Question about Kodak EASYSHARE 5100 All-In-One Printer
Rundll error message
I uninstalled Lexmark printer and installed Kodak 5100. Now I have popups that won't quit. I get this error message that says I have a missing module.
CWindowsSys32spoolDRIVER W32X86LXBT time.dll
    Problem Solver:
  • 19 Answers
What type of Lexmark did you uninstall? When you review your add/remove programs, is it still there?
Posted on Feb 09, 2008
I have just purchased an new computer and am running windows7 on a 64bit machine. I have tried several times to install the Kodak software from the disk provided with my printer which worked OK on my last...
32 bit and 64 bit drivers are not compatible. So for 64 bit operational system you have to install 64 bit drivers for your Kodak Easyshare 5100. I found link for you:
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9099&product=EKN033539
I am strongly suggesting uninstall everything what are you installed ignoring warnings about incopatibility before installing proper drivers! Good luck! :-)
Sep 27, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
What does Error Code 3807 mean and how do I fix it?
uninstall the firmware for the printer and then uninstall the drivers and then ran atf cleaner and then create a new user and then install it will work fine without any error
Dec 03, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
I have the Kodak 5300 All in one easy share printer. Less than a yr old. Also a Del computer with Vista Operating system, Less than a yr old. About a week ago decided to take the time to learn the kodak...
try using the system restore option on Dell computer.........as you have vista,,,click on the start button and type system restore in start search box and follow the on screen instructions and select yesterday's date and proceed.......should help:)
Apr 16, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak 5100 won't print with Windows 7.
I've had the same problem for some time, but recently found a fix. Those sneaky folks at Kodak updated their Vista driver for the ESP series, and it works with Windows 7 now. Oddly enough they haven't advertised this fact, but it works none-the-less. Now, you're going to have to uninstall the Kodak Home Center, the driver and anything else associated with Kodak. You need to manually go through the Program Folder and delete anything Kodak. Make sure you set explorer to show hidden files/directories, and go to Program Data and delete any thing Kodak. Finally go to users appdata and delete anything Kodak in all the sub folders there. Then download and install the new May 1 drivers from the Kodak site:
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9103/13657/13660&product=EKN035329
Note: They are the Windows Vista drivers, but they do work on my Windows 7 machine.
You'll also notice that they've updated their installer program.
Hope this works for you, and if it does spread the word!
Mar 06, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Problem Installing 5100 printer
During the install, dont connect the printer when it tells you to. close the window that askes you to connect the usb cable to the printer and PC. The install should finish.
Leave the printer disconected.
Reboot the PC. If easyshare was installed you have to set it up.. If you did not select Web Install during the install then, after reboot and easyshare setup, open the Home Center software. There should be a message saying there are software updates availible. If not click the [?] on the top right to open the side pannel and click the bottom link that says check for updates. Run and install the updates. after its done then connect the printer.
If you did not need updates then try uninstalling and downloading the software directly from Kodak.com (link near bottom of this message)
If the printer still is not detected then try another USB port on your PC .. the PC ports on the back of the PC that are directly connected to the motherboard are the best. You can also try a new usb cable, or hook up a powerd USB hub between the printer and the PC. Also try unhooking all other USB devices (not printer and keyboard) then connect the printer.
If you could not get the updates through the home center you can get them at kodak.com (link bellow)
http://www.kodak.com/global/en/service/downloads/dln_ekn033540.jhtml?operatingSystem=windows_xp&downloadLanguage=en
I hope this helps. If you still have issues respond to this with any changes or what happened when you tried each step.
SDtester.
Feb 29, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Problem scanning
Uninstall software and re-install with usb cable unplugged. It will instruct you in the installation when to hook it back up.
Jan 07, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Unhandled exception error after installation
uninstall software and reinstall the software with usb cable not hooked up to the printer.
Dec 05, 2007 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
67 people viewed this question
Top Kodak Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
