Question about Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook
MacBook Internet connection
I have a new MacBook laptop.Even though my Airport is showing a full strength signal Safari keeps telling me I have no internet connection, Network diagnostics has not solved the problem. It will pick up the wireless network at work immediately but I keep getting the "your computer isn't connected to the Internet here at home. I have a netopia Router and my other Sony laptop can pick up the internet without any problem. i have been trying to fix this now for over a month. any help would be really appreciated !
  • 2 more comments
  • squidgy Feb 09, 2008
    I have a very basic techie Knowledge & would need step by step instructions on this one ! Thanks again !
    Rookie !
  • squidgy Feb 10, 2008
    Cheers Jason !! It's a Netopia router from Eircom. 3347NWG made in Thailand ! ! I tried the Network setup assistant also but still no joy ! Really really appreciate any help !
    squidgy.
  • eli7 Sep 05, 2008
    My Mac Book just quit connecting to the internet. I took it to a public wifi location and it won't connect there either. It worked one day and then wouldn't connect the next day. I've been through all of the suggestions that I've seen online. I have another Mac Book that connects fine and the settings on this one are the same.
  • Kevin Pettit
    Kevin Pettit May 11, 2010
    Have you tried using the assistant 'Internet setup utility' ?
  • 178 Answers
Ok call me or I can post for you. I know what your problem is. But i need to know what model netopia router you have. Kepp in touch
Thank you
Jason
Posted on Feb 10, 2008
I have airport set up at home. One laptop receives a good singal another one does not.
AirPort signal strength is directly affected by things like concrete walls and metal ducting. You might want to change the physical location of the Airport to help with signal strength. Placing your Airport router in a central location based on computer usage location will help a lot.
Also changing your routers wireless channel thru Airport Utility can help. Think of it as a lot of people using the same street, it tends to get a little crowded. So changing the street means less traffic.
Dec 05, 2010 | Apple 13.3 MacBook Intel Core 2 Duo...
The Internet on Mac book pro will not work. I usually use wireless but even connected to Ethernet .... When I do diagnostic it says everything is working. Any thoughts out there - I can't get the safari...
check your network settings in system preferences. Is there a green dot next to airport? Ethernet? Check your modem and router for your connection.
Sep 20, 2010 | Apple MacBook Pro Notebook
Apple Macbook Pro does not connect to wireless network
The antennas in the Macbook Pros have had an issue with reception due to the aluminum housing of the laptop but, should still receive decent reception just not as much as a plastic Macbook or plastic PC laptop. It could be possible that the antenna's cables have become disconnected from the Airport Extreme card inside your Macbook Pro, that the card itself is faulty or damaged or that the Antennas themselves have been damaged in some way. As always make sure you have the latest updates and have installed any driver updates from Apple regarding your Airport Extreme card. Here's an article that may help eliminate any wireless interference that may be affecting your signal strength. Apple - Wireless Interference hope this helps, if so don't forget to comment, vote, etc. Thank you.
May 28, 2010 | Apple MacBook Mac Notebook
I f I connect hotel internet via Apple USB 2.0 Ethernet Adapter to my MacBook Air, internet after few minutes disconnected, to connect again i take out the cable, and then plug in, usually internet start...
Try turning off Airport. Your computer may be finding a wireless network and automatically switching to it, and getting an intermittent signal. Just a guess, but for a good ethernet connection you want to disable the Airport searching feature anyway.
Open the System Preferences application, select "Network" and right on the top left of the resulting window there's a pretty big button that will either say "Turn Airport On" or "Turn Airport Off" - just turn it off if it's not already ...
Hope this helps!
For help with Public Address Systems see my new How To Video, available as a DVD at www.whamuniversal.com
Feb 15, 2010 | Apple USB 2.0 Ethernet Adapter for MacBook...
My clamshell ibook shows signal but won't load sites...
Try with Safari or Firefox. If still no pages loading then your Airport is not connecting to the Internet. If you are using a cable modem contact your ISP for assistance.
Jun 29, 2009 | Apple iBook G3 Clamshell (M2453B) Mac...
Not able to connect to internet via airport express
Have you checked your system preferences, network settings? You have to tell the mac to use airport or ethernet. It may be setup to use the hard wire and not airport. You should see a link to turn on airport in the upper right corner of your screen. I think you can turn airport on there.
Apr 03, 2009 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Macbook loses wireless internet connection
Hi 8233 is a good choice for a router
Here's your solution
1. These steps are to be performed strictly from a computer which is wired.
2.Even if you are using your mac book turn of the airport and connect it via a cable.
3. Open your router setup page by typing in 192.168.2.1 on your browser tab or typing i http://192.168.2.1 in the run window
4.An rsp will open and on the top right hand corner of the screen it will say Internet status:: connected
5.On the left hand side change you"ll see channell under wireless
6. Select it and change it to 6 or 11 for best signal strength
7.Now to the most important segment 8233 has a piculiar issue with its extra strong security
8.On the left hand side under wireless you"ll will see an option called wi-fi protected setup
9.Select it and turn it off reboot router and wow the problem should definately be resolved .
Then turn on airport and go wireless along with your wife.
10. You will still be secure with your data through security option on your router (wep or wpa )whatever you use .
Thank you and just let me know if it worked or not
Feb 26, 2009 | Belkin (F5D72304F5D7000) Router
No internet with wireless laptop
Check to be sure that your network connections are set to automatic(control panel->network connections then right click on your wireless connection go to properties- tcp/ip click on that and check there.
Oct 29, 2008 | Linksys Wireless-G Broadband Router
Can't connect!
First of all... Unplug the modem, unplug the Airport (WiFi router) and turn off the Airport connectivity in your MacBook.
After 5 full minutes... Plug in the modem.
Wait 2 full minutes... Plug in the Airport.
Wait 1 full minute... Turn on the Airport connectivity in your MacBook.
After all of that...
If you're still not back up and running and you're using an Apple Airport, open the Applications folder, open Utilities, open Airport Utility.
If you're using any other type of WiFi router, use the Network Diagnostics button that should show up in the web browser window when you try to go to any website.
Aug 28, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Macbook Airport Problems
You should check to see if you have the connection set to static or to scan. Your computer could be set to scan, and so when it recieves a stronger signal, even if it is for a second, it will disconnect from the signal you have current. You can go to system preferences , select NETWORK, go to show, then AIRPORT, make sure your signal of choice is at the top of the list.
Aug 24, 2008 | Apple MacBook Mac Notebook
Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook Logo
141 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
