Question about D-Link DP 311U (DP-311U) Print Server
D-Link DP 311U wireless setup
Signed up for the new AT&T Uverse service to replace my existing DSL service. The new service came with a new 2WIRE wireless router with a different WEP key and different IP address range. I've been able to get my various PC's to connect to the new wireless network, but I've had no luck with the D-Link DP-311U print server. I've noticed that on the PC's the old 2WIRE router used Network authentication of 'open' and data encryption of 'WEP', whereas the new 2WIRE router requires Network authentication of 'WPA-PSK' and data encryption of 'TKIP'. there doesn't seem to be any way to specify anything other than 64 bit or 128 bit and ascii or hex for the encryption connection with the DP 311U. Am I missing something, or am I just out of luck with an old print server I will have to replace?
Roger
  • Anonymous Nov 23, 2008
    I have a gateway tablet pc with xp on it with the 311-u and the 2 wire gateway 2701 with a hp all in one scanner printer copier and I cant even connect to the print server to change the IP address into the range needed for the gateway 2701
Had same problem. Got it to work!!
I have DLink DP-311U and 2Wire Gateway router/modem 2701HG-B.
Solution: Connect DP-311U to router via network cable.
Then you can see it either with PS Admin or with browser http://192.168.0.10 should be default IP address of DLink Print Server. Set Connection Mode=Infrastructure, ESS-ID=2WIRExxx (xxx is your number of the router) - this is your network name, and wireless channel=1.
And the most important - change your IP Address to 192.168.1.xxx - xxx=choose a number over 64 if it's not taken already.
On your Gateway page: http://gateway.2wire.net/xslt?PAGE=J46&THISPAGE=A02_POST&NEXTPAGE=J46
Set Network Name=2WIRExxx, WIreless Channel=1, enable SSID Broadcast, Disable wireless network Security.
Once you get those numbers in, check connectivity with above programs with cable connected, or typing new print server IP address in browser. Then disable cable and check again. You should be able to see the box. Then connect print server to printer and make sure your printer settings on computer point to new IP address.
Posted on Jun 21, 2008
  • 38 Answers
I've run into this issue with some of my older linksys/dlink network equipment as well. These old devices just dont' support WPA encryption. I've gotten around this by just setting the wireless router back to WEP encryption. If this is not an option, then I recommend upgrading to a newer wireless print server.
Posted on Feb 10, 2008
I see that DLink has provided a firmware upgrade but I am not sure if it has WPA or not.
Posted on Apr 13, 2008
I have a same DP-311U print server and shared your problem.
After a day of searching, I think I resolve this problem by setting up a proper default gateway. It is very simple:
login to your DP-311U, say http://192.168.1.10 Click on Network tab, replace the default gateway 0.0.0.0  with 192.168.1.1 (the ip address of your network router) and save.
On your PC, Control Panel --> Printers and Faxs --> right click on the printer and select properties --> select  Ports tab --> click on Configure Ports --> in LPR settings, check mark LPR Byte Counting Enabled --> selec OK
You are OK to go. Good luck to you all.
Posted on Mar 31, 2009
Can't get tv to connect to new wireless modem, but everything else did connect
What is the model no of your 2wire wireless modem not all 2wire wireless modem can support cable tv might as well contact you cable service provider
just feel free to add comment if you have furthur queries:
can also call: AT&T ' Uverse
Call +1 800.288.2020
if your under the uverse service of AT&T
or try going to this site for more 2wire infomation
http://support.2wire.com/
Aug 12, 2011 | 2wire (2701HG-B) Wireless Router
I have purchased an AT&T 2wire 2701HG-B wireless DSL router to use in setting up a wireless network in my office. I have an external modem now that is part my AT&T internet service. Will the new...
The network appliance you're asking about is a modem with a wireless router built in. Basically, it's an all-in-one device. It will replace your already existing modem. It is a wise upgrade for any AT&T DSL connection.
Mar 12, 2011 | 2wire 2700HG-B Router (2700HGB)
Setup encountered an abnormal program execution
you got the wrong driver or you lost part of your driver you need to reinstall the complete driver again.
Jan 13, 2010 | D-Link DP 311U (DP-311U) Print Server
Att dsl internet on deskop and want wireless for my laptop
Yes you can buy a different DSL modem and that should not be a problem , then once you have the new DSL you just contact ATT and they will set up the settings on it...
Oct 09, 2009 | 2wire 2700HG-B Router (2700HGB)
For 2wire HomePortal® 1800HW. adaptor broadband connection ... I recently upgraded from my 2wire DSL to Uverse. ... Linksys wireless adapter won't auto connect to 2Wire. ... I thought to use it as a...
First thing to do here is to reset the unit by pressing the reset button for 30 seconds while power is ON , after that if still the same better to contact your ISP or the manufacturer of the device and have it replace..
Sep 08, 2009 | Linksys Wireless-G Broadband Router
I recently upgraded from my 2wire DSL to Uverse. My older laptop with the 2wire card and the home portal fins the new network but only runs at 11 mbps. Where my other laptop with the newer 2wire software...
That means the older 2wire card was a B model adapter, which can only run at 11mbps. The other laptop most likely has built in wireless or some other adapter in it that runs on the G model, which is 54 mbps. There is no way to fix this issue, other then aquiring a new wireless adapter for your older laptop.
Jun 29, 2009 | 2wire HomePortal® 1800HW Router...
Can I use AT&T 2WIRE 2701HG-B DSL to ant ISP?
look if u wish to go for verizon service,,they will provide u with a wireless modem as well,,but if u tell them that u hav a modem then they might configure this modem only,,both ATT and verizon are DSL service providers with PPPoE connections.the only thing u need is the username and passwrd from verizon which u have to setup on the first page of the 2wire setup page,,both the connections are dhcp based.so no other connection settings change required.But when u talk with verizon make sure u tell them of the 2wire modem
Moreover verizon has wireless broadband service which is actually a express card tat u have to put into your computer and u can go online anywhere u go within ur country{it works like a mobile phone}
best of luck,,keep me posted
May 14, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
2Wire 802.11g USB Wireless Adapter driver in qwest
try getting the drivers from
http://support.2wire.com/index.php?page=download
Dec 09, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
Can i connect a 2wire 2701hg-b with roadrunner cable internet ? I had the 2wire dsl with at&t but recently disconnected the service
It is possible but it may not work as a router (2 wire 270). The 2wired router only has a phone port and ethernet/usb for computer connection. So if you will connect the roadrunner modem to the 2wired, you can connect it to the ethernet port of the 2wire, but the 2 wire will not function as a router any more. It will work just like a wireless bridge. This one setup that you can.
May 02, 2008 | 2wire Wireless-G 802.11g ADSL Gateway
HP laserjet 1018 service
Have you installed the new drivers for your HP?
Personally, on all HP Printers, I use only HP products, mainly Jetdirect Print Servers, but you might try creating a TCP Port Printer (via your Printer Install Wizard) and use that. You only need to know the IPAddress of the DLink and the Drivers for the HP Printer.
Dec 04, 2007 | D-Link DP 311U (DP-311U) Print Server
D-Link DP 311U (DP-311U) Print Server Logo
2,409 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
