Question about Dryers
AEG condenser dryer - plastic bracket for contact brush
Hello, I'm new to this forum.
I have an AEG condenser dryer Lavathrem 5770. It didn't heat and the drum didn't turn, but I have replaced the belt - I bought the Service Manual from the internet to assist. I now have a new problem.
A plasic bracket near a brass brush at the top of the machine is missing.
The Service Manual doen't descirbe how it is mounted or what it does, and the service diagrams don't help.
What does the brass brush at the top of the machine do? Is it meant to make contact with the stainless steel strap which is insulated from the drum? If it is meant to make contact then I can try to make something, or if anyone knows the part number of the complete plastic assembly (from brush to metal cross piece) then I could order it. I'm just not sure what it does.
Thank You
    Sergeant:
  • 236 Answers
The brush is a sensor to check for the dryness of the load(for a basic description) it should run on the track you have mentioned.
Posted on Feb 16, 2008
Hi. Got a Aeg T56840 dryer with an E50 error. So It might be the carbon brushes that needs to be changed. But How do I get to the motor? Top, side, back or button of the machine? ? Hope you can help
side off as explained by one person on a forum
so some questions to be asked
does the drum turn
will it turn if you help it
it is unlikely that it will have brushes as most electric appliances use induction motors which are brushless
e50 is the machine sensing the drum failing to turn
it could be a failed start/run capacitor if the drum turns when you help it start
the capacitor is a 6uf capacitor mounted on the motor ( try e-bay)
the fault also may cover not heating
try resetting the machine by disconnecting from the power point for 15 minutes then starting it again
Dec 17, 2015 | AEG Washing Machines
My aeg lavatherm 56600 acts strangely. The timingclock seems to go too fast, and the waterpump rund continously Even when floatchamber is completely empty. Heating works seemingly perfect, and sensor brush...
It looks like that is not correct Conductivity sensor (two brushes; wiring and electronic). I'd like to know if you replaced the both carbon brush (6), which makes contact with the drum shaft is situated in the protective housing (7) of the drum shaft and carbon brush 3b.
25316337-hf2jxxovvq5cn05mugly0fcq-5-0.jpg The last alarm code memorized can be displayed even if the appliance is in normal operating mode (e.g. while the drying
programme is being performed):
- Press button start/pause and first nearest button simultaneously for at least 5 seconds: the display shows the last alarm. The alarm sequence continues to flash as long as the two buttons are held down.
The appliance continues the cycle while the alarm codes are being displayed. If the appliance is in programme selection mode, the options previously selected are stored in memory.
However, your tumble dryer is smart and if something is wrong it should be displayed by the alarm codes.
Dado
Dec 10, 2014 | AEG Dryers
Bissell 5770 Brush Issues
Hi their... By touching accidently the screw driver ok circuit board that may be caused of a short of any kind fues on the board or small resistant... Please contact to electronic technician to repair it rather than purchasing new board... Thank you
Oct 24, 2017 | Bissell 5770 Healthy Home Bagless Upright...
Drier heats up in beginning of cycle but after that never heats up again during that same cycle.
While you didn't say im suspecting it a gas heated dryer??
If so here is whats wrong with it;
The reason your gas heated dryer starts off heating ok,but a part way through the cycle it is no longer heating as it did when it started,is beacuse the coils that open the gas valve are getting hot and breaking down when they are warm. At start up of cycle the coils are cool,but when the dryer heats up as it runs the coils that are weak can not handle the heat and do not open the gas valve. Replacing the gas valve coils with fresh,strong ones will open the gas valve the entire duration of the drying cycle. All appliance manufactures use the same exact gas valve coils and label them with their unique part number. Having been in the service business i know they are all the same and the part number for the least expensive gas valve coils is 279834
They can be purchased at your local appliance parts store on online at
searspartsdirect.com
repairclinic.com
apwagner.com
apdepot.com
midwestapplianceparts.com
To replace the coils,remove bracket over them(dont worry about where it says dont grip thats for when dryer is plugged in) unplug them and install new ones,that bracket has notches in it and the coils have tabs that inter lock so they position them self exactly where they fit.
This is what the coils looks like
Aug 27, 2011 | Maytag Dryers
Our tumble dryer is not blowing hot air only cold wot could the problem be ? its a creda simplicity condenser dryer - tc 22 cw
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 24, 2011 | AEG T58840 Dryer Electric
Got new tmbledryer week old no digital display checked fuse on plug
Cheapest price search results for AEG T58840- Tumble dryer- Technical details, features, compare prices, AEG T58840 buying guide, reviews, tests, d and buy a AEG Lavatherm T58840 Electric Dryer from 419 at Deal Time UK.See images, features, check best price and 2 reviews and ratings by people who have bought this Aeg T58840: "A lot quieter than my old tumble pare prices for the AEG T58840 Washer d impartial reviews and buy online for speedy delivery only denser tumble dryer with Silent pare the UK's best prices for AEG T58840 and other Washer-Dryers from 100s of online shops.
AEG T58840 AEG Tumble Dryer Condenser, FREE DELIVERY, Buyers and Sellers offer the widest range of domestic appliances from top of the range to budget items at the most.7Kg Drying Load, Condenser Dryer, Sensor Drying, Large LCD scree, 20hr Delay rn everything you need to know about tumble pride ourselves on our customer service and the best prices on internet for the AEG Appliances Tumble Dryer Condenser Freestanding T58840 from BHS pare prices from across the web and read product reviews on AEG Lavatherm t58840 compare prices on Aeg t58840 from online T58840 Condencer Dryer- 7kg Load in White.
