Question about Baby Gear
Convertible top overide?
Just purchased this vehicle and I'm trying to figure out if there is a manual way to open the convertible top. I think the motor may be burned out.
  • 2,039 Answers
It depend what kind of car the only way to open is removing the motor and turning it manuel or maybe by removing the motor it you gonna be able to lift the roof by hand the motor kinda lock it in place try it out let me know thanks for using fixya pierre
Posted on Feb 09, 2008
05 mustang convert.no open/close,makes clicking sound.2 relays,fuse,switch checked,new motor/hydraulics.Are there other relays,open close sensors? Top works UP when grounded externally, but not DOWN.
Principles of Operation
Convertible top operation is controlled by the smart junction box (SJB). When the convertible top raise/lower switch is operated, the SJB commands the front and rear windows to the full down position. Window operation is disabled while the convertible top raise/lower switch is being operated. When the SJB receives a full down input for both rear windows, it commands the appropriate relay closed to raise or lower the convertible top. If the SJB does not receive a full down input signal for both rear windows, convertible top operation is disabled.
The convertible top assembly is a floating frame, Z-fold design. The main pivot brackets are attached to the body, and the convertible top frame side rails expand or fold when the convertible top is raised or lowered. The LH and RH stay pads are attached to the convertible top frame bows, and provide the main source of tension for the convertible top material. When the convertible top is in the full down position, it stores in the compartment behind the rear seat backrest. When the convertible top is in the full up position, the body provides a stop which the convertible top frame number 5 bow contacts to provide a weather seal for the convertible top against the body.
The convertible top hydraulic system uses a 12-volt reversible pump and motor assembly. When active, the pump uses hydraulic pressure to extend the hydraulic lift cylinders to raise the convertible top, or retract the hydraulic lift cylinders to lower the convertible top. The convertible top motor/pump assembly is equipped with a thermal circuit breaker. The circuit breaker typically resets after 5 minutes depending on the ambient temperature. The thermal circuit breaker cannot be repaired and must be installed as a unit with the motor/pump assembly. In the event of a hydraulic system failure, the convertible top cannot be operated manually.
  1. Verify the customer concern.
  1. Visually inspect for obvious signs of mechanical or electrical damage.
Visual Inspection Chart Mechanical Electrical
  • Convertible top brackets and frame
  • Hydraulic motor and pump
  • Hydraulic lift cylinders
  • Hydraulic lines
  • Bussed electrical center (BEC) fuse(s):
    • 13 (40A)
    • 51 (10A)
  • Circuitry
  • Convertible top switch
  • Smart junction box (SJB)
  • BEC
  • Convertible top raise relay
  • Convertible top lower relay
  • Left or right rear power window motor
  1. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step.
  1. If the cause is not visually evident, connect the diagnostic tool to the data link connector (DLC) and select the vehicle to be tested from the diagnostic tool menu. If the diagnostic tool does not communicate with the vehicle:
    • check that the program card is correctly installed.
    • check the connections to the vehicle.
    • check the ignition switch position.
  1. If the diagnostic tool still does not communicate with the vehicle, refer to the diagnostic tool operating manual.
  1. Carry out the diagnostic tool data link test. If the diagnostic tool responds with:
    • SCP or ISO circuit fault; all electronic control units no response/not equipped, refer to Section 418-00 .
    • No response/not equipped for SJB; refer to Section 419-10 .
    • System passed, retrieve and record the continuous diagnostic trouble codes (DTCs), erase the continuous DTCs, and carry out self-test diagnostics for the smart junction box (SJB).
  1. If the DTCs retrieved are related to the concern, go to the Smart Junction Box (SJB) Diagnostic Trouble Code (DTC) Index.
  1. If no DTCs related to the concern are retrieved, GO to Symptom Chart .
  2. do you know what DTC'S - diagnostic trouble codes are ?
