Question about Dell Dimension 4600 PC Desktop
Dell dimesion 4600 won't boot up
I can't get my dimension 4600 to boot up. I put it in sleep mode 2 nights ago, via the keyboard, and now can't boot it up.
  • 1 more comment
  • hiawatha100 Feb 09, 2008
    Thats the first thing I did, but no go. Thanks
  • hiawatha100 Feb 10, 2008
    When I power it up, the green led comes on on the front panel. The green led is lit on the motherboard, and the drives(dvd, cd burner). come on. No power to the keyboard, and no vidio signal. I just put a new power supply in it a week ago.
    Forgot to add that, the HDD wont come on either. I mean it doesnt spin, click or anything
  • 47 Answers
Now when when you say your computer doesnt boot up, do you mean it wont Power up at all? or does it turn on and wont boot into windows.
2 things you can do for either of these problems
1) If your computer doesnt power on, you may need a new power supply, contact me me if you need help buying a power supply,
2) if your computer turns on but doesnt boot to windows try putting in the ORGINAL windows disk you have when you FIRST turn on the computer and try and do a REPAIR YOUR CURRENT VERSION OF WINDOWS.
Your computer will boot off the windows disk and then prompt you to repair you version of windows. DO NOT REFORMAT YOUR HARD DRIVE or DO NOT REINSTAKK WINDOWS
let me know if this is of some help.
-rob
Posted on Feb 10, 2008
  • Robert Couts
    Robert Couts Feb 10, 2008
    i think you might need a new hard drive. How old is the computer. Hard drives sometimes need to be replaced because of the constant powering up, spinning, getting shut off, and unfortunatly getting shutoff by unplugging. Try this:
    when you turn on the computer. And its done trying to boot up. And it stays frozen try pressing the spacebar a couple times, and tell me if you hear the hard drive spinning.
    Master:
    Sergeant:
  • 440 Answers
U try to just hold in power button shut down all way for min then back on
Posted on Feb 09, 2008
  • nick helpap
    nick helpap Feb 09, 2008
    try safe mode remove sum crap from booting up msconfig ect ok
Came home to find computer off. It was left in sleep mode. The moniter keeps saying there is no signal and the keyboard has no power.
If its truely in sleep mode, and won't come out of sleep mode. Unplug the computer from its power, hold the power button down for 5-15 sec, then wait 2-5 full minutes. Then plug it back in, and turn it on.
If that doesn't work it is NOT stuck in sleep mode. Most dell computers I've worked with the caps go out in the power supply and/or the motherboard. I would next clean out the computer with canned air, check the caps on the motherboard, and in the power supply. If there are any bad caps, replace them, and it should fix it. Hopefully though the above paragraph fixes your problem.
Sep 13, 2013 | Dell Dimension 4600 PC Desktop
My Dell Monitor keeps going into sleep mode immediately after booting up.
Make sure your computer's screen resolution is fine for that when you power up the computer press F8 key 5 to 6 time untill you can see safe mode and other menu if you are able to see safe mode then enter in enable vga mode then enter as admnistrator go to control panel->display property ->settings change screen resolution to 1024*768 then apply and restart it.Let me know if you need further assistance.Thanks for using FixYa.
Aug 03, 2011 | Dell Dimension 4600 PC Desktop
I have a dell dimension 4600 computer. I usually put the computer in sleep mode when I am not using it. Usually I press the ESC button and the computer wakes up. All of a sudden, the monitor won't...
Plug the monitor into another computer to determine if the monitor is damaged or working properly. You can also plug another monitor into your computer to determine the same thing.
May 21, 2011 | Dell Dimension 4600 PC Desktop
I can't boot up normal, safe mode, or to the cd-rom on my dell dimension 4600 desktop, i've set to boot to cd rom in bios, but still nothing
If you are trying to boot off an Windows Installation disc then you might have a problem. On some computer the CD-ROM drive won't be able to read the operating system disc.
The solution to this issue would be to put in a DVD drive and try to boot from that.
More details on the normal and safe mode boot attempts would be nice too. Are you getting a blue screen or is it just hanging up?
Jun 06, 2010 | Dell Dimension 4600 PC Desktop
How can I open my Dimension 4600 in safe mode?
Power the PC down then power it up. As soon as the power comes on, Keep pushing F8 until you get a start menu. Safe mode will be one of the options.
Jan 28, 2010 | Dell Dimension 4600 PC Desktop
Dell Dimesion 4600-Yellow light after I added memory
take out the newly installed stick and see if it comes on.  if it does, find out if the memory and motherboard are compatible.  if your computer no longer boots even with the new stick taken out, you probably already burned your motherboard and the damage is irreversible.  it can also be a bad stick that you installed.
May 18, 2009 | Dell Dimension 4600 PC Desktop
Dell dimesion 8300 desktop--ac power alert when computer boots up
  • makes sure that the AC cord the you are using is compatible with the PC
  • and the right output / input settings are correct check the power supply voltage settings
Apr 24, 2009 | Dell Dimension 8300 PC Desktop
Dell Dimension 4600 PC Desktop Logo
329 people viewed this question
Alun Cox