T58840: 7Kg Condenser Tumble Dryer in White: 433.97: AEG: T88840: 7Kg Condenser Tumble Dryer in White: 535.00: AEG: T35850: Vented Tumble Dryer: 264.97: AEG: Electric Shop supply AEG T58840 7Kg Condenser Tumble Dryer in White from leading manufacturers at discounted T35850 Vented Tumble Dryer- Special T58840 review, price comparison and where to buy online at Compare Store Prices UK for cheap T58840 White Freestanding condenser tumble T58840 Condenser tumble Price: 448.85.Tumble Dryer Models from AEG: T35850; T58860; T88840; T58840.
Aeg T58840 Condenser Dryer, read the latest user reviews and compare prices on Aeg T58840 Condenser T58840 review, price comparison and where to buy online at Compare Store Prices UK for cheap T58840 Condencer Dryer- 7kg Load in T58840 from Chantry Digital AEG 7kg Load Condenser Dryer with White T58840 Colour WhiteManufacturer AEG7kg Drying LoadCondenser DryerSensor DryingLarge LCD Screen20hr Delay StartCondenser duct information and details for AEG Lavatherm T58840 Electric AEG T59800 Dryer is in stock at several UK k the green box and well make sure that more people get to.
Find out more about the amazing AEG Lavatherm T58840 tumble dryer condenser in p with dryer hotpoint tumble problem on AEG T58840 Condenser Tumble Dryer Electric and free tech support for dryer hotpoint tumble d out more about the amazing AEG Lavatherm T58840 tumble dryer condenser in rything you want to know about the T58840.491.00: NEW AEG T58840- MANUFACTURE a better deal by comparing prices on AEG T58840 Washing Machines to save money online and guarantee Christmas T58840 3) Tumble Dryer Spares and T58840 3) Parts- Page 2- Belt, Door, Drum, Filter, Seal, Heater, Hose, Knob, T58840 Tumble Dryers Condenser In White Aeg The number one appliance specialist in the UK.
Condenser Sensor dryer
Large LCD Display
Sensitive Option, Leisure Programme
21 programmes including Microfibre, Jeans, Bed Linen
Easy Iron, Extra Dry, Storage dry, Hand Iron
Machine Iron, Intensive Dry, Extra Dry, Wool Care etc
Large 36cm porthole opening
Interchangeable door hinge
Manual timer up to 40 minutes
Stainless steel drum with Internal Light
Drum Light
please comment on these on how helpful.
Dec 21, 2010 | AEG T58840 Dryer Electric
AEG Electrolux Lavatherm 57800: Push a program button, Machine starts for 3 - 5 seconds, Then stops and timer is on 0.
try cleaning the drum contact on the rear of the machine. It is a carbon brush that contacts the drum spindle. It can get covered in carbon from the brush.Remove the plastic cover containing the contact brush, clean out all carbon dust and lightly sand the drum spindle to remove any surface build-up and ensure a good electrical contact then reassemble.
Nov 27, 2010 | AEG T57800 Electric Dryer
How does tumble dryer work?
The heated air inside the dryer is not expelled but reused. The drum is contained inside a closed area. The heat is contained inside the dryer. No ducting to outside is needed. The moisture is removed from the heated air through a condenser before re-entering the drum. Sorta like a giant self-contained dehumidifier. As the water is removed from the clothes, it puddles up into a drain pan which periodically needs dumping. Fancier models pump out the water to standing drainpipes. This design saves energy.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 11, 2010 | AEG T58840 Dryer Electric
New element fitted still only top hafe of element heating
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
yuyu
Dec 17, 2008 | AEG T57800 Electric Dryer
Condenser Dryer turns but no heat
Check with multi-meter for power on the heating element's tags (115/220V). If it does get power,you should replace the heating element. In case of no power- you should replace the thermostat. Good luck!
Aug 21, 2006 | AEG T57800 Electric Dryer
Open Questions:
Kenmore Elite Dryer HE4 Quietpak 9, has 4 dim lights showing on the console display but won't start or respond, I have bought brand new and replaced all sensors. Replaced heating element. looked like the original heating element. Pack came with new sensors. I did not test with a multimeter. My plan is to measure continuity on all the old sensors. Then do the same on the new ones. The electronic board looks good, does not smell burnt or old burnt smell. I cleaned all the lint in this dryer but unfortunately the motor has some lint in it which I surfaced cleaned. The only way to get to the motor is to remove the drum. So far I have soent $40 on all parts and a week works of troubleshooting as a novice. On the main display read, it shows two small dim lot red lines, wish I could send you a picture. Also when the fuse is off I plugged in the dryer and all the lights turned on normal. All looked in working condition except of course it did not turn on, I have not replaced the switch and with the new fuse, by the way, I bought 5 to 6 of the same fuses thinking I was burning them, that's why I bought a multimeter to retest them to see if they are not burnt. When I plug in the fuse it goes black but the door light works. I have held down the start button, nothing, held down the cancel button, nothing, I have done the crazy push all buttons even shook the machine a bit just in case something was causing whatever myth I was conjuring. I am about to give up and just buy a used one from someone else but I think I can fix this, it should be very simple to fix.
Aug 20, 2018 | Kenmore Dryers
Dryers Logo
180 people viewed this question
Top Dryers Experts
Marvin
Marvin
