Question about Belkin (F5D5231-4) Router
Modem box changed now can't get belkin router to connect to internet
My dsl modem box has been changed and the internet properties are different, my problem is the Belkin router F5D 7231-4 will not connect to the internet, I am using the easy install program cd and can get through all functions to the last step and that is to connect and it won't connect to internet. Thank you in advance, Jan
  • 178 Answers
I can help you
Posted on Feb 11, 2008
The globe light is blinking. We can connect to Belkin but page not found comes up. The message that comes up says IP address does not match. We have 3 laptops, and none of them are allowing us to have...
  • Connect your computer directly to your cable or DSL modem. If you see a log-in screen for your Internet Service Provider, make a note of the user name and password.
  • Unplug your router and your cable or DSL modem.
  • Plug your modem to your Belkin router's "WAN" port. Connect your computer to one of your Belkin router's numbered ports.
  • Turn on in your modem and wait 10 seconds. Plug in your router and restart your computer.
  • Select "Start," then "Control Panel" and then "Network Connections." Right-click "Local Area Connection" to bring up your network connection properties.
  • Click "Internet Protocol (TCP/IP)," then "Obtain an IP Address Automatically" and then "Obtain DNS Server Addresses Automatically."
  • Open your web browser. If you are prompted for a user name and password, enter the information you recorded in Step 1
  • Dec 29, 2010 | Belkin F5D8236-4 Router
    I changed my router wep key password code and now I cannot connect to the internet; how do I fix this problem? It does not recognize the connection now and I cannot go back in to change it back to the...
    This is how you reset your router.....
    Reset the router to factory default With the router powered on, use a small thin object to press and hold the reset button for exactly seven seconds. The router lights will flash and this will restore the router to factory default. Connect your computer to one of the routers lan ports with an etherent cable. Open your web browser and navigate to 192.168.2.1. This should show the router status page with the default settings.
    How to setup new router:
  • 1 Connect your computer directly to your cable or DSL modem. If you see a log-in screen for your Internet Service Provider, make a note of the user name and password.
  • 2 Unplug your router and your cable or DSL modem.
  • 3 Plug your modem to your Belkin router's "WAN" port. Connect your computer to one of your Belkin router's numbered ports.
  • 4 Turn on in your modem and wait 10 seconds. Plug in your router and restart your computer.
  • 5 Select "Start," then "Control Panel" and then "Network Connections." Right-click "Local Area Connection" to bring up your network connection properties.
  • 6 Click "Internet Protocol (TCP/IP)," then "Obtain an IP Address Automatically" and then "Obtain DNS Server Addresses Automatically."
  • 7 Open your web browser. If you are prompted for a user name and password, enter the information you recorded in Step 1.
  • Read more: How to Set Up a Belkin Router ' eHow.com http://www.ehow.com/how_2292408_set-up-belkin-router.html#ixzz19MK9oA2A
    Dec 27, 2010 | Belkin Computers & Internet
    After firmware upgrade can't get router to connect to internet
    Connect your computer directly to your cable or DSL modem. If you see a log-in screen for your Internet Service Provider, make a note of the user name and password. Unplug your router and your cable or DSL modem. Plug your modem to your Belkin router's "WAN" port. Connect your computer to one of your Belkin router's numbered ports. Turn on in your modem and wait 10 seconds. Plug in your router and restart your computer. Select "Start," then "Control Panel" and then "Network Connections." Right-click "Local Area Connection" to bring up your network connection properties. Click "Internet Protocol (TCP/IP)," then "Obtain an IP Address Automatically" and then "Obtain DNS Server Addresses Automatically. Open your web browser. If you are prompted for a user name and password, enter the information you recorded in Step 1.
    Apr 30, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    Reset my belkin router now i can't connect to
    if you truly reset your router then you may have to reconfigure it. If your belkin router is also your dsl modem or cable modem then you will have to call your ISP provider and get your user id and password to start with.
    I have a feeling this device does double as your modem since you now cannot connect. Most routers will work as a router right out of the box. However if your modem is seperate then it may expect your router to have a different subnet for its IP address then the default. Try plugging your computer directly into the modem if that is the case. If it works then just reset the routers IP address to be on the same subnet.
    Mar 09, 2010 | Belkin (F5D7231-4) Wireless Router
    I just switched from cable modem to dsl modem..dsl modem gets on the internet when connected directly to computer..once connected to router doesnt connect to internet
    Your new ISP is DSL. the router was working before with the cable modem. The settings for the cable and DSL ISP are different. Now your computer is working when you connect it directly to the DSL modem. that means the modem is working.
    The DSL modem works on 2 different modes.
    You will need to check which mode is your modem working on and according to the settings of your modem you will need to set up the router.
    To change the settings of the router, you will need to open the set up page of the router.
    Click Here for more information about the router set up.
    Feb 20, 2010 | Linksys WRT160N Wireless Router
    My Belkin wireless G router does not seem to work any more. If I connect my router to my DSL modem, I am not able to make a connection to the internet via the router to my iMac. However, if I connect the...
    So if you connect the computer directly to the modem , it works .
    That means your modem is working properly. Your ISP is DSL connection. Now connect the modem to the router and the computer to the router. Open the router xet up page and change the settings of the router according to the type of connection you have.
    There are 2 types of connection in DSL.
    DHCP and PPPOE .
    Click Here for step by step instructions
    Feb 01, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    Modem Light Flashing, Internet Light Off, No Internet Connection
    Hi, Here is your solution.
    Please ensure the proper physical connection from modem to router and to the computer as mentioned on the box and make your all lights are on modem.After that turn on the router,if your have a cable modem, you can very well go for a hard reset,that it is at the back of your router you would see a reset button which is a button inside a hole. Please hold the button for 20 secs with power on router and 20 seconds without power continuously for 3mins (remember to hold the reset button through out 3 mins while plugin and plugout the power cord of the router and use pin or pen to hold the button). After this check out the lights on your router, lan light, internet ,power and modem should be solid.Else you can call the customer service number on the product box, they will assit you very well,ITS A TOLL FREE NUMBER.
    Sep 22, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    Belkin F5D8236-4 won't connect to the internet.
    this issue mostly comes with dsl connections..
    check whether the dsl modem is in bridge mode or pppoe method
    if it is in bridge mode ask the isp vendor to change the modem into bridge mode which prompts you for username & password
    try this it resolves the issue..
    Apr 19, 2009 | Belkin (F5D5231-4) Router
    Need assistance on seting up a belkin router
    Contact Belkin Tech Support At Toll Free Number- 1-800-585-2494
    Jan 20, 2009 | Belkin (F5D8231-4) Wireless Router...
    Belkin modem
    your modem is not the same...... the red/green arrows does not apply as it is for the other device
    you need to log into you modem (the quick setup guide will tell you how to do this)
    the status page will tell you if you are connected on adsl (there is also a link light on the modem itself which goes solid on (not flashing) when connected properly
    if on the status page it is not reading as connected you need to check your logon info and check the logs to see why it is not connecting..
    if it reports that it is connected, then there are a few system properties that you need to check.
    open Internet properties (right click on intenet explorer, choose internet options) in the connection menu, choose "Never dial a connection" press Apply, then press "LAN settings" button and tick box "Automatically detect settings"
    close Internet explorer then open internet explorer, it should spend a few seconds checking your settings then it should get out to the internet..
    job done...
    Oct 03, 2008 | Belkin Wireless Cable/DSL Gateway Router
    Belkin (F5D5231-4) Router Logo
    79 people viewed this question
    Top Belkin Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
