resently moved into a office area where smoking had been a problem. I took the unit and clean both filters. I sprayed the outside with windex.... put it alll back together and will not turn on.... does it have a safety button somewhere.
On the model 30200 there is a safety interlock switch actuated by a plastic tab (about 4" down from the top of the front filter cover) on the right side. Assuming that all you did was take off the front cover and clean or replace the filter(s) and the unit was working previously, this should be your answer. If in taking off the cover the switch actuation tab was broken off, you could (carefully) wedge a tab into the slot where the switch resides. This defeats the safety aspect of certifying that the unit isn't running when you remove the cover. The safe work-around is to unplug the unit before you open it for service.
Posted on Mar 23, 2008
I have a ionic pro turbo, I would really like to clean the oxygen plus filter other running the vacuum over it. We smoke so it has a build it up on. Can I remove it and wash it?
The collectors are made to be removed and washed. All of the build up from smoking on the collector plates will be very difficult to remove. You will probably need to spray on some 409 or any type of spray cleaner and let it sit for a while then keep on doing it until most of that will be removed
Nov 23, 2014 | Air Purifiers
We have had the unit for about 2 months and keep in our garage where we smoke. At first it was super but after a few weeks the unit did not handle the smell as well. I cleaned the plates per the...
Sounds like you did a thorough cleaning, except you didn't list cleaning the air intake filter. If you didn't clean it, there is the problem. The filter is just as important as all the other parts you listed.
Apr 26, 2011 | Ecoquest Flair Air Purifier
When clean the filter in one hour the machine stop and i need clean back
clean the metal filter grid blades with a long strip of scotch brite pad and also clean the corona wires in the back of the unit very gently with light grade sandpaper. i had this problem and tried cleaning my unit so many times that i was ready to toss it into the trash. now it works normally. i did some spray painting in the room where the unit was operating and believe it picked up a coating of paint causing the sparking. good luck!
Jul 22, 2010 | Sharper Image Hybrid GP (SI724) Air...
How do I clean the Oreck Air 7
Hi There,
Here's how you can clean the machine, and I have copied the link to the owners manual below for your convenience.
Cleaning
The Cabinet
You can clean the air purifier cabinet with mild, non-abrasive cleanser and a
soft cloth. IMPORTANT: Unplug the unit from its electrical power source.
Do not spray cleansers or furniture polish into the louver or grill areas.
Collector Cell
Indicator light is green under normal operation and flashes red
when the cell requires cleaning. To clean, proceed as follows:
The red "WASH CELL" light will flash or illuminate when it is
time to clean your cell. However, it is recommended that every four to
eight weeks or if snapping sounds become frequent, clean your
electronic air purifier. Your electronic air purifier is still filtering the air
when the red light illuminates. Cleaning your electronic air purifier is a
snap too... and a must for efficient operation.
1. Turn the unit off and unplug it from the electric power source. If wall
mounted, remove unit from wall.
2. Remove front grill by unscrewing the retainer screw under the grill on
the cabinet bottom. (fig. 1)
3. Pull the cell out of the cabinet by using the two small handles on the
front of the cell. (fig. 2)
4. Snap off the charcoal odor absorber from the back of the cell. Change
as necessary for continued odor removal. (fig. 3)
5. Slide off pre-filter. This can be cleaned with the cell and reused. (fig. 4)
NOTE: Handle the electronic cell with care. Damaged metal plates
and/or broken wires will cause the air purifier to malfunction. (Do
not wash charcoal odor absorber; it is disposable.)
Cleaning with Assail-A-Cell® Cell Cleaner:
6. Using Assail-A-Cell® Cleaner, thoroughly saturate the cell and prefilter.
Be sure to spray between each cell plate and cover every
surface. Allow product to soak for a few minutes, not allowing it to dry.
Rinse thoroughly with water. For extremely heavy deposits, repeat the
process.
IMPORTANT: Dry the collection cell thoroughly outside of the
air purifier before reinstalling it into the air purifier. Ensure
that all areas including corners and areas that may trap
water are dry before reinstalling into the air purifier. DO NOT
process.
place a wet or damp collection cell in the air purifier.
Here's the link to the owners manual for your Oreck Air 7:
http://www.oreck.com/includes/customer-service/owners-guides/pdfs/3323-3018-AIR7-Rev-H.pdf
I hope this was helpful to you. If this helped, please be kind and rate the repair, or leave feedback for me. Thank you,
Chris Jones
GoVacuum.com
May 01, 2010 | Oreck Super Air 7 Air Purifier
"Cleaning overdue" red blinking light after cleaning was done
Check that there are no fine pieces of lint that are bridging the plates or the ionizing wires, to ground.
Check the contact points of the collector cell and inside the unit.
The light is caused by a shorted collector cell and associated components.
Dec 21, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
How to troubleshoot a Pure Ion #AP-75 non-working
My ionair cleaner doesn't clean the air what so ever. All four filters are perfectly clean after running for over two months. All of them are properly inserted and seated as specified. No filter warnings turn on and the unit works in all other ways. There is an ongoing fire in the hills nearby and our house if full of hazy smoke.
Aug 08, 2009 | Brookstone Pure-Ion UV Air Purifier
Have cleaned unit and will not work. The clean
I just fixed my proffessotional ionic. Im not sure what I did. lol. I took the screws out of the bottom, didnt see anything wrong, tho there is a piece of plastic in there, I dont know what it is. I cleaned the 2 center long metal like things, cleaned the contacts that the metal blades touch. cleaned the wires with alcohol and qtips, put it all back together, and it came on!!!!!!
Apr 20, 2009 | Sharper Image Ionic Breeze 3.0 Air...
I NEED EHELP TO CLEAN MY FILTER
I clean them with EcoH spray (other enzyme cleaners will also work) no matter what they have on them. Then rinse off with hot water. It works great with smoking, formeldahyde, soil, etc.
Dec 18, 2008 | Ecoquest Breeze AT Living Air Purifier
Clean Filter Red light
I cleaned the filters as well earlier and the red filter light still blincked to clean the filters. Then I pushed the power button for about 10 seconds continously and then turned it on and the light turned off.
May 22, 2008 | Brookstone Pure-Ion UV Air Purifier
Unit stopped smelling
Whenever you clean or replace the plate, you must also clean the contacts that touch the plate, and all supports for the contacts. Clean them with 70% or higher isopropyl alcohol and Q tips. You should also clean the ionization point with a Q tip and alcohol, remove and clean the fan and oil the fan motor front and rear with a drop or two of sewing machine oil. Replace the fan so that it is flush with the end of the shaft. Make sure that the contacts are firmly against the ozone plate when you replace it. They sometimes barely make contact and then don't work well. You can bend them enough to make them fit firmly.
Nov 06, 2007 | Ecoquest Breeze AT Living Air Purifier
Hunter 30200 \ 30010 (Set) Air Purifier Logo
284 people viewed this question
Top Hunter Air Purifiers Experts
Marvin
Marvin
Steve
Gerry Harvey
Gerry Harvey
Are you a Hunter Air Purifier Expert? Answer questions, earn points and help others
