Making my computer run faster.
Would anyone out there know how to make my computer run faster? I don't know how to make it run faster and it is going pretty slow.
  • muriel_britt Apr 06, 2009
    how can i make my dell desk top faster it is very slow down loading any thing
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 9 Answers
One of the reason why your computer is getting slow is the non effective use of your RAM while you can use antivirus programs to run the cleaning of the running program. You also need to regularly delete your temp files. The best solution is to have a quality antivirus system which refreshes your system each time when it stores unusual memories.
Posted on Jun 27, 2018
Help about this question
Posted on Dec 30, 2008
  • 51 Answers
Ok umm, this is simple
it is either
-upgrade your ram
-uninstall things
-defrag drive
-get a new computer
hope this helps, maxicube
Posted on Feb 09, 2008
  • 39 Answers
Hello Kalono:
There are many different solutions to making your PC run faster.
Try www.pcpitstop.com. It will run a free full diagnostics on your PC and offer solutions.
Good luck my friend!
Seek Pc Repair
Slow opening of websites
How to Make Windows XP Startup Faster
Steps
1.Click on Start, then Run, and type "msconfig". Wait for a new window to pop up.
2.Look under the "BOOT.INI" tab. You will see a box labeled "Timeout:", and a numerical value. By default, it's 30, which means 30 seconds of wait time before boot. This can be changed, using 3 seconds. (Note: if you have more than one operating system, this means the wait time to startup to the highlighted OS. you might want a bit more than 3 seconds)
3.Delete the temporary files periodically from your computer to make the applications run faster. Type %Temp% in the run dialog box by clicking on Start -> Run, and click on "OK". You will see an open folder with many files. Click on the Edit menu and click on Select all and then click on the File menu and select Delete. Note: Always confirm that the folder which is opened has a temp on the top of menu bar and the folder indicates that it is a temporary folder.
4.Perform a scandisk to see that your computer hard drive is in healthy condition and it helps your computer run faster.
5.Always perform a disk defragmentation at least once in a month. start the disk defragmentation from the system tools available in the accessories from the start menu. it takes a longer time and it is advised not to run any applications in the computer including the screen savers, while running disk defragmentation.
Hibernation
After you have done all this, another method you can do is to allow the computer to hibernate. Hibernation closes and opens Windows faster than normally. However, Hibernation is a good long-term solution, as it does not waste electricity.
1.Go to Start->Control Panel->Power Options. Click on the Hibernate tab.
2.Click on the box that says "Enable hibernation" to check it.
3.Click on the Advanced tab and change the Power buttons options if you want to hibernate by pressing the sleep button or the power button. Otherwise, holding the Shift key while in the Turn Off Computer menu will give you the option to hibernate.
4.Restart your computer every week or so to clear your computer.
The power can then be completely turned off, even at the socket so that no power is wasted.
Prefetch
1.Simply browse to the windows folder (Ex: C:Windows) and under there you should see the prefetch folder. Go into the prefetch folder and delete all the files (Careful! It should look like this c:windowsprefetch). We need to edit a registry key to tweak it. Open regedit and browse to this key:
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlSession ManagerMemory ManagementPrefetchParameters
Under this key you should see a value named: EnablePrefetcher
It has 4 possible values:
0- Disabled : The prefetch system is turned off.
1- Application : The prefetch only caches applications.
2- Boot : The prefetch only caches boot system files.
3- All : The prefetch caches boot, and application files.
We don't want to disable it entirely. This would actually make boot times *longer*. This is because this feature is also used to speed up the loading of boot files. That is why we are going to pick the number 2 option. It allows us to keep the advantage of caching system files, without continually clogging the system up with applications.
Set the value to 2 and reboot.
The 2nd time you boot it should boot much faster. Remember that the side effect is that launching individual applications once windows has loaded will now be slightly slower.
Tips
When installing new software choose not to add the program to the startup folder.
. Regularly check to see what programs are running from your startup folder as malicious programs such as spyware may have installed itself without your knowledge.
. If you accidentally uncheck a program, just retrace the steps above and recheck the program and restart your computer.
. Adding more RAM to a Windows XP computer helps it boot faster, and since RAM prices are very low these days, it's an easy way to boot faster.
. uncheck system startup unnecessary startup programs*
Warnings
. Save any open work before making changes.
. Shut down all applications before making changes.
. Don't uncheck anything from Symantec or any other anti-virus or anti-malware software. Doing so may disable or hinder the protection of your PC.Remove all toolbar from add or remove program. From control panel. Reset web settings from internet option.
Apr 14, 2012 | Microsoft Windows XP Home Edition English...
