Question about TruTech PVS31170S1W 17 in. LCD Television
DVD player The DVD player reads "No Valid Disc" for all all movies.
    Brigadier General:
  • 6,966 Answers
Most DVD players that would display such a message even with a known good disc inside signifies that the that the laser eye/lens is not reading the disc. This could probably be attributed to:
1. dirty, damaged, inverted, blank, un-finalized burned CDs or DVDs;
2. defective, weak, dirty/dusty burned-out laser eye/lens;
3. defective slider shafting (where the laser eye's carriage moves) or some other components.
A few things you can try:
1. Use a CD cleaner (readily available from most computer shops);
2. use a can of compressed air and blow through the inside of the loaded disc area;
3. gently tap on the top cover where you estimate the reading/laser eye/lens would be;
4. gently press on the tray door once the disc is loaded.
Should this not be corrective, perhaps your best bet would be to seek the services of a qualified professional such as those in a Service Center. Alternately, your friendly neighborhood electronic shop should do just fine.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kindest regards.
Posted on Feb 10, 2008
I purchased a toshiba portable dvd player and the disc is not spinning therefore reads no valid disc. I have put in a few discs still same reading? Any suggestions?
The Sled Motor is defective. this is the motor, whic spins the disc as it has been loaded properly. If the loader mechanism loads the disc properly into place and if the catch up magnet catches the disc in place, and still the dis do not spins, replace the sled motor. OK.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
SD-P1900SN After inserting movie DVD, I get message, "No Valid Disc". I ensure disc is inserted properly. Bought player a couple of years ago. Have only used it 3 times. Can't find anything in manual...
Check for cracks or scratches on the dvd disc?It a dvd movie disc,not a computer program dvd disc?Take the dvd disc,washes it with some dish washing soap.To clean all the grims and grease out of the dvd disc laser surface to the dvd player laser eye to read the dvd disc.
Jun 17, 2010 | Toshiba SD-P1900 Portable DVD Player
Disc read error
Dear Sir,
After 2-3 years generally all optical drive lenses goes bad,so first try by cleaning lences,if it not solves your problem then try by replacing lence of your DVD Drive,if you have any problem regarding this issue leave a feedback we will glad to assist you.
have a nice day
good luck
Sep 11, 2009 | Toshiba SD-P1900 Portable DVD Player
Portable durabrand dvd wont read disc
If it is reading a burned movie from the internet make sure you set you brun software for captability mode.
If this is a orginal disk make sure its free of dust and scratches.
1. buy a lens cleaning kit from walmart or any other eletronics store.
2. Make sure the disc is free of scratches.
3. change disc's and see if it works on any others.
if these steps do not help then the laser would need to be replaced. Durabrand is a Wal mart brand i had mine for 2 years and i had to clean the lens 3 times with a cleaning kit.
Jul 17, 2009 | Durabrand DUR7 Portable DVD Player
No valid disc
your not using a good disc. use a regular disc and no blue rays
Mar 31, 2009 | GPX D1816 DVD Player
MPIO dvd player reads "no valid disc"
Try cleaning the lens with a dab of rubbing alchohol and a q-tip. If error continues, throw unit in garbage.
Mar 02, 2009 | Televison & Video
I load in a movie it spins for a few seconds and then it says not valid disc
Is this movie a copy put onto a blank disc?
Not all players can read copied discs.
Sep 16, 2008 | Televison & Video
No Valid Disc
Try cleaning the laser lens if this don't repair it ,is the flat cable connector between the laser lens and the main board.Good luck
Jul 25, 2008 | Durabrand Portable DVD
I put the disc in the player ithen tries to play then it says disc not valid .
Same here!!! We've only used it maybe 8 or 9 times. And it's been worthless for the past month because of it. It reads everything "no valid disk" and nothing will work. And I tried e-mailing customer support several times, with no luck.
Nov 21, 2007 | Durabrand DUR7 Portable DVD Player
No Valid Disc
Try this out; Go to your DVD player's settings/setup menu, find the "Disc Lock", set it to "off" if it is already set to "on"
Apr 16, 2007 | Durabrand PVS1966 Portable DVD Player
TruTech PVS31170S1W 17 in. LCD Television Logo
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
