Question about Pioneer AVIC-X1R CD Player
Faulty screen I can see the image if i shine a torch at the srceen but i can't get it to illuminate. has the lcd bulb blown if it has one, do i need a new screen, has my light sensor gone faulty? whats it gona cost me? or do i need a new screen.......help
  • 78 Answers
If it's just the illumination thats gone it's probably a surface mount fuse or the inverter circuit or the flexible pcb, I would advise you to bring it to a pioneer service centre and I would guess you should expect to pay about £75 + vat
Posted on Mar 17, 2008
TV turns on but just a black screen
hi does it have sound, if it's a led type shine torch on the screen see if you can see an image, if you can the led in the panel may have blown, thanks
shaun
Feb 10, 2017 | Televison & Video
Screen goes black but sound is good.
This sounds like the inverter which powers the display fluorescent has or is failed/failing. If you take a torch to the blacked out display can you see the image faintly? If so the unit needs repairing.
Mar 12, 2015 | Televison & Video
No pictures showing anymore
sounds like the projection bulb went. behind computer monitors and lcd screens is a bulb that shines a light threw the screen to allow you to be able to see the image, try opening the unit to see if the bulb is on while unit is on, if not try shining a light threw the back of the screen to see if you can see the image. bulb may need to be replaced.
Dec 15, 2013 | Sunpak (SDPF-070AW-0US) Digital Picture...
Hello, would like to ask about my hanspree tv, 2 weeks ago the power just stopped so i opened it up (left it 24hrs with no power and had ground strap etc) and 2 capacitors had blown. I changed them and the...
The backlight controller is most likely faulty. It could be bad capacitors again, or the inverter board itself may need to be repaired - possibly faulty inverter(s). Try shining a torch close to the screen and see if you can see anything on the screen.
Mar 04, 2011 | Hannspree HANNSwing 32 in. LCD Television
My sdm-hs73 moniter the power is on but screen is blank, what could be wrong
First check brightness and contrast settings.
If all good could either be your lcd back light has gone or the inverter. To check if its the black light shine a torch through the back of the screen to see if you can see a slight image on it, if you cant see anything the inverter board is faulty and to repair needs to be changed.
Jan 21, 2010 | Sony SDM-HS73P 17" LCD Monitor
My TV image went blank, but the TV stayed on. What could it be.
The exact model number is necessary to determine the exact parts your TV has. Some models has suffixes in their numbers to indicate they have some differences in their parts. For example, the 42LG30 is different from 42LG30DC, 42LG30-UD and so on. But generally, there are three parts that has a direct connection with the dimming and illumination of the screen. These are the T-CON board or LCD driver, backlight and inverter or ballast. The T-CON board is responsible in driving the LCD panel to produce the appropriate video or image. The inverter or ballast provides power to the backlights to illuminate the screen. If one of these fails, you will not be able to see any image or video on your screen.
The T-CON board is bad when there's a glow on your screen indicating that the backlight is on but there's no video or image. In short, the screen is blank.
If the screen is black, no glow, grab a torch and shine it on your screen. You will be able to see a faint image if the T-CON board is good. This indicates that the backlight is off. Either the inverter/ballast is dead or the backlight itself is busted. But usually it's the inverter/ballast that has failed. You can tell that the backlight is busted if the TV is old enough that the mercury vapor inside the tubes has depleted.
The T-CON board and the inverter or ballast are not serviceable and must be replaced completely if faulty. Replacing these boards can easily be done. Feel free to inform me if you find which of the above is the root of the problem to guide you in the fix.
Dec 04, 2009 | LG 42LG30 42 in. LCD HDTV
Hello, LCD Problem. I have sound but no image. Black screen. No access to the configuration menu. Someone can help me ??
I think your LCD TV lost back light that is why you have sound but no picture to see it as LCD TV requires back light to present picture on its screen.
Please intimate model and brand of your LCD TV to provide you more info.
Sep 17, 2009 | Televison & Video
Power light comes on but screen will knot light up
shine a torch onto the screen when it is running. if you can see the images then your backlight has gone and you need to replace.
Feb 26, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
No picture just sound
- try to on it again and observe how long will it takes and it will lost the display again, then explain it agian to the technician
Dec 10, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
IR 5000 No Back illumination for touch panel
Most likely you will have to just replace the LCD display pannel or Touch Screen PCB. It does have a lamp, but I did not see a part number for it. You may be able to find a used or rebiult one on line and have a tech install it for you, to save your self some money..
Aug 27, 2008 | Canon imageRUNNER 5000 Copier
Pioneer AVIC-X1R CD Player Logo
127 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
