Mag monitor dx17t tint adjust
Dont know how to adjust color and tint,plus i dont have full horizontal deflection.at full width it lacks about 1/2 inch on each side.i dont know how to operate the adjustments.
  • ronbalch Feb 10, 2008
    i have tried all the buttons,but none of them seem to adjust color.they are for horizontal and vertical only
  • Maryellen7 Aug 30, 2008
    Had a crash and have just now gotten files back and can log on.  I have it in safe mode and am running all the tests and diagnostics I can.  I believe It locked me out of signing on due to a faulty mouse.  The colors are terrible and tint is bad.I had this problem once before and found a simple adjustment just before  buying a new monitor.  I cannot remember how I did this.  Any help will be appreciated.  Bought an apple but would like to run both along aside each other.
    Problem Solver:
  • 3 Answers
Adjust color and tint by pressing buttons on your monitor
Posted on Feb 09, 2008
What is cost of yoke for panasonic ct tv?
You're discussing about the width problem to picture. If yoke have a short in between its wingdings [even a single winding short], will cause the failure of horizontal output transistor. As per you report here, the set has a raster, but problem is with the picture width.
There possibliliites for this fault are.
1. Lack of voltage from the SMPS power supply output.
2. Horizontal width capacitor.
3. Horizontal output capacitor.
Check the output voltage from the SMPS section first, and confirm that it is OK.
Jan 03, 2013 | Panasonic CT-24SL13 24" TV
WS-65903 HD1080
press format key on mitsubishi remote control and try to get full screen.let meknow if it works if not do you have a cable or satellite box and what type?
Jul 04, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Width problem
A width issue specially if this is short of width on the screen can be due to many reasons:1. It can be a low +B which means the SMPS power supply has a lower output due to low Switching or a low value on the main capacitor. Check this out, measure the +B on the mains end and also the secondary side which will confirm.2. If the secondary +B is correct the fault can be with the sync circuit IC or the horizontal coil or even a fault with the deflection coil. A proper measurement of the voltage in this section is important.3. Check for weak capacitors and DRY soldering on the horizontal section , line output section.
Dec 15, 2011 | LG Studioworks 700S 17" CRT Monitor
Screen horizondally pulled right side and screen rolled to left side
hi,
your monitors horizontal deflection side have some problem. you have to check the horizontal width cotrolling transistor mounded on the aluminum heatsik near the lot( line output transistor). also check the three mosfets which adjust the width for different resolutions. there are three such mosfets in the horizontal section.
fist of all replace the width controlling transistor in the heat sink. photo of mosfet and transistor is added for reference. not the exact number.
ok
Jan 27, 2011 | AcerView 99C 19" CRT Monitor
Horizontal alignment ok, but right half not printing.
One of two situations exists:
1. If the printing stops with clear stopping edge, then the PRINT WIDTH setting has been changed from the default full width setting of 104mm.
Check this by pressing MENU and then the NEXT button until you see a setting for MAX WIDTH. It should be set to full width of 104mm. Anything less will stop printing beyond whatever the setting is. Change it back to the full width setting.
2. If the printing stops by fading away to the right side, then that is caused by a pressure imbalance across the printhead. There is more pressure on the left side than the right side. There are two toggles that press down on the printhead and the pressure can be adjusted by moving the right toggle to the right so that more pressure falls on that side of the printhead.
Hope that helps !
Jul 20, 2010 | Zebra 140XiIII Plus Thermal Label Printer
Suddenly hor. lin. became "narrowed", smell of overheated element
try a good slap most times it works
u may have to try looking at options to change the monitor soon too, its a sign to say the monitors's getting old
hope this helped
pls rate
Jun 29, 2009 | Samsung SyncMaster 900 SL Plus (White) 19"...
Can not get a full screen lack 1 quarter inch on both side of the screen
just right click right in desktop and choice properties then setting and adjust the screen resolustion
Sep 28, 2008 | Computers & Internet
Monitor emachine
If the width is shrinking, check also if the edges are now distorted too.
If so, there is a 'bipolar' capacitor in the high voltage section that is failing.
To find and verify this, you will need a meter that can measure capacitance, and perferably, DF or losses of capacitors as well.
If you ignore this, the horizontal will continue to shrink until the deflection stops completely and can cause other, more costly parts to fail although these may also be weakened and failing.
I'm afraid this is not a DIY problem.
Aug 27, 2008 | Computers & Internet
Monitor problem
Appreciate the "Ask Me".
I am assuming that you have more than just familiarity with electronic components and circuitry, the use of a DVM and a soldering iron. Further, that you have access to a service manual.
Width problem is basically insufficient horizontal deflection, then analysis would have to be in the horizontal section. Areas to initially focus on:
  1. 12V line and pin 29 of IC401;
  2. 110 V peak to peak at collector of Q403, if yes check Q 402 & 404 as well as T401;
  3. other components that affect the horizontal size are:
  • IC201
  • Q 405, 406, 407 & 408;
  • D409
  • L401
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 06, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Horizontal/Vertical Postion of Image on LCD Monitor
the controls for focus adjustment are on the flyback transformer, (that big black thing on the left hand side (usually) of the monitor with the thick red wire that goes to the CRT.) the flyback may have 1,2,3 or even 4 knobs on it. 3 of these would be labled SCREEN (bottom knob of flyback. handles brightness)
FOCUS 1 + FOCUS 2 (focus adjustments. these are what you need to play with) and the 4th knob (some old mitsubishi workstation monitors had these) i do not know, it wasnt labled and HV adjustment was on the deflection board
Apr 25, 2008 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
139 people viewed this question
Alun Cox
David Payne
David Payne
