Question about Samsung SPH-a620/VGA1000
SAMSUNG SPH-a620/VGA1000 = Won't power on at all!
The battery is fairly new. I was on the phone talking & it all of a sudden turned off & completely powered off on me. It's never powered back on since. I put it on the charger and the outside screen will kind of light up, but the charging light doesn't come on like normal. I've also tried charging it in my car with no luck. Don't know if I should bother buying a 3rd battery for it or just get another phone......
  • 983 Answers
Ya try wit another battery it will surely work ....................
Posted on Feb 10, 2008
The tip of my AC charger broke off on the contact post of my samsung sph-a620. A new charger cannot make contact for recharging purposes. I cannot see how to disassemble the phone to access that electrical...
To disassemble the phone, you need to get he appropriate screwdrivers and follow the processes below;
  1. Turn your phone over so the battery cover is facing you. Remove the battery cover and battery. Next remove the 2 rubber stoppers and unscrew the aerial.
  2. Remove the screws,
  3. Next remove the 2 rubber stoppers & screws above the main screen,
  4. Prise the back part away from the rest of the phone by running your fingernail between where the two parts meet,
  5. Unclip the ribbon,
  6. After removing the ribbon cable, carefully lift the metal part. Another ribbon will be attached which should be carefully removed. Take the circuit board & keypad out and you'll be left with just the screen and the keypad rack.
  7. On the circuit board, you'll see the charging port and the broken charger that is in it.
  8. Try to pick it out with a pincher, and if you cannot, then you have to replace the charging port.
  9. Disconnect the charging port and replace it with a new one.
  10. Reverse the process to reassemble the phone back together.
  11. Take care.
Jun 22, 2010 | Samsung SPH-a620/VGA1000
Locked phone
you can try the codes 1234 or 0000 those 2 are usually the company codes to unlock the phone.
Jul 26, 2009 | Samsung SPH-a620/VGA1000
Cant get pics off the phone
If you have a memory card installed on the phone and the photos are on the cards memory and not the phone memory, simply remove the card, place in in an approprate card reader on any computer, and you should be able to tranfer the photos. However, if the phone is not a GSM device, or does not have a memory card, you are pretty much out of luck.
Jul 22, 2009 | Samsung SPH-a620/VGA1000
Need to retrieve pictures from a broken flip phone
You will have to get a usb cord and a downloading program like bitpim from bitpim.org Then you can transfer them onto a computer
Apr 03, 2009 | Samsung SPH-a620/VGA1000
Possible battery issues
if the samsumg unit hang on.... reprogrammed the unit to refresh the memory of the unit... it always happen when the memory of the phone is almost used...to much file or phothos or videos been save....another option if wont charge try to check your charger if okay ccheck your battery , if you notice your battery has bloated size then replaced it...also try look your battery locks if still fit to the battery terminal..
Feb 23, 2008 | Samsung SPH-a620/VGA1000
My Phone says: Phone locked return for servicing
Maybe you need to re-register, or get a new simcard
call support or the cingular website.
Dec 26, 2007 | Samsung SPH-a620/VGA1000
Samsung A620
handy phones always have hole for the microphone or we called it mouthpiece.. if someone cant hear you, but you can hear them.... the best of it change your microphone or your mouthpiece
Dec 22, 2007 | Samsung SPH-a620/VGA1000
Samsung SPH-a620
to reset your phone.. got to menu area look for the settings find the master clear or reset settings and if the phone aasking for the code strike the key number zero, seven times... but if the code is invalid try the security code that you log...if
Dec 19, 2007 | Samsung SPH-a620/VGA1000
Hard reset samsung sph-620
open phone....press menu...press 8...press 6...last but not least press 7.
Nov 06, 2007 | Samsung SPH-a620/VGA1000
Samsung SPH-a620/VGA1000 Logo
76 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
