Question about Linksys Wireless-N WRT150N Router
Wireless connection cuts in and out
The wireless connection on my router constanly cuts in and out. it will disconnect for a few minutes then reconnect for about half hour. the wired connection to it has no problem. i know its not my computer because it does this to all of the computers on the network at the same time. does anyone have any answer to this problem???
  • erdoc1234 Mar 05, 2008
    but how do I change channels??
    Master:
    Sergeant:
  • 440 Answers
Uslay gota change chs in option menu keep trying these are very bugy stiill ok
Posted on Feb 09, 2008
Acer aspire 5742Z wireless adapter Atheros AR5B97 intermittent fault loses all local wireless signals. Sometimes can I recover after diagnosing problem - sometimes need to reboot to recover. ??
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Nov 17, 2012 | Acer Computers & Internet
My wireless zyxel router disconnects about every 30 minutes.
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
Feb 03, 2012 | Zyxel X-550NH Router
Internet connection worked through my wireless router until recently on my Satellite L305-S5877. I have turned off my firewall to no avail. I have limited connection to the router wirelessly, but no...
First unplug all devices from your router. There should be a small button (mine is depressed with the point of a pen) on your router that is used to reset the router. I have to reset mine from time to time. Hold the button down for two minutes or so to allow it time to reset. If that does not work then disconnect your modem for a few minutes to allow it to reset Then reconnect everything in the exact reverse order that you disconnected. I needed to contact my router manufacturer the first time for help in resetting it.
Feb 15, 2011 | Toshiba Satellite L305-S5877 Notebook
My D-Link Router 615 keeps cutting out after a few minutes of working. I have no problems when I connect the ethernet cord directly to the modem.
Please check the wireless signal quality and strength you are getting from the wireless router.
Please do a continuous ping to the wireless router IP.
ping -t "ip of the wireless router"
Oct 31, 2010 | D-Link DIR-615 Wireless Router
Why does my Belkin N wireless router disconnect and reconnects
Turn off the firewall in the Router
Step 1 : Open RSP By typing 192.168.2.1 on the address bar of internet explorer
Step 2 :On the left side click Firewall
Step 3 : Leave the password blank and click submit
Step 4 : Disable it and click Apply
Step 5 : Restart te Router And try a Skype call
Step 6 : If it works let me know at warrierrakesh@ymail.com
Jan 04, 2010 | Belkin Wireless-N Wireless Router with...
Netgear DG824m Disconnecting every few mintes
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, arid welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply)
Nov 17, 2009 | NetGear DG824M Wireless ADSL Modem Gateway...
Ethernet connection gets disconnected very often
If none of the router jacks give you a solid connection and you maintain one when you directly connect to the modem, it is time to replace the router.
Mar 21, 2009 | NetGear WGR614 Wireless Router
WIreless router - internet connection cuts out
there might be a signal problem repair the connection to change its ip address by right clicking on the connection icon which is found at the bottom left beside the clock if the problem still persists, check the cables of the router
Feb 10, 2009 | Acer Aspire 5100 Notebook
USB wireless connectio
Please check your windows firewall settings (see exceptions)
Mar 09, 2008 | D-Link AirPlus DI-524 Wireless Router
Speedstreem ss2623
the signal strenth is always good>and try this login to ur router and change the channels use 11>or 1>and delete all temp files and cookies and clear history>and reboot the lap top also>and rate me solved if its helped
Oct 27, 2007 | Siemens Efficient Networks SpeedStream...
Linksys Wireless-N WRT150N Router Logo
125 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
