Question about JVC TH-A25 System
JVC XV-THA25 Hello. When I power on the unit, the word PROTECTION comes up on the display and then it shuts itself off. What can I do about it? Thanks,
  • 4 more comments
  • LarsL Feb 14, 2008
    I have the exact same problem and absolutely no idea what to do. It has not been used for 7 months as I have been abroad in this period.
    Worked perfect before that
  • rinusvanelde Aug 22, 2008
    After years without problems I installed a eurodocsys (UPC) unit and reconnected the cables. After a few minutes a loud "blow" blocked the TH-A24 and came into the "protection" state.
    No solution found yet. Fuses (4 in total) seems to be OK. Reset didn't help.
    No resistors replaced yet. No burned-out resistor found!
  • Anonymous Dec 07, 2008
    Please, write to jamlet75@hotmail.com
    Thanks.
  • danstun_mak Mar 13, 2009
    protection and shut off
  • Anonymous Mar 28, 2009
    protection, che devo fare?
    dvd player won't open, says "protection"
    After the word "protection"appears the dvd player turns itself off and can't
Fixed it by replacing a burned resistor.
100ohm 1 wat designation PR010 on the main pcb.
Posted on Aug 11, 2008
  • cyrez00 Aug 11, 2008
    oeps.... 10 ohms that is.
The most logical solution that I could find is that when you leave the dvd player plugged into the wall it is still runnning and therefore doesn't cool down very well. when you turn it on it's already trying to stop the overheating so turns off automatically. if you unplug it whenever you're not using it you should have no problem.
Posted on Jul 21, 2010
Hello have you found a solution for this PROTECTION!!!?
Posted on Jul 13, 2008
Receiver shuts off when loud content comes on TV
Hello Jerry, This means that the unit is going into protection mode. The unit will only go into protection mode for 2 reasons. The first reason would be if there is a short within the unit itself. The second reason would be if one of the speaker connections is causing a short. To isolate which of the two is the issue, you would first turn the unit off and unplug all of the speakers. Turn the unit back on with no speakers connected and raise the volume up. If the unit turns off with no speakers connected then we know that the issue is internal and would have to go in for repair. If the unit stays on, that will tell us that one or more of the speaker connections was causing the issue. If that is the case I would check all of your speaker connections and possibly start with fresh copper connections. Thanks, FJD
Feb 24, 2016 | Onkyo TX-DS575 Receiver
Speaker monitor will not power up
Most likely bad electrolitic capacitors from it sitting for a long time
Feb 10, 2012 | JBL LSR 2328P 8" Bi-Amplified Powered...
My HT-P10 displays "protection" and
The amplifier has a bad channel or is bad in general, and will need replacing. In some cases, it's a separate board and can be replaced itself, but in others, everything is on one board(except the power supply unit) and warrants just having he unit replaced.
Dec 04, 2010 | Samsung HT-P10 Theater System
Hello. Starting to watch a movie there came a loud "blow" and the machine shut off. The word PROTECTION comes up on the display and then it shuts itself off again. How can I get the DVD out of the...
hello you will have to take the top of the machine then you should see a plastic cover over the laser unit.you should 2 screws undo these you should see the dvd
regards
shaun
Feb 18, 2010 | JVC TH-A25 System
Need help with HT-z410
When your home theater's display reads PROTECTION, it means the home theater is over heating and the unit will shut down to prevent any damage. This can happen if the unit is stacked along with other electronic devices or the unit is in an enclosed area that prevents the unit from cooling properly. To decrease the chance of overheating, relocate your home theater to a more open area.
If the home theater display reads PROTECTION every time you turn it on, no matter where or how the unit is placed, it needs service. To set up service call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Jun 29, 2009 | Samsung HT-Z310T Theater System
Hello Protection Samsung HT-DS900
Jun 14, 2009 | Samsung HT-DS400 System
Protection displayed and shuts off
the solution is get rid of it fast , i had a samsung dvd player that did that then it caught on fire , pretty scary,lucky i was there when it started to smoke up
May 23, 2009 | Samsung HT-X40 System
Toshiba sd-kt50 dvd player turn on open/close hello appears protection appears and goodbye comes up turns it self off. we had two second power offs not associated with a storm
the sudden power cut-off can either blow the fuse or corrupt the system of DVDs.but, some DVDs has protection for this occurrence.try not to use it for sometime.then if it's well rested try turning it on see if is resets it's protection circuit.if not, a new unit or call a technician for it.
May 07, 2009 | Televison & Video
Help
Take every single cable out of the unit, now power on the unit.
If the power protection still shows then there is an internal fault, usually a short or a component defect.
If it powers on ok, switch off and insert 1 speaker at a time and power on the unit until the protection mode comes on again, the last speaker you have put in has overloaded it for some reason, also as you are trying each speaker use the volume and bass controls to see if there is an internal overload.
Thats as much as I can offer you until you narrow the fault down to the unit or one of the speakers.
Cheers
May 13, 2008 | Samsung HT-X40 System
Hey guys! Im glad you found my solution on my blog, and posted it here. I hope you ccan fix yours, or get it replaced on warranty. Im happy to help you with anything, the capacitors i think was 4,7 uF, 100volt, not sure.
Here is the link to my solution: http://lemurt.wordpress.com/2008/08/18/defenition-of-waranty-void/
:D
/ lemurt
Mar 01, 2008 | Samsung HT-X40 System
JVC TH-A25 System Logo
3,060 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
