Question about Mitsubishi WS-65819 TV
Intermittent convergence issue became permanent
In the last couple of weeks the convergence of the WS-65819 would go way out of whack and then return by itself. This happened several times and now it appears to be permanent. I believe other posts have pointed to the STK392-570 convergence amplifier. Before I order parts I would like to get a service manual. What web site would you recommend? I have found a full service manual offered by User-Manuals.com for $14.99 and was wondering if this is a good site.
http://www.user-manuals.com/ws65819-p-219321.html
Frank
WHEN I TURN ON THE TV THE LETTERS ARE SEEN IN TWO OR THREE DIFFERENT COLORS AND THE SCREEN ON THE TOP AND BOTTOM IS IN A U BOW TYPE SHAPE ,SOMETIMES AFTER THE TV WARMS UP THE SCREEN IS NORMAL BUT THE PROBLEM IS NOW LASTING LONGER.
  • Anonymous Jul 24, 2008
    Ordered a service manual from them 2 days ago for 14.99 for a Panasonic. Never received it, but my card was charged. They will not return my e-mails asking them to credit my card. I get the feeling I've been had. The TV was fixed with one sentence of directions from dlplampsource.com. He said "the bulb is hidden behind the silver trim on the front of the TV." That is all it took.
    Problem Solver:
  • 15 Answers
Hi Ed,
Your convergence amplifiers are definitely bad. The user manual will not work, since it is the same manual that comes with the set when it was new. The service manual can be found at:
http://servicemanuals.net/results.aspx?type=SM&brand=0&model=WS-65819
Best Regards,
MyTvGuy
P.S. Thanks in advance for rating me!
Posted on Feb 10, 2008
    Problem Solver:
  • 19 Answers
Hi! My name is Aleixo. Before you do something, Frist of all, try resolder those IC pins, because you sad some time work fine some time not. May be this will help you. Good loock
Posted on Mar 05, 2008
My ws 65819 turns on but turned of in few seconds.any sugestion?
redmaxim@aol.com
Posted on Mar 12, 2009
My Mitsubishi ws-65819 shows in an oval shape, can this be fixed, also is there a way i can do it myself to save some money? Also how to play an Xbox 360 in HD?
yes......you can rplace the convergence ic's on convergence module......these are the big stk type ic's and also the low ohm resistors.
These are 3.9 to 6.8 ohm half watt on the yoke return circuit. Let me know how you fare......regards. meder's tv
May 28, 2012 | Mitsubishi WS-65819 TV
Mitusbishi Model ws-65819 color convergence repair. How does one go about fixing it?
The two stk-392=570 chips need to both be replaced===they are along with the rest of the circuit on the middle board.
May 20, 2012 | Mitsubishi WS-65819 TV
I have a 65inch mitsubisihi and having convergence problems need help on instructions to put in stk-392-570 chips to fix the problem. WS-65819
Here is a youtube video I found that was quite helpful to repair my WS-65819 this weekend: http://www.youtube.com/watch?v=63TbxQaNkVo
There is a part 2 that deals specifically with the soldering of the chips. Hope this helps
Sep 26, 2011 | Mitsubishi WS-65819 TV
Have a Mitsubishi WS-65819 (about 9 yrs). over past 3-4 weeks the color started to skew (3D like arch on top and bottom), then yesterday, the TV totally powered down and will not power up, totally dead. ...
You lost your convergence IC's and possibly a resister or two that are in the same circuit. If you are good at Soldering, this should be somewhat of an easy fix. I believe you can still get the IC's for this set.
Aug 09, 2011 | Mitsubishi WS-65819 TV
My WS-65819 won't power on. It would power on for
need to replace the stk's and some other caps, usually have to resolder the chasis on both convergence and power supply chassis.
Dec 03, 2009 | Mitsubishi WS-65819 TV
Mitsubishi ws 65819
Ur power board ic converter it dead.
Ur Convergence board is bad going to die to.
Both must change.
Aug 15, 2009 | Mitsubishi WS-65819 TV
Turns off as soon as I turn it on. ws - 65819
I had the same problem. The repairman said the Convergence ICs were bad, located on the big aluminum heat sinks on the center board in the TV. He replaces both, and a couple of fuses (that look like resistors).
The tv worked fine for a couple of days then did exactly the same thing. They are coming back out to fix it next week. If there is anything different, I'll post an update.
Nov 22, 2008 | Mitsubishi WS-65819 TV
Bow like image
You likely have bad convergence output ic's type #STK392-570.  These can be purchased at UED 800-648-6657.  You will need to remove the board they are mounted on to be able to usolder the old ones and resolder the new ones.  These will be mounted on heat sinks.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Sep 08, 2007 | Mitsubishi WS-65819 TV
Bowlike effect convergence all screwwed up
I suspect you originally had an intermittent solder connection on the convergence circuit board. This may have damaged the convergence IC's on that board by now if repairing those connections doesn't fix the set.
Mar 10, 2007 | Mitsubishi WS-65819 TV
Mitsubishi WS-65819 TV Logo
322 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
