The hourly price and time employed to replace the ball joints may vary.
In USA the price to replace the four ball joints ranges from about $500 to $1000 .
A single ball joint for discovery can cost between $35 and $80, depending on model.The set will be less expensive, costing between $100 and $150. Here a list: land rover discovery ball joints.
After replacing the ball joints, the mechanic must do alignment procedure. Depending on the garage, this may be billed separately.
HI. Ok, This vehicle is equipped with an upper and lower set of ball joints. The prices are as follows:
Parts price will be $40.00 for the upper set
The labor is set to $195.00 for the upper replacement procedure.
Parts price for the lower ball set will be $40.00.
The labor price for the lower replacement procedure will be $165.00
NOTE_ Land Rover recommends to replace the upper and lower, in this situation. Total cost, if you chose to replace the upper and lower ball sets, will be $80.00 for the parts, and $360.00 on the labor.
