check if the setting FORMAT CONVERT is with some numbers, please change for NONE.
This seting change the resolution from Printhead 200dpi or 300dpi or 150 dpi or none, none mins, if you have 200dpi printhead, print 200dpi resolution(small fonts). if have 300 dpi, print with 300 dpi resolution, if have 300 dpi(very small fonts) printhead, can print 150dpi(big fonts) if change this setting.
if ok, check the driver or your software.
1. Then download the file by clicking miscellaneous link under the file information section on the
opened page.
2. Install the downloaded file in your nokia phone by connecting the phone
with PC using data cabl.
3. Now open the "My Own" folder on your phone, & click on the
ZFontRemover file.
4. Go to Options & then select the "Remove All
Fonts" option.
5. Now Restart your phone.Get ur original fonts now....
1) Install in the memory card. 2) Create a folder in memorycard at data en name it fonts (when there is allready one don't bother, there should b a file there called fontrouter ini 3) make fonts (choose a ttf and copy them 3 times so u have 4 fonts. 4) Rename them in2:
nohindisnr60 nohindissb60 nohinditsb60 S60ZDIGI
Now for the hard part...
5) make sure your cell doesn't use the memorycard (otherwise the mass storage won't work).... Think about the message setting and change it in2 phone memory... 6) Connect with mass storage and rop the 4 files in the e:data/fonts 7) Unplug and reboot... 8) That's it....
When U want 2 change it, that's even harder. Because the new fonts R being used by the memorycard, the mass storage won't work anymore. U can't delete the without mass storage....
1) Use the app X-plore and search 4 the frontrouter.ini file in the same folder. 2) Edit the file and change the setting on the 12th row:
enable=1
in2 this:
enable=0
3) save it and exit... 4) Reboot (this will restore your normal font) 5) Now use mass storage (again everything exits on the memorycard) and rename the folder fonts (E:data/fonts) in2 font (so loose the s) 6) Delete the files in there 7) Reboot and that's it.
When u want 2 change them at point 5 U have 2 drop the new ones in there after U deleted the old ones. Then use X-plore again and edit the ini file and change it back 2:
