Question about JVC AV-65WP74 Rear Projection Television
How do you pop-out the screen for cleaning? - JVC AV-65WP74 Rear Projection Television
  • Cazzzmo Feb 09, 2008
    Drummernick - do you know more about this model?? I have convergence issues that I've yet to post on this forum.
    yes, I've already both of the STK-110 ''chips'' professionally replaced but that didn't fix the problem. Its actually worse now in that both red and blue wont line-up whereas before it was only the red gun. I took the board to my local TV guy to have him do the soldering (i bought the new STKs on ebay, they might've been el cheapos). He said he didn't see any resistors burnt out or anything. I suppose you're right. The whole board needs replacing. Don't get any signal to the red beam anymore either. any suggestions? where to get a board?? my TV guy is retiring . . . he basically shut the doors last week so he's not really an option.
    Master:
    Sergeant:
  • 440 Answers
Uslay insde has screws holding it in then slide up
Posted on Feb 09, 2008
  • nick helpap
    nick helpap Feb 09, 2008
    YA WELL THAT USALLY IS THE BOARD I WOULD GET NEW ONE thats best bet thx nick
  • nick helpap
    ya get newer young guy in ther to work on new stuff for u form good tech place gota cheak parts dial it in form inside
My volume control keeps popping on and off my screen when i use my Logitech key board cover
Have you popped off the volume control key and cleaned out any debris? It's possible the key is partially depressed and the cover is finalizing the press.
Feb 22, 2015 | Logitech Computers & Internet
How do I clean a Remington Shaver
If micro screen style, pop off the screen and use included brush to clean out all the beard hair. Spray with shaving lube then pop screen back on. That's it!
Aug 25, 2014 | Remington Health & Beauty
Screen/computer messing up
I assume you have a touch screen? but the keyboard seems to be the problem..(sticky keys) so might try a different keyboard and it wouldn't hurt to clean the Touch screen with an approved cleaner
Sep 24, 2013 | HP TouchSmart Computers & Internet
Screen pops up laser lens needs cleaning How do I do this
how old is your computer, if it's over a certain age, it may be a timed pop up that's just a reminder to clean it, see your other post on the subject and try my suggestion. please only create on thread per problem in the future :)
Jul 02, 2012 | Compaq Computers & Internet
I switch on my pc (window xp) this evening, and my pc auto restart with blue screen pop out. its say some error with name 'fatal system error'. already clean disk, de-fragment in the safe mo
turn on computer,press F* repetedly until screen shows up wth options
safe mode
safe mode with networking etc...
in dat screen select option "most recent good configuration"
and enter..next window select windows xp and enter..thats it.
after u log in.clean whole system with good virus scanner for viruses,malware,trojans all
May 19, 2012 | Computers & Internet
Menu screen pops on and off rca 52 wide screen hd
Dirty contact switches, clean all the contacts on front of TV with contact cleaner.
May 01, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Toshiba 52 inch Screen
the outer trim just pops loose behind that there are several screws the plexi is held in by those crews i believe so once you take the screws out you can clean between the two screens
Feb 04, 2009 | Toshiba TheaterWide 46HM94 46" Rear...
Removing the protective screen on our Pioneer SD-532HD5
Pop the bottom front cover off (that is over the speakers) first. This will expose 2 brackets that hold the moulding around the screen in place. Un-screw the brackets enough so you can get the moulding off and take it off. Once the moulding off you will see the brackets that hold the actual screen in place. Loosen these brackets and VERY carefully remove the screen (it will wobble and bend so I would recommend 2 people do this). Lay the screen down on a soft surface that will not scratch it. Clean and re-install screen, tighten brackets, re-install moulding, tighten brackets and pop the speaker cover back on.
Nov 11, 2008 | Pioneer SD-532HD5 53" Rear Projection...
How do i clean my screen
  CRT Rear-Projection - Before you can begin cleaning, you need to determine if you do, or do not have a screen shield. A screen shield is a hard plastic cover over the front of the TV screen. If you can't tell, give the front of the TV a light tap. Another way to tell is to check for ridges in the screen area. If you can feel ridges on the screen, then you do not have a screen shield. Rear projection TVs without a screen shield require a special kind of cleaner and rag. These are available for purchase at your local TV service center. Those that do have a screen shield should be cleaned with a dry or damp soft cloth. If it's extremely dirty, a mild soap may be used. Do not use paper products, such as paper towels, to clean the screen shield. Paper products can easily scratch the surface of the shield. Screen shields can have a tendency to streak while cleaning. If this happens, use a dry cloth and buff the screen in a small circular motions.
Oct 29, 2007 | RCA P52926 52" Rear Projection Television
Dirty screen but it is behind the outside screen.
The front screen with the frame does remove from the cabinet giving you access to the mirror and CRT lens. Remove the speaker grill,remove the four screws on the bottom of the frame, then working underneath a corner proceed to pop the rivets holding the frame to the cabinet. It will seem impossible at first because you have to use a lot of force to pop each one out.When reinstalling,a rubber mallet may help popping each rivet back in (I am not kidding when I say they are tight)
Oct 24, 2007 | Hitachi 50UX57B 50" Rear Projection...
JVC AV-65WP74 Rear Projection Television Logo
21 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