  3. Smart Junction Box (SJB) Diagnostic Trouble Code (DTC) Index DTC Description Source Action B1141 Convertible Top Full Down Position Switch Circuit Failure SJB Go To Pinpoint Test E . B1142 Convertible Top Full Up Position Switch Circuit Failure SJB Go To Pinpoint Test E . B1402 Driver Power Window Down Switch Circuit Failure SJB Go To Pinpoint Test A . B2068 Convertible Top Up Output Circuit Failure SJB Go To Pinpoint Test A . B2069 Convertible Top Down Output Circuit Failure SJB Go To Pinpoint Test A . B2481 Convertible Top Up/Down Switch Fault SJB Go To Pinpoint Test A . B2578 Passenger Power Window Down Switch Circuit Failure SJB Go To Pinpoint Test A . All other DTCs - SJB REFER to Section 419-10 . Your best bet , take it to a qualified repair shop , before you short out the smart junction box .
  4. $336.54 then 300 bucks to program at ford
Feb 16, 2018 | Cars & Trucks
I have a 2007 mustang convertible top that will not go down. with key on windows go to park down position but no hydraulic pump sound checking fuses to ensure good power. where should i begin?
Convertible top operation is controlled by the smart junction box (SJB). When the convertible top raise/lower switch is operated, the SJB commands the front and rear windows to the full down position. Window operation is disabled while the convertible top raise/lower switch is being operated. When the SJB receives a full down input for both rear windows, it commands the appropriate relay closed to raise or lower the convertible top. If the SJB does not receive a full down input signal for both rear windows, the convertible top operation is disabled.
The convertible top hydraulic system uses a 12 volt reversible pump and motor assembly. When active, the pump uses hydraulic pressure to extend the hydraulic lift cylinders to raise the convertible top, or retract the hydraulic lift cylinders to lower the convertible top. The convertible top motor/pump assembly is equipped with a thermal circuit breaker. The circuit breaker typically resets after 5 minutes depending on the ambient temperature. The thermal circuit breaker cannot be repaired and must be installed as a unit with the motor/pump assembly. In the event of a hydraulic system failure, the convertible top cannot be operated manually.
Inspection and Verification
  • Convertible top latches
  • Convertible top pump and motor assembly
  • Hydraulic lines
    • 13 (40A)
    • 51 (10A)
  • Circuitry
  • Convertible top ajar switch
  • Connector(s)
  • LH or RH rear power window motor
  • BEC
  1. If the cause is not visually evident, connect the scan tool to the data link connector (DLC) and select the vehicle to be tested from the scan tool menu. If the scan tool does not communicate with the vehicle:
  1. If the scan tool still does not communicate with the vehicle, refer to the scan tool operating manual.
  1. Carry out the scan tool data link test. If the scan tool responds with:
    • CAN or ISO circuit fault; all electronic control units no response/not equipped, refer to Section 418-00 .
    • System passed, retrieve and record the continuous diagnostic trouble codes (DTCs), erase the continuous DTCs, and carry out self-test diagnostics for the SJB.
  2. Smart Junction Box (SJB) Diagnostic Trouble Code (DTC) Index DTC Description Source Action B1141 Convertible Top Full Down Position Switch Circuit Failure SJB Go To Pinpoint Test E . B1142 Convertible Top Full Up Position Switch Circuit Failure SJB Go To Pinpoint Test E . B1402 Driver Power Window Down Switch Circuit Failure SJB Go To Pinpoint Test A . B2068 Convertible Top Up Output Circuit Failure SJB Go To Pinpoint Test A . B2069 Convertible Top Down Output Circuit Failure SJB Go To Pinpoint Test A . B2481 Convertible Top Up/Down Switch Fault SJB Go To Pinpoint Test A . B2578 Passenger Power Window Down Switch Circuit Failure SJB Go To Pinpoint Test A . All Other DTCs - SJB Refer to Section 419-10 .
  3. Your best bet ,take it to a qualified repair shop !
Nov 05, 2017 | Cars & Trucks
Convertible roof mechanism will not close roof? What is cost?
For what car?
Make and model?
If in UK "Please call us on 01306 885566 to arrange - we are able to diagnose the fault and give an estimate on the cost of repairs prior to commencing the work." and follow link below.
