Question about JVC AV-65WP74 Rear Projection Television
Part number for the convergence board??
Or what is that board called?? i've already installed new IC chips and it didn't fix the problem. where do i get a new complete board??
  • Cazzzmo Feb 09, 2008
    what are the black rubber ''nipple'' or plug type of things on the lamp housing??? mine are basically collapsed. my retiring tech guy told me to check fluid levels on the guns/lamps . . . . is that what those black plugs or boots are??? are they filler holes or indicators??
  • JVC Master
  • 8,617 Answers
Its called the convergence board tri state may have it,
http://www.tristatemodule.com/index.html
Or PTS may have it
http://www.ptscorp.com/
Posted on Feb 09, 2008
  • Sonny Berry
    Sonny Berry Feb 09, 2008
    Yes the black plugs are the filler oles for the CRT coolant, but that would not give you a convergence problem. Did you check the resistors right next to the Convergence ICs for being open? Usually 1or 2 of them will go out when the ICs go out. They are locayed right next to the ICs Check those resistors with an oms meter see if any read open.
Red.yellow and green colors do not align. What is wrong? Isd it something I can fix?
If your picture has a 3D effect and you try to align with the cross hatches, then you have a convergence issue. I usually change both convergence IC's and any resistors that are open in the circuit. It requires unsoldering and soldering in the new convergence IC's. To locate the IC's, you can identify them as two side by side black chips about 3 inches by 2 inches with 18 pins each soldered to the board and on a metal heat sink. The numbers on them are identical and start as STK 392- 120 or 110. It is quite a job even for a skilled tv tech. After installing them and any resistor that is open, you will be able to align the cross hatches.
Jun 12, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Convergence problem
The convergence board is bad in this set. Samsung no longer has this board in stock. You will have to take the board out and rebuild it by replacing both of the STK convergence amp IC's These IC's are soldered to the printed circuit board. They will be standing up against a metal plate, called a heat sink. They are black in color and are about 2" by 3" . They have white lettering on them that start with STK and the some numbers. You get those numbers and go to mcmelectronics.com, enter the exact number of the IC and order two of them. Before you install the new IC's you will need to apply some heat sink compound onm the back of the new IC's. This heat sink compound is avaialable thruogh radio shack. Good Luck
Aug 23, 2007 | Samsung HCL4715W 47" Rear Projection...
My tv has blue shadows on all character faces and other objects
Hi Joyce,
If the symptom didn't cure by convergence adjustment through the remote control, this is an indication of faulty convergence board inside. You may replace the convergence IC's and some of the resistor around because its already gone bad. Also, consider bad solder joints in that area, it will do the same symptom like what you've encountered right now. Find it first and re-solder. If you don't have necessary tools and test instrument and can't do the job yourself, I would advise you to look for a qualified technician to isolate the problem.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
May 03, 2011 | Hitachi 60DX10B 60" Rear Projection...
Mitsubishi vs70803 green color gun out of alignment
Hi mopacdave,
If the symptom didn't cure by convergence adjustment through the remote control, this is an indication of faulty convergence board inside. You may replace the convergence IC's STK series and some of the resistors around because its already gone bad.If these parts replaced with new one, your unit will back to normal again. Also, consider bad solder joints in that area, it will do the same symptom like what you've encountered right now. Find it first and re-solder. If you don't have necessary tools and test instrument and can't do the job yourself, I would advise you to look for a qualified technician to isolate the problem.
Hope I helped you.
Have a nice day!
Apr 21, 2011 | Mitsubishi Televison & Video
I am trying to set the convergence on my 60inch projection tv however the red will not converge with the green on numbers 1,3,4,6,7,9..How do I fix that?
hello, the reason for this is down to the convergance ic at the back of the tv, 2 big black chips sit on a metal frame called a heatsink they are usually located behind the tuner board, also you will have to test the resistors and the 2 capacitors at either end hope you can get it repaired
regards
shaun
Nov 21, 2010 | Toshiba 55H70 55" Rear Projection...
Hitachi 46f500 46 in problem double picture end two collor
This is symptom of convergence output chips failure in rear projection tv, replacement of convergence output chips will fix the problem.
Chips/ IC replacement requires soldering work in circuit board, if you are not familiar with electronics stuff fixing an soldering work, call local tv repairman to help you.
Thanks.
Oct 26, 2010 | Hitachi 46F500 46" Rear Projection...
WS-55909 convergence problem turns now into F9A04 Fuse issue
I had this happen on my WS55909 about 2 years ago. I dont remember what the circuit id's for the fuses were, but out of 6 fuses on the middle board, the two in the middle were blown. I traced the circuit schematic and found that only the convergence IC could cause these fuses to blow. It sounds like you already put in a new convergence IC (the one with the big-*** heat-sink which probably also needs a fan) but you need to make sure all those fuses on that board are still good. After I replaced that IC, my TV still didn't work. I went and double checked for continuity of all the fuses on that board and one was blown (after checking all of them and replacing the IC). Replaced it and the TV has worked ever since. Total repair cost was 23 bucks. Professionals recommended that I would be better off just buying a LCD TV than fixing my rear projection TV, but I still dont think you can get one of those as big as 55" for only 23 bucks! ****. BTW, mitsubishi would probably tell you otherwise, but you don't have to use those "littlefuse" fuses. I soldered in a fuse-holder for a glass fuse of the same value (5amp 125v in my case) that can be purchased at radio shack. A fuse is a fuse. My TV never burst into flames.
Apr 06, 2010 | Mitsubishi VS-50501 50" Rear Projection...
Red green and blue arched horizontal lines on the tv
Hi, you`ve got a bad convergence circuit, involves un-soldering either 2 or 3 large IC`s (you didn`t post a model number) possibly 2-3 burnt resistors and possibly a chemical fuse. A lot of times it`s just the 2 or 3 IC`s, definitely worth fixing (I personally own a 53" Hitachi) If you try this yourself be sure you get original IC`s for the set, theres a lot of bogus chinese IC`s on the internet, acme-sales.net in Orlando Fl. is where I get mine, gl, video-tek
Jul 03, 2009 | Hitachi Televison & Video
Where to buy the convergence board of a 55PP9502
You can find a replacement auto convergence board for a model # 55PP9502 from this major Philips part distributor at the following link:
Philips 55PP9502 Replacement Part Auto Convergence Board
Feb 02, 2009 | Philips 55PP9502 55" Rear Projection...
HC-P4752W - IC Replacement vs Convergence Module.
The colors weren't lining up correctly on my HC-P4752W which is only about 30 months old. I did a little bit of research and got ahold of the people at http://servicemanuals.vstore.ca/ They recommended replacing the IC's as well as the IC resistors. I purchased the replacement parts from their site and made the repairs myself. I should mention that I didn't have any previous soldering experience. The repair was easy and a complete success. You may find replacement parts elsewhere for slightly cheaper but what you won't find is the prompt and detailed customer service that they provide. They gave me there # and said to call if I had any questions before or during repair. I took advantage of their services and got answers every time I called.
Aug 11, 2007 | Samsung HC-P4752W 47" Rear Projection...
JVC AV-65WP74 Rear Projection Television Logo
35 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
