Question about Fellowes DM15C Shredder
DM15C stops after 4 seconds, open bin light comes on
My DM15C shredder stops after 4 seconds, not quite enough to finish one sheet. The red "bin open" light then comes on. Turning off the main switch and then on allows it to run for another 4 secs. Alternatively pulling out the bin and replacing it also allows another 4 seconds of shredding. This can be repeated indefinitely. There are no jams. The shredder is not warm and makes no strange noises. Shredder has shredded less than two bins worth so it is not worn out. Grateful for suggestions.
  • 15 more comments
  • bfran Feb 13, 2008
    Same exact problem, I have taken it completely apart and cleaned.
  • Anonymous Mar 17, 2008
    I have the same problem and have no solution yet. 03/17/2008. Ralph
  • Anonymous May 05, 2008
    same
  • Anonymous May 16, 2008
    I have the same problem - cleaning does not help at all
  • Delta Brad May 30, 2008
    I am having the same problem and cleaning the sensors did not work. Can the sensor be replaced or at least bypassed?
  • Anonymous Jun 03, 2008
    same problem; cleaning doesn't help
  • ZAKARIAH Jun 05, 2008
    SAME PROBLEM MUST BE A DESIGN FAULT !!!
  • Anonymous Jul 16, 2008
    same problem
  • crahrick Jul 24, 2008
    stops and red light comes on no reason
  • sailknot Aug 25, 2008
    Same problem.
    I don't see the solution displayed???
  • irbrenda Jan 03, 2009
    Exact same problem today!
  • Anonymous Jan 04, 2009
    same problem
  • mjkenger Feb 21, 2009
    I have the same problem, but cleaning the sensors doesn't fix the problem.  Any help would be appreciated.
  • Paul Stawski
    Paul Stawski Jan 23, 2014
    THANK YOU! After just a couple minutes it's working like new!
  • Michael Schroeder Apr 18, 2017
    If that does NOT work, the sensors are bad. They are no longer made. Pop the top off, takes a good hard pull as stated above, turn the motor blade unit upside down and remove the 5 screws holding the grey top on. You will see the wires for the sensors going into a connector that then goes to the circuit board. Disconnect the sensors, and then CUT the connector off that comes from the circuit board. Strip back and twist the two BLACK wires together. Use a wire nut or clamp fastener, or simply twist and tape with electrical tape. This bypasses the sensor. The unit will run fine, and the thermal overload etc. is not effected. The sensors you bypassed are for the BIN FULL shut off, so you will have to check the bin yourself, but this fixes the issue.
  • Jonnika Benjamin
    Jonnika Benjamin Dec 19, 2017
    Nice! I cleaned the remnants from below the bin so it could close completely and blew air on the sensor and now it works again:)
  • Mike Scir Mar 09, 2018
    Thank you very much Michael Schroeder, soldering the 2 black wires together fixed mine, it is actually usable as a shredder again. It was a bit unwieldy as a paper-weight! Thank you for the clear and thorough instructions!
I lived with the problem for 6+ Months -- drove me NUTS -- Today, I called Fellows -- Spoke to "JoAnn"... She said this works 80% of the time...
Pull out the bin -- put your foot inside to hold the shredder down -- pull up on the top of the shredder -- you WILL hear a POP as the plastic top disengages from the bottom but TRUST ME THIS IS OK! -- take off this top section (which houses the blades) -- flip it over -- you will see 6 screws total but it is the sets of 2 screws close together to focus on -- right next to the screws you will see a tiny glass sensor -- use a q-tip and alcohol to give them a wipe -- press the top back on -- bin back in -- you are DONE -- This took me less than 1 minute and it works as it did the day I got it! Go shred something!  :)
Posted on Jan 05, 2009
  • Paul Stawski
    Worked like a charm! THANK YOU!
This solution worked great! Thank you
Posted on Apr 15, 2008
    Scholar:
  • 102 Answers
The machine will autimatically run for 3-4 seconds every time you turn it on this is normal after that it is ready for shredding. This is more than likely a problem with the bin full sensors located on the underside of the shredder head. Remove shredder head from casing and turn upside down, you can find the sensors by locating the little bulbs on each side of the opening held in by two screws on each sensor. Clean off sensor bulb with a Q-tip dampened with rubbing alchol. If this does not solve the problem you more than likely have a sensor that has burned out.
Posted on Feb 22, 2008
I emptied the shredder and now the red overheat/door open light comes on when I turn it on. will not allow me to shred anything. please help!
There is an interlock that prevents your shredder from operating without the bin in place. Something may be stuck inside, preventing the bin from closing the interlock. There also could be a shred of paper preventing operation.
Feb 17, 2015 | Compucessory CCS60076 - High Security...
At first the shredder would only run for 3-4 seconds, then quit. Turning the rocker switch off, then back on, would cause the shredder to run another 3-4 seconds, OR pulling the collection bin out, then...
could be the sensor needs cleaning or is now defective. Use a q-tip and insert it where the paper goes. Look for a small button which senses the paper and triggers the stredder motor.
Mar 26, 2012 | Fellowes DM15C Shredder
SHREDDER INDICATOR KEEPS COMING ON WHILE SHREDDING
look for two LED lights where paper falls into bin and wipe them off, but the sensors could be faulty as well. I have seen both.
Nov 11, 2009 | Fellowes DM15C Shredder
The basket full light will not go out
YOU WILL HAVE TO HAVE SENSORS REPLACED
Sep 15, 2009 | Fellowes DM15C Shredder
Short run time and redlight, stops running Fellowes DM15C
There are two sensors (look like little light bulbs) on the top part of the shredder at either end of the blades. If you pull out the drawer and turn the shredder upside down you will see them. They get dirty telling the machine that it is full and needs to be emptied. Clean the sensors off with an alcohol wipe. If cleaning them does not work you need to replace the sensors.
Aug 25, 2008 | Fellowes DM15C Shredder
Novitech shreader
I have the Fellowes shredder oil. The bottle has ABSOLUTELY NO instructions on how to use it.
I used to drizzle oil in on the cutting blades through the feed slot on top, grumbling all the while because it was so messy.
Then I got this tip: Once a week squirt oil on sheet of paper that will be shredded. Do 3 or 4 sheets.
Or do it each time the machines stops for its cool-down period.
I run the oily shreds into a separate bag because I recycle my shredded paper and want to keep it clean.
Jul 31, 2008 | Fellowes DM15C Shredder
Novitech shredder
After clearing the jam (with the unit unplugged!), let the unit cool completely, then try using it again. A notice on the nameplate inside my unit says: "2 min on/4 min off." Apparently, a thermal cutoff keeps it from overheating by automatically preventing continued operation that might otherwise melt the parts. So heed the directions. I had the same problem with my NoviTech Model PS-026/B2 crosscut shredder (max: 5 sheets, 1 credit card). Also, make sure the motor mechanism is seated square and flush on the bin. I tried testing it out of the bin, and the green ready light wouldn't come on -- for a good reason: safety. (I still have all of my fingers, thanks to that!) Hope this helps.
Feb 12, 2008 | Fellowes DM15C Shredder
Fellowes DM15C Shredder Logo
1,185 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
