Question about Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
FP 2 drawer dishwasher DD6031
The bottom drawer cover is not working inside. It doesn't cover the tub so it doesn't fill. You can just hear it go on,start and then you hear a knocking sound which I guess is the cover trying to come down,but it doesn't. This started from one load tot he next without any warning. Please advise what to do.Thanks.
    President:
  • Fisher and P... Master
  • 2,651 Answers
Possible you have bad lid actuator motors(common to break without warnig) calling manufacture for authorized dealer in your area to get part
Posted on Feb 23, 2008
How do I relace the drain flapper valve (528625P) on the bottom of the upper drawer in my Fisher Paykel 603?
9.9.1 Remove the drawer front
9.9.2 With the tub opened release the tub clips and push back the
drawer rails.
9.9.3 Carefully release the four wiring cover clips from the front
lower section of the tub taking care not to damage them.
9.9.4 Release the three clips on the underside of the tub which
retain the wiring cover.
9.9.5 Pull the tub fully open and lift it up at the front (this makes it
easier to remove the wiring cover from the rear of the tub).
9.9.6 The wiring cover may now be carefully moved forward to
release it from the rear of the tub.
controller.
9.10.6 Unclip the drain hose cuff from the motor assembly taking care not to misplace the non-return flap valve so you know where it sits.
Replace flap valve and refit in reverse order.
Not sure why you need to take the top drawer out if you have already got the bottom drawer out and only need to replace the valve in bottom drawer.
Apr 18, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
Faulty top drawer on fp dishdraw can I disconnect powet to top unit to disable it
Unfortunately the power is distributed from the inside to the two drawers.
You will have to address the cause of the problem in the top drawer.
If you are good at electric repairs you could disconnect the power from the dishwasher power board itself, but this is not for the faint hearted (no offence). Might be helpful if you can provide a little details about the problem with top drawer. Generally if you are getting F1 message on the panel on bottom drawer and top drawer display is blank (ie no power), then the power board at the base of dishwasher is blown and needs to be replaced. Please clarify model number as the one you provided is for single drawer unit. Make sure the mains power is turned off when you work inside the diswasher.
Feb 05, 2013 | Fisher and Paykel DishDrawer DS605FDSM...
How to get bottom drawer out of fisher paykel dd6031
I wasn't able to find an exact match to your reported model (DD603I?), but all of the DD60xx models appear to have the same drawer removal process:
2_23_2012_6_18_56_am.jpgI actually took this from the installation guide for the KitchenAid dishdrawer (also made by F&P), since it had the clearest images.
Dec 24, 2011 | Fisher and Paykel 24 in. DD603H W Built-in...
Fill fault on top tub and bottom works fine. getting about 30 ounces of water and it takes about 3 minutes for fault code to come up
If your bottom drawer works fine then your inlet water valve below the bottom drawer is bad. Click on the link below to see how to repair this dishwasher.
Appliance Repair Video
Mar 26, 2011 | Fisher and Paykel 23 in. DD-603 Built-in...
The top drawer of my FP dishwasher is not cleaning everything properly. The glasses or dishes in the front left side are always dirty and are covered with crumby dried residue when the cycle is complete....
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Feb 20, 2011 | Fisher and Paykel 23 in. DD603H SS...
Dd6031 find it very difficult to close top drawer-seems something is blocking it-it has just happened
The likely culprit is the drawer seal which is located at the inside top of the housing.
YOu will need to take the drawer out by pulling the plastic pins on each side to release the front cover. Turn off mains power to the unit.
Inspect the top inside to see if the seal is broken or rigid. It should move in if you press. If rigid then the actuator motors are misalinged or faulty. Needs service.
Hopefully if the seal is ok, then it is likely the drawer had come off the rail and was not going to the end. Put drawer back in making sure it is sitting with ease on the track. Replace front cover and test.
Sep 16, 2010 | Fisher and Paykel 24 in. DD603H W Built-in...
Need to know how to take the see through cover off under the top draw on the DD603 dishwasher to replace the drain hose on Fisher and Paykel
I think you are referring to the wiring cover at the bottom of the drawer. I will assume you know how to get the drawer out.
To remove the wiring cover
1. Carefully release the four wiring cover clips from the front
2. Release the three clips on the underside of the tub which
3. Pull the tub fully open and lift it up at the front (this makes it
4. The wiring cover may now be carefully moved forward to
5. To reassemble first ensure that the wiring harnesses, drain
hose and fill hose are clipped into their correct position.
6. Then refit in reverse manner
Please rate this solution if this is what you were after. Otherwise post a comment and fixya.com will try to help you.
May 22, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Power light + bottm drawer closure
the plastic covering at the bottom is clipped in. check outside diameter of the cover and u will find the clips. is your activator board in working order? when u have a leak on these units it sometimes causes problems on that lower board.did u put connecters back properly? check these things and reply back 4 more help if needed. good luck.
Apr 25, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
How to take or remove drawers out of 2 drawer Fisher Pakel
Hi, welcome to FIx Ya...
1. Unplug machine.
2. Slide drawer open, remove two pegs that secure front panel to drawer (one on each side of drawer)
3. Slide front panel down and out, remove green ground wire.
4. Depress tabs that hold bottom plastic cover on bottom of drawer and remove entire cover, being careful not to break the tabs.
5. Disconnect tan water fill hose from rinse dispenser.
6. Disconnect two wire harnessess at control board.
7. DIsconnect drain hose from pump base. (might want to put a pan underneath to catch water)
8. Depress tabs on hose/harness coupler at bottom rear of drawer and dis-engage the coupler.
9. Lift drawer off slides.
Jan 13, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
How can I fix my Fisher and Paykel DD 6031 Dishwasher? its leaking
I have Fisher & Paykle DW DD603-SS (5Y old)
The upper drawr started to leak H2O out and in to the bothom drawr???
What is the problem and also please what is the solution?
Thanks, JB
Jun 23, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Logo
433 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
