Question about Fisher and Paykel GWL11 Top Load Washer
Frigidaire (gallery series) err problem
I've loaded the laundry tub and filled the detergent pressed start and the (err) button keeps coming on.... what to do?
ps. I've lost my owners manual..
Paulette
Fisher Paykel GWL11 wont spin and water wont drain.
Diagnostic says pressure tube problem.
  • Anonymous Sep 12, 2008
    wash machine was in a wash cycle and it stopped ,i pressed a button to restart it and it flickered once and now it is dead?
    President:
  • Fisher and P... Master
  • 2,651 Answers
Ck to see that a control lock light is not illuminated, as far as fisher and paykel pressure swithc is part of motor controller under main console. removing screws behind console allows you access and from ther i would remove clear plastic tubing from right side of control and blow down the line (sometimes detergent will block other end not allowing proper readings)
Posted on Feb 24, 2008
Frigidaire gallery top load washer
After 13 appliance years, your washer is a candidate for replacement.
Aug 08, 2017 | Frigidaire CWS3600AS Top Load Washer
How do I clean my washing machine? My clothes and the washer have a mildew odor.
Add the entire packet of "TIDE WASHING MACHINE CLEANER" directly into the tub (no laundry) and close the door.
Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
This method of "TUB CLEAN" is *not* from a service manual but has been the best method for cleaning out LG washers more than a year into incorrect detergent usage.
After this--use the correct amount of "HE" detergent & perform a "TUB CLEAN" cycle every (4) months using the *tub clean* option on the control panel.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 18, 2011 | LG WM-2277HW Front Load Washer
Moldy gasket
It because the mildew is not just on the gasket, but it is in the tub and in the pump and discharge hose as well. You need to reduce/eliminate the mildew in those parts. There is a couple of things you should do to reduce the causes of mildew.
1. Run the machine once a month using hot water and two cups of vinegar to clean out the machine. You might need to repeat this a few times to completely clean out your machine.
2. Follow the manufacturer's instructions for the about and type of laundry detergent to use with your wash. Using too much detergent causes a build up of detergent on the tub which encourages mildew growth.
3. After your final wash of the day, leave the door and laundry detergent open, wipe dry the gasket with a cloth.
4. If the above steps does not help, try a commercial product like Affresh.
Hope this helps you.
Jul 22, 2010 | Frigidaire GLTF2940ES Front Load Washer
Soapy smell in clothes
You might need to wash your washing machine.
Most consumers think they are doing what is *normally* the right thing to do, which is to follow directions on the detergent label. In this rare case--those directions should be entirely disregarded.
Additionally--in many LG washers--the liquid dispenser cup (blue cup) has a "MAX" line on the white siphon cap.
This was a very big *faux pas* on LG's part--this "MAX" line has NOTHING to do with measuring detergent and should never be used as a guide for determining correct detergent amount.
The "MAX" line indicates how much liquid must be in the blue dispenser cup before it DISPENSES from the bottom of the cup.
This is a very,very frustrating mistake that gives owners much grief.
After three months of incorrect type of detergent or incorrect amount of the correct detergent used--musty odor begins to occur.
After more than two years--a significant amount of soap scum/curd has accumulated in the washer. Odor-causing bacteria flourishes on this build-up.
It is imperative to remove this slimy residue. Tide sells a product called "TIDE WASHING MACHINE CLEANER" which is very effective if used the proper way:
Once a tub has become heavily contaminated--normal methods of performing a TUB CLEAN cycle won't "cut it".
Got that? LOL
Jun 13, 2010 | LG WM2487H Front Load Washer
Screen flashing "LE" and will not finish spin cycle?
You MUST use "HE" (High Efficiency-Low Suds) type detergent--but to use the correct amount.
Nearly all brands of "HE" detergent have incorrect instructions.
The correct amount is as follows:
HE: (2) Tablespoons Per Washload
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated): (1) Teaspoon
This reduces/prevents:
1) Musty Odor
2) "LE" Error/Interrupted Cycle
3) L-O-N-G Cycle Times (longer than time displayed)
4) Insufficient Cleaning Results
5) Small Water Leaks from the air vent behind the washer or at the
front door gasket
6) Damaged Hall Effect Sensor (on 2007 or older LG washers)
7) Reduced Spin Speeds (laundry not spin-dried effectively)
Most consumers were doing what is *normally* the right thing to do, which is to follow directions on the detergent label. In this rare case--those directions should be entirely disregarded.
This was a very big *faux pas* on LGs part--this "MAX" line has NOTHING to do with measuring detergent and should never be used as a guide for determining correct detergent amount.
It is imperative to remove this slimy residue. Tide sells a product called "TIDE WASHING MACHINE CLEANER" which is very effective.
This method of "TUB CLEAN" is *not* from a service manual but has been the best method for cleaning out LG washers more than a year into incorrect detergent useage.
Most digital-controlled front load washers have a software feature that consumers are unaware of.
If excess suds is detected by the MAIN BOARD (which monitors motor electrical load during rinse & final spin) the "suds kill mode" will be enabled.
This causes the washer DISPLAY CLOCK to stall.
The washer makes an attempt to reduce/remove suds--usually a futile attempt--and ends the cycle much longer than was originally shown on the DISPLAY.
May 24, 2010 | LG WM-2277HW Front Load Washer
What detergent brand do you suggest with front loading washer?
We use 2x ultra ALL due to having allergies in our family. It is free of perfumes and clear of dyes. We only use 1/4 of the cup (or less) that is supplied with soap container and double rinse. That's the great thing about these washers, they use alot less water and don't need the extra soap as well. Even with the double rinse, at the end of the full cycle, we still see an occasional soap bubble near the door. Hope this helps!
Mar 25, 2010 | Frigidaire GLTF1670A Front Load Washer
Mildrew, stale water smell in laundry
Run a very hot wash on your machine with no load
Fill a bucket with a strong solution of soda crystals and pour it into the machine first
Add some more crystals to the soap dispenser
Use an old fashioned soap powder for a couple of washes as well and reduce the load slightly
Modern soap powders do not contain certain bleaches and soda and the 40 degree wash leaves body fats and oils inside which cause odours
Jul 03, 2009 | Frigidaire ATF6000ES Front Load Washer
Black streaks, smudges and dots from drum
take a rag and wipe around front door boot first does any thing come off on rag if this ckd ok does it keep a roaring noise when spinning? if so suspect rear bearing or corrision on spider this is tub support behind basket..ask for estimate before repair as this could result in major expense to repair good luck
May 28, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Click on your model number (below FIXYA) on this website, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site.
Jan 23, 2008 | Frigidaire GLTF2940ES Front Load Washer
Laundry tub
The problem is detergent spotting, do the hottest wash for several occasions and add a cleaner descaler preferably two mugs full of washing soda. Regards Advisor
Aug 23, 2007 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Fisher and Paykel GWL11 Top Load Washer Logo
228 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
