Question about Digimate DGL32 32 in. LCD Television
POwer Supply blown
Teere was a power surge and my PSU fried.How can I replace my PSU.Thjere are no service centers in Canada for Digimate.
  • Anonymous Mar 11, 2008
    same problem
  • 29 Answers
Just get the specs for that PSU. Look for the output voltage and current and buy one of the same specs. The voltage should be the same but the current may be the same or higher but not lower.
Posted on Feb 09, 2008
depend on where the surge is. from power line, then most likely your psu is fried. if it comes from the modem/telephone line then probably your motherboard is fried.
May 30, 2014 | E-Machines eMachines Desktop PC
Vostro would not power up after power surge
You can try another PSU, but since you mentioned there was a power surge, worse case power supply circuit in laptop may have fried.
Mar 01, 2014 | Dell Vostro Computers & Internet
Will not power up. Replaced bad power supply(burned circuit board inside PSU) but still does not power up, PSU is ok. When power on button is pushed CPU fan turns for about 1/2 second but nothing else....
Sounds to me like when the power supply went out it allowed a surge to hit the mother board and you will have to replace it also .Look at the mother board and see if there is a green LED light showing if it is you are getting power to it and you have capacitors blown if not recheck you connections from the power supply and MB if they are all tight and correct then just figure on replacing the mother board
Sep 01, 2011 | Biostar M7VKB Motherboard
Had a blackout and now power suppy won't turn on. Green ps light blinks and makes a clicking sound through speaker.Modelatx 300-12z cdr
Surge has possibly fried the PSU. Depending on the severity, you may find other components are damaged on the motherboard.
Best way is to test with a known good PSU
Jan 07, 2011 | Bestec (ATX100-5) (ATX1005B) Power Supply
How to turn on the "power supply" without the
You need a Power Supply Unit (PSU) tester which you can get from Ebay or shops like maplins.
TIP - never turn on a PSU without at least one drive attached to it, the power surge on the first turnon can fry the PSU unless it has at least one hard drive or cd drive plugged into it.
Oct 30, 2010 | Dell (9228C) 200-Watt Power Supply
I had a power failure. when the power returned, my hp pavilion will not come on. is there a reset button? Or is my computer permanently broken?
are there any light on *********** board?
what happens when you press the power button?
chances are that there was a surge when the power returned and it fried your psu (power supply unit), the best way to test this is to try a different psu on your computer
costs depend on brand and wattage but i generic 400 watt is only about 40 bucks
Oct 13, 2009 | HP Computers & Internet
My computer will not turn on it will not do anything, i remember hearing something blow like a fuse, it is connected to a surge protector it was the only thing that messed up
you fried your power supply inside the computer. check all connections and try plugging directly to known good outlet first. but it sounds like a blown power supply
Jul 16, 2009 | E-Machines eMachines Desktop PC
Push power button it does not turn on. Noticed green light blinking though on the back of computer under the power chord can you help with what is the problem?
This is indicative of a blown PSU. Your PSU is the Power-Supply-Unit which, naturally, supplies power to your computer. The bad news is that some of your other components might have been taken with the PSU as when most PSUs die they cause some form of an electrical surge before dying. This in turn could fry some other components.
If you have another computer in the house, try removing its power supply and sticking it into this computer. If it works after installing the power-supply, we know nothing else got fried or damaged and we can simply order you a new PSU. However, if something doesn't work (no sound, video, no response after pressing power button) you have a much more serious issue and will probably end up having to replace the entire system.
Before you replace the PSU, check to see if you're still under warranty. If you are, have the system inspected by a technician certified to inspect warranty products from the company which made your computer. If the system is still under warranty, the inspection and replacement of fried parts should be free.
Let me know which route you decide to take or if I need to explain anything mentioned above in more detail. However, I'm quite certain this is because of a blown PSU.
Mar 25, 2009 | Compaq Presario sr1403wm AMD Sempron 3000+...
Dell Dimension 9200 PC will not power on
Well, either way it sounds like something in your motherboard or your system got fried. Either a surge occurred frying some if not all components (yes, voltage can still flow through them even when they're dead allowing things such as the LED on the motherboard to glow) within the computer, or your PSU blew out taking some components with it.
Due to what you're describing, I'm more inclined to believe your PSU blew out due to some form of an overload taking your motherboard (if not more components) with it. An overdraw of power on the PSU or just a cheaply constructed PSU will easily blow taking some of the components with it (essentially killing the components).
Sorry if this is not the solution you were after. However, everything you described matches with either a power surge or a blown PSU. Always sad when perfectly good electronics get fried. Let me know if I can help you with anything else.
Mar 22, 2009 | Dell Dimension 9200 PC Desktop
Digimate DGL32 32 in. LCD Television Logo
109 people viewed this question
Top Digimate Televison & Video Experts
Jaime Hernandez
Jason Morris
Computer Repairing
Computer Repairing
Are you a Digimate Televison and Video Expert? Answer questions, earn points and help others
