Question about Whirlpool LTE5243D Top Load Stacked Washer/Dryer
Whirlpool washing machine
The basket/tub moved completely out of place during spin cycle.
how do i move it back to its correct position?
  • ddale Apr 03, 2008
    the tub mounts are all missing the clips to hold the ring around the springs
    President:
  • Whirlpool Master
  • 2,651 Answers
You dont youll need to remove the top of the washer, first remove the angular access panel between the washer and dryer, youll see 2 brass clip holding down top POP those off, there may be 2 screws directly behind the clips as well, the main top will slide off. now there are 2 5/16 screws holding the front panel on probably 5 inc or so down on inside wall of unit, after the front panel is removed youll see the suspension for hte unit, theres 3 suspension rods, im sure 1 or more is broke or come detached. retailing for about 85 bucks id see the temptation to replace the broken one but honestly id replace all three if that is indeed the problem
Posted on Mar 16, 2008
    Problem Solver:
  • 19 Answers
For instructions on how to replace all three, you might want to review my solution in this thread:
http://www.fixya.com/support/t1578111-lte5243dq6_tub_broken_loose
Posted on Jun 17, 2010
Whirlpool duet dispenser to tub hose keeps cracking/ripping. why?
carefully check the position of the clamp, as the tub moves around during the wash and spin cycles the ears of the clamp been rubbing through the hoses
May 12, 2014 | Whirlpool 8540063 Washer Hose, Dispenser...
Whirlpool mach. is humming when u turn on but agitator won't move
Hello friend,
The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
In case of the agitator not moving check the following:
Motor coupler
Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts
Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer.
Check the above, It seems that your washer needs a repair and would not be possible to do it yourself. So yau will have to call a technician.
Do feel free to get back to us in case of any other assistance if problem is not solved or if you have any other query.
Thanks
Mar 05, 2010 | Whirlpool Washing Machines
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Whirpool model GSQ9669LW1 basket does not spin after replacing the broken coupler between motor and transmission. Motor showed good continuity using volt-owm meter on ohms setting on low, medium, and high...
We are sorry to hear of the problem with your Whirlpool appliance. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Reviews@Whirlpool.com with your name, phone number, address and the model and serial number for your washer.
Apr 06, 2017 | Whirlpool Washing Machines
Machine makes loud banging noise during the spin cycle
The load is out of balance. Open the lid and redistribute the contents. When it's empty, grab the basket and give it a slight push sideways. It should move a little but, not free swing. If it doesn't have much resistance, the "snubber" has dried out and should be replaced. It is simply a piece of rubber in a metal bracket, that rests on the tub. When the basket spins,the snubber keeps it from jumping around.
Aug 31, 2009 | Frigidaire FWT449
Shaking in spin cycle and tub moves too easily in washing machine
the tension springs on the tub mite have came loose during moving
Jul 01, 2009 | Washing Machines
Clicking noise when the washer is in the initial wash cycle,
does agitator or tub move at all during the cycle. if no movement then this sounds like the coupler. used in place of belt in this design, located between motor and transmission.
Apr 24, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Stylemaster 4217141 tub not moving wash/spin cycles
Sounds like the drive belt is broken or very loose. Take off the back and check the belt. If loose or missing, tighten or replace. This is usually done by loosening the motor support bolts and moving the motor until the belt is tight, then re-tighten the bolts. Replace belt in the same way.
Apr 22, 2009 | Whirlpool Washing Machines
Whirlpool Ultimate Care II spin cycle not functioning correctly
It sound like the basket is out of balance. When it spins open the lid and see if the basket is moving side to side and back to back. If so look under the deck and see if there is springs or rubber ties attached to the basket.
Jan 19, 2009 | Whirlpool LSQ9665JT
Trans will not disengage
either you have something stuck betwwen the two tubs(ie. a sock. ) preventing the tub from free spinning.or there is a clutch mounted on top of the transmission not engaging, as far the agitator not spinning correctly sounds liek the agitaor dawgs are stripped preventing proper agitaing(bottom of agitator works fine but upper portion free spins both ways without resistance?? correct??
Mar 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool LTE5243D Top Load Stacked Washer/Dryer Logo
142 people viewed this question
Dan Webster
Dan Webster
Sal De
