Question about HP Photosmart 2610 All-In-One InkJet Printer
2610 won't print
I have a hp 2610 and it won't print anything from my computer but will print a self-test report fine.
    Problem Solver:
  • 7 Answers
By self-test, I assume you are doing that manually on the printer. drivers downloaded/installed? right click on my computer, left click on properties, click on hardware, and then click on device manager. is there a yellow question mark by print drivers? If so, then need to load them from the internet or from your installation disk.
Posted on Feb 09, 2008
HP C6280 will not print self test diagnostic
Do you have an Anti-Virus program installed on your PC? If so, can you try and disable it before you print.
for more help visit CBR Tech Solutions
Mar 13, 2013 | HP C6280 All-in-One Printer
HP C5180 - test page prints fine, but when printing from any other program, the paper feeds to start printing, then the print job appears to be dropped. Multiple shutdowns of both the computer and the...
Try to perform this step as --->press setup menu on the printer front panel then scroll using the arrow key and select print report and then select self test report
if it does not print then the issue is with the printer hardware
Jul 30, 2010 | HP Photosmart C5180 All-In-One InkJet...
Missing text and top of some text is missing
* Perform Step 2 in the following HP web link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01446637&cc=uk&lc=en&dlc=en&product=3643612
If the issue persists, please print a self test page from the unit and verify whether the unit prints the test apge fine. Step are given below:
  1. Load U.S. Letter, A4, or legal size paper into the input tray.
  2. Press the Setup button.
  3. Press 1 to select Print Report , and then press 1 to select Self-Test Report .
  4. Press OK . The self-test page prints.
:) Dr Tony
Apr 20, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
How to print configuration page hp officejet g55
Printing a self-test page Method one: Print a self-test page from the All-in-One control panel
  1. Press the Menu button.
  2. Press 3 or use the arrow keys to scroll to Print Report , and then press the Enter button.
  3. Press 5 or use the arrow keys to scroll to Print Report , and then press the Enter button. The self-test page prints.
Method two: Print a self-test page from the computer
  1. Click Start and click Printers and Faxes .
  2. Right-click the appropriate product, and then click Properties .
  3. Click Print Test Page . The self-test page prints.
Oct 22, 2009 | HP OfficeJet G55 All-In-One InkJet Printer
Hp printers continue to jam
Print a self-test report Use the following steps to print a self-test report.
  1. Load plain white paper in the input tray.
  2. Press Setup , and then press 2 . The Print Report menu displays.
  3. Press 1 to select and print a Self-Test Report .
IMPORTANT! Try to print a self-test report after every solution even if the solution resolves the issue. Solution one: Clear the paper jam Follow these steps in the order presented to resolve the paper jam. Step one: Remove loose paper from the tray Remove any loose sheets of paper from the input tray and the output tray. CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism
Sep 08, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Missing lines and some lines have only half the characters
Solution one: Make sure the paper is appropriate for the print job Using the wrong paper for the print job might cause the colors to be faded or dull.
  1. Many papers have printing and non-printing sides. Make sure to load the paper with the print side facing down.
  2. Make sure the paper type is appropriate for the project. Use HP Premium or HP Advanced Photo paper for the best results.
Solution two: Check estimated ink level Use the following steps to check the ink level.
  1. From HP Solution Center, click Settings , and then click Printer Toolbox . The toolbox appears. NOTE: The toolbox can also be opened from the Print Properties dialog box. In the Print Properties dialog box, select Printing Preferences , click the Features tab, and then click Printer Services .
  2. Click the Estimated Ink Level tab.
Solution three: Check the print settings Use the following steps to check and adjust the print settings for the product.
  1. In the software program from which you are printing, click File , and then click Print .
  2. Make sure the product is selected from the drop-down list, and then click Properties or Preferences .
  3. Click the Features tab, and then select the print quality and paper type settings that match the print job.
  4. Click OK to accept the new settings.
  5. Click Print to send the print job.
Solution four: Check for defects using an extended self-test report Extended self-test reports identify specific print quality issues. Use an extended self-test report to determine what is causing the issue. Step one: Print an extended self-test report Use the following steps to print an extended self-test report.
  1. Press and hold the power button (c01346625.gif ), and then press Cancel .
  2. Release both buttons. The extended self-test report print
Jun 18, 2009 | HP DeskJet F4280 All In One Printer InkJet
Hp5510--will fax, bukt when it prints, the sheet is blank.
First print a standalone test page.
Push Setup >> Print reports >> Self Test report.
If the page prints fine. Reinstall the software. It will work !!
Best Of Luck.
Dec 01, 2008 | HP Officejet 5510 All-In-One Thermal...
C3180 will not print as error occurs even when installed
Try printing a manual self-test page:
1. Press and hold Cancel on the control panel.
2. While holding Cancel, press Start Copy Color.
The self-test report prints, containing the serial number and service ID.
This should tell you if it is a problem with the unit itself, or with communication between the unit and your computer.
Feb 19, 2008 | HP Photosmart C3180 All-In-One InkJet...
Slow Printing
Hi, The slow printing issue can occure even if the cartridges are out or low in ink try to check the print function by the stand alone unit by printing a self test page Here are the steps to print a self test page: On the front panel of the product, press Menu (or Setup) . Press the Right Arrow until Print Reports displays, and then press Enter, Start, or OK . Press the Right Arrow until Self-Test Report displays, and then press Enter, Start, or OK . If the self test page takes less time to print and if all the color blocks and black block print fine the ink level are fine. if the time for self test is also more try to clean the cartridge contacts and replace the cartridges if needed this will fix the issue. If the printer works fine as stand alone self test and copy try to performe the steps in the below webpage: ========== http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00093466&lc=en&cc=us&dlc=en&product=2512010&rule=10185&lang=en ========== If the issue is still un fixed try to set the print directly settings in the printer properties Click on start >> control panel >> printer and faxes >> there look for the HP printer icon with the check mark and right click on it and select properties and then click on advance tab and under it select the print directly to printer and click on apply and ok to save the settings. Once done try to print and check with the issue. Hope this will fix the issue. Regards, Barret.
Sep 03, 2007 | HP PSC 2175 All-In-One InkJet Printer
HP Photosmart 2610 All-In-One InkJet Printer Logo
99 people viewed this question
Ben Johnson