If US ("
Our support email address is support@mtmfg.com
On line ordering for your convertible top or for convertible top products and accessories is based on our secure and protected site. You may access information by selecting your convertible car in the list above. You will be taken to full information and a most secure ordering page. For telephone orders (orders only please) you may call 800-999-2892.
") and link below.
Free DIY? Youtube is your friend. Ebay for parts?
Mini Cooper Convertible Top Repair Part 1 Convertible Hood
Repairs Cayman Auto Services Vehicle Repairs
Convertible Tops and Convertible Top Parts
Feb 11, 2015 | Cars & Trucks
I have a 93 M/Benz SL500 having problem with the convertible top. The switch for activating the convertible top lights constantly and when driving, a terrible warning noise occor. Everything seem to work...
look around your convertible top and its like you have problem with the black seal some thing there make your convertible top not close good . try look again and i hop you found the problem . look good .let me know .
Nov 16, 2011 | Cars & Trucks
Convertible top won't go back up, can you help?
IT is probably a fuse. Does it work at all? my mustang had a busted cylinder and only 1 side would go up. If it doesnt work at all then check your fuses. With no manual you will have to use a flashlight and shine on them and see if one is blown. IF they all look good then I would go buy a testlight for about $10 and manually check the fuses for power. It oculd be the motor, however that will cost you several hundred dollars and that is if you install it yourself.
Oct 06, 2009 | 2001 Ford Mustang
The convertible roof leaks and also needs a
If you need a manual, you need a factory manual. Aftermarket manuals seldom address the convertible top.
Convertible tops seldom leak till they are 5-6 yrars old unless the material is defective.
Your problem is probably weatherstrips.
Either they are damaged or out of place.
Door window adjustment will also cause a leak at the weatherstrip.
If the water is in the rear of the car, you probably have plugged drains.
Convertibles leak at the rear from new. there is a gutter that directs the water to drain holes near the rear wheels. If the drains get plugged, the water will seep into the rear carpet or trunk.
Solution...clear the drains.
Karl at topgunwon.com
Sep 30, 2009 | 1998 Chrysler Sebring
I am renting a Pontiac Solstice convertible. I
Follow this link to Pontiac site...scroll down to Solstice user manual, download it. Convertible top instructions are on page 92
http://www.pontiac.com/manuals/
Sep 05, 2009 | 2007 Pontiac Solstice Convertible
Convertible top won't go down on my 1998 bmw 323ic
Sounds like the sensor has faulted or the pump has become disengaged. Usually when the light is flashing it's a sensor. You can check for a pinched line or low fluid also. There is a manual lock overide procedure to get the windows up, it's in you owners manual.
Good luck...i hope this helps,
May 27, 2009 | 1998 BMW 3 Series
How to raise and lower the 328ci convertible top manually
I just bought a 1996 328iC (the "C" is for convertible). I bought the car with the knowledge that the roof needed a motor replacement (~$300 for the part alone + ~1-2 hours labor) and that I would need to open and close the roof manually if I wanted to take advantage of the convertible part of the car.
After some trial and error, I figured it out and now it takes me <30 seconds to open or close the top (manually). Note: my top is a semi-electric roof, which I think is what came on the 328iC, you have to lock into place after you close it.
Here's what you do:
1- open all of the windows
2- unlock the roof by turning the latch between the sun visors.
3- push the front of the roof towards the rear of the car - be sure to push in the middle of the roof, where the latch is.
4- lift the back of the roof up off of the roof storage compartment
5- while holding the back of the of the roof up, lift up the roof storage compartment door
6- let go of the back of the roof so that it drops right into the storage compartment
7- push the rest of the roof into the storage compartment
8- close the storage compartment door.
To close the roof, follow the steps above in reverse order. Remember: this is a German car, so you use a little bit (or a lot) of force and you won't hurt it (I think it actually likes it ;-D ).
Good Luck!!!
Roman
Sep 01, 2008 | 1997 BMW 328
Baby Gear Logo
29 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Marvin
Marvin
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