Too slow,how can i speed it up
Steps
Hibernation
Prefetch
Tips
Warnings
Apr 09, 2012 | Computers & Internet
My laptop is running slow
Steps
Hibernation
Prefetch
Tips
Warnings
Apr 05, 2012 | Lenovo Computers & Internet
I need to clean up my computer
Goto C: drive icon in My Computer. Then click on Properties, then click Disk Cleanup. There is also on option to clean all but the latest restore point, that saves a lot of hard drive space.
You can also defragment your hard drive which sorts all the files out so that when a file is accessed it finds all of it at once, instead of finding fragments and putting them all together. Files are not usually stored all in one but are spread around the drive, taking longer to find the fragmented bits. It also consolidates all the free space for faster writing to the drive.
You can also go in to MSCONFIG and click the Startup tab and see what programs are running. Anything in there automatically starts running as soon as Windows starts. You can dissable the ones that you know don't need to be running. Not things like Antivirus, Firewall or anything to do with Internet though.
Go to the start menu and type msconfig in the search / run box and press Enter. When you have unticked the ones you dont want running restart the computer.
You will probably get a box pop up when you have restarted saying that you have been in to the configuration settings etc. Just tick the little box on the left that says Don't show this again or whatever it says.
You could also uninstall any programs that you don't actually use.
Go to the Control panel and click on Add and Remove Programs for Windows XP, or Programs and Features in Windows 7.
If it's just got slow gradually,cleaning up usually helps a bit.
If you just want it to be a bit faster then maybe it can have more Ram fitted on the motherboard, that helps, also upgrading the processor, and a faster hard drive will help.
You can also use a little program called CCleaner whhich searches the hard drive for all the rubbish left over from uninstalled programs, unused files, temporary files that are no longer needed etc. It's a free program and very popular.
You can also clean the registry which gets rid of a lot of rubbish left in there. There is an option in CCleaner whhich will do that.
Hope this helps.
Feb 10, 2012 | Toshiba Computers & Internet
Hello, I need help, I bought a My Book at the Walmart store today and I just wanted more memory so my computer would run faster. Now I have this Memo Auto Sync and Memo Auto Backup going in the back...
If you were wanting more memory to make your computer run faster, you didn't need a hard drive, you needed more RAM (random access memory), which comes in the form of long, slender cards that plug into the motherboard. You'll have to shut your system down, unplug it, open the case, locate the memory cards, read what's on the stickers on them, then get more of the same. If you've got a BestBuy, or Staples, or OfficeMax, or some other store that offers in store service and installation, you'll do yourself a real service by letting them do it. If you don't know what you're doing, you can really screw things up.
Alternately, you can access some decent how-to videos on youtube.
An external hard drive will give you a place to store seldom accessed stuff, or backups, but it's way too slow for regular use, and has little or nothing to do with speeding your computer up.
Aug 04, 2011 | Computers & Internet
Can't get on facebook takes for ever to load and can get on ebay but not my ebay help just seems to freeze all the time but i can get on farmville
mcdevito75 here, You can try to remove some un-wanted items from your computer to help it run a bit faster. First from your desktop, emty the recycle bin, NOW! from your home page, left click on TOOLs at the very top of the screen, delete cookies, READ every word in that box for deleteing items you don"t need, check each box of items you don"t need then delete. This should help your computer run a bit faster or more efficiently.
Jul 07, 2010 | Facebook Social Network
MY COMPUTER IS SO SO SLOW IT TAKES FOREVER TO DO ANYTHING WHY IS THIS? IM NOT EXAGERATING IT TAKES FOREVER TO DO ANYTHING
Delete any start-up programs you don't want or use, this will help make it faster at boot-up. Go to Start Button > Programs > Start Up then delete unused programs.
You can also run disk defragmenter. Which will speed up the process of looking up files, making your computer faster. To access Start Button > Programs > Accessories > System Tools > Disk Defragmenter.
There are other ways to make your computer faster like running anti-virus, spyware/adware programs, registry cleaners, and even re-installing Windows. If you still have problems take it to local computer service shop, not a "big box" store like a geek squad (they think everything is a virus).
I hope I helped your computer be faster. If you have questions please contact me on my profile. Good luck!
Jan 03, 2010 | Dell Latitude 120L Notebook
Moped Faster
you could re-jet the carb or put a larger one on but that would mean making your own manifold, and you can open up the pipe to make it less restrictive.
Sep 11, 2009 | 2008 Keeway Matrix 150
Computers & Internet Logo
213 people viewed this question
Alun Cox
David Payne
David Payne
