Question about Compaq tc4400 Tablet PC
Hp tc4400 s-video not working
I've conntected it to my TV, and I've tried two different s-video cables.
The manual states that function+F4 will swap between displays, but the video driver doesn't seem to recognise that the TV is attached to the laptop. Fn+F4 only flashes the laptop display once and doesn't let me switch through the display options like it normally does when the laptop is hooked up to an external display through the DSUB output.
There is however, some kind of signal going to the TV as when it's on the AV input, even though the screen is still blue, it flickers when I wiggle the cable at the back of the laptop.
Any ideas?
  • 1 more comment
  • largepiece Feb 09, 2008
    Are you saying the S-video output doesn't actually work to a TV?
    I only want to hook it up so my movies are bigger. I don't mind about blurry icons.
  • largepiece Feb 10, 2008
    So would you expect the s-video to not work at all on a regular TV?
    As in, there's no picture (just a blue screen)? Not even a blurry picture?
    Righto, thanks. :)
    Master:
    Sergeant:
  • 440 Answers
Well cuse u nee dto use vga output to a vga pc ready tv only ok s video looks horbaily dontw ork well wont show all icons ok
Posted on Feb 09, 2008
  • nick helpap
    nick helpap Feb 09, 2008
    ya i know need vga tv not even s video will look right bvery hard to control its output not worth it
  • nick helpap
    nick helpap Feb 10, 2008
    yes not made for that teriible out to use need vga and a tv that has that ready in put or hi end ati card with hdmi outs ok
How do you turn on HDMI?
I work at a company where we design a lot of boards that have HDMI interfaces on them. We have seen cases where there is no display and after swapping out the HDMI cable, the display comes on. HDMI signals can be very tricky in that the length of the cable or whether or not the cable has ferrites integrated into it can mean the difference between a blank screen or video displayed. Try at least one other cable type to see if the problem goes away.
Apr 18, 2016 | Tablets & eReaders
Compaq tc4400 suddenly turned into non tablet pc (pen & touch gone)
http://www8.hp.com/us/en/support-search.html?tab=1#/qryterm=compaq%20tc4400&searchtype=s-002
this is where your find the moel drivers for tablet , there are two available , so please read before installing.
Nov 27, 2013 | Compaq tc4400 Tablet PC
When turning on my HP Compaq tc4400 Tablet PC a blue screen comes on that says power-on password, but I do not remeber the password. How can I get past this
Well, you will have to try harder to remember it. Failing that, you will need to take it to an HP certified Service Center to have the password erased.
Apr 07, 2011 | Compaq tc4400 Tablet PC
My hp tc4400 tablet wont boot
Pull out extended ram & try again.
Dec 26, 2010 | Compaq tc4400 Tablet PC
I have HP TC4400 Laptop and there is BIOS password which is forgoted please help me how can i remove that password.
To reset the BIOS password read the information from this link.
In case of your HP TC4400 laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Oct 16, 2010 | Compaq tc4400 Tablet PC
HP TC4400 hard drive ugrade problem
go to hp site and check is the model support 320gb hdd or not if not trun yr hdd in limited capisity
Feb 26, 2010 | Compaq tc4400 Tablet PC
HP Compaq 2710p: External monitor does not display anything
The display properties indicate the hardware is working, so it's likely just a setting.
On HP/Compaq models you will see a picture, usually on the F4 key that looks like a screen with two lines beside it.
You need to hold down the Fn key(bottom left) and then push the F4 key at the same time to cycle between LCD, external or both.
If it is a newer model, a menu will pop up when you do this asking if you want to duplicate the LCD on the external, switch to the external or extend the desktop onto the external. Select the appropriate setting or continue holding down Fn while pressing F4 to cycle between the settings to the one you want.
If you have re-installed the computer at some point with anything other than the factory recovery set this may not work and I will have to give you a longer set of instructions.
If this works please rate this as fixed, if not reply back and indicate what version of windows you're using and I will post the instructions for the "long" way.
Chris
May 26, 2009 | Compaq 2710p Tablet PC
Problem: Cannot Load Windows/Windows Setup Does Not Detect Hardrive
My Hp Compaq tc4400 Does not load Windows and when i try to install a new one and error Message apears saying that it cannot detect any hardrive, but when i press F9 for boot selection Notebook Hardrive is dected and availble, i tried removing the hardrive and re-insert it also it dint work could somebody help plssss
Feb 01, 2008 | Compaq tc4400 Tablet PC (RL875AW#ABA)
Compaq tc4400 Tablet PC Logo
520 people viewed this question
Top Compaq Tablets & eReaders Experts
Vernon Taylor
tosin_christ
alibaba69
Are you a Compaq Tablet and eReader Expert? Answer questions, earn points and help others
