Screen has horizontal lines and fading
About a month ago my screen developed a horizontal line across the bottom. If I touched the screen in that area it would go away, but it would always appear again if I didn't touch the screen. My screen has now started to fade away and I'm not able to see anything. If I touch the screen, I can see what's on the screen. How do I fix this? Thanks.
    Master:
    Sergeant:
  • 440 Answers
Bad screen u have to get new screen take it apart from top side pop off top panel 2 screw on back use flat head unscrew screen get new one one ebay ect ok cheak cables in ther also thx nick
Posted on Feb 09, 2008
  • nick helpap
    nick helpap Feb 09, 2008
    not hard to do and if u get screen ill walk u throw it
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
More results from www.cnet.com
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Dec 19, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
Samsung TSL2793HF - Slight Right Side Pincushion and Horz Line Bottom to Top Until the TV Warms up
Yes, this is rare but I have seen it before--not fixable if it is what I think it is----It is what is called a Dome effect---the shadow mask in the picture tube is actually contracting and or expanding depending on temperature---
Directly behind the phosphor coating (the stripes that you see on the screen) is a metal screen--the holes or perforations in it line up with the stripes on the phosphor screen.
Some masks either have a material or a defect causing the dome effect----Not likely to be anything else---a Pin amp problem will not usually act the way you describe but a shadow mask inside the picture tube will act exactly that way.
Dec 02, 2012 | Televison & Video
Our Toshiba Regza LCD TV has developed a thin white vertical line down one side and a green horizontal line across the middle. The bottom half of the TV screen then comes and goes in muted and faded...
All Plasma and LCD TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken . Good luck in solving the problem....
Aug 06, 2011 | Televison & Video
Line across screen
scane for virus and reinstall the operating system
May 30, 2009 | Computers & Internet
Horizontal lines across the top 3 inches of picture
Hi
what line started? from Left to right? or from top to bottom?
Thanks!
Nov 28, 2008 | Philips 32PT6441/37 32" TV
Canon image runner 3300
Most likely something on the glass. Even a small speck on the glass will cause a horizontal line across the sheet while using the top feeder. Otherwise it would be the drum unit or a scratched fixing film.
-jen
Oct 29, 2008 | Office Equipment & Supplies
Horizontal lines on Screen
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 14, 2008 | Gateway FPD2275W LCD Monitor
Line across my laptop screen
The graphics part of the laptop is going out. Recommend just replacing the laptop, it would be cheaper.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Jun 10, 2017 | Computers & Internet
Green horizontal lines across screen
try adjusting the green screen control. remove the front bottom panel of the tv by removing any screws holding it in place. gently pull of the front panel, there are gromets holding it in place, you will be able to gently remove the front, just make sure you get all those screws. now reove the small wodden or plastioc panel. now you will see the screen/focus assy. check to see of the screen controls are the top 3 or bottom 3. adjusted the center screen it's the green one, the other 2 are the red & blue. it is best to adjust in a dark room where the lines will show up easier. good luck
Dec 19, 2006 | Hitachi 43FDX01B TV
Green Lines Horizontally
yeppers its a g2 control on the flyback thats gone or drifted out of alighnment or the flyback its self.Try turning the g2 control dowm till those lines fade. If they wont go away then you need someone to check the Picture tube or its componets driving the crt.
Mar 26, 2006 | GE 31GT740 31" TV
Computers & Internet Logo
427 people viewed this question
Alun Cox
David Payne
David Payne
