Question about Denon AVR588 Receiver
No clear sround sound from my receiver
I have a AV3801 about 5 years old first i had very good sound and then after while start blowing my polk spekers almost 5 or 6 time till i am out of warranty i bougth new speakers but i don't have nice clear surround sound i am wondering if any thing wrong with my receiver
  • nadimk Feb 09, 2008
    even an expert installer come and set it up all the wire coected properly.
    what is level use 0?
    i am not sure what cable A or D please explain or call me the # is in my profile we can discues.
    Master:
    Sergeant:
  • 440 Answers
ALL CONECTION +- CORECT ect cheak al wires on speakers and reciver cheak level use 0
Posted on Feb 09, 2008
  • 1 more comment
  • nick helpap
    nick helpap Feb 09, 2008
    on main unit set all speaker levels at 0 only in main manus what cables are uusing also digital or analog
  • nick helpap
    just cheak on back of sterio macke sure red going in postive black going in negitives ok
  • nick helpap
    if these are crossed and u crank it it wil blow stuff or on the speaker terminals
Hello, I am inquiring about a replacement antenna for my Polk Audio SR H1000 Sirius satellite tuner. Thank you, Donna Sebran
It sounds like you should be able to find a replacement antenna from any of your local electronics retailers, such as Best Buy, Radio Shack, etc. I would take your old antenna with you when you go to look for a replacement, though, to make sure that the plug that is on the end of the new antenna looks exactly like the plug on the old antenna, to be sure that it'll work for your needs.
Oct 17, 2010 | Polk Audio SR-H1000 SIRIUS Radio Receiver
DSW PRO 600 not getting signal from receiver. Why?
You don't name the electronics, which can be the source of the problem. See #3.
1. If you suspect the cable why don't you just swap in another RCA cable? BTW: there's no such thing as a "subwoofer" cable. Monster makes their money on those beliefs. Cables don't wear out but they can go bad if one or more conductors fails. Oxides devolp at either end which can inhibit conductivity. Remove each end and reinsert it with a twisting motion.
2. Maybe. You need to ensure the sub is defined. Run speaker level check. If no sound at the sub, prove the LFE/sub channel has output by running the RCA cable to a recorder or your TV (low volume). If there's no signal, duh, no speaker will work with it.
3. Mmm, not if it's exhibiting the same problem as the old one and the Polk 450. Have you looked at the setting of the Standby/Auto/On Switch? And the Power Mode LED's? Red is bad.
Mar 31, 2010 | Polk Audio DSW PRO 600 Subwoofer Speaker
Blew a fuse what kind dose it take is it a slow blow fuse or fast blow one,i took out the old fuse and it reads le.3a/250v is it a 3a or .3a
It is a 3A/250V fuse, also known as a 6A/125V fuse.
Power amps generally have slow blow fuses.
If this is helpful, please be sure to hit the "Thumbs-Up" for me!
Jan 24, 2010 | Polk Audio PSW202 Subwoofer
Hey , with the Onkyo TX-NR1000 can I get started plugging two speaker while I gather enough money to buy the surround sound speakers. Also your opinion on speaker choices is greatly appreciated. Thank you.
Sure you can only connect 2 speakers. As for brand recommendation Polk audio makes some fine sounding speakers also Klipsch, Boston acoustics, too many to suggest. If you have a Best Buy near you they usually have a speaker room with many different brands that you can listen to. Though that doesn't mean you have to buy them their. I'm partial to Polk audio though. Polk has excellent customer service. That's going to be a tough decision you should really do some research on the internet for cost to quality references. Good luck. I hope this gets you pointed in the right direction.
Nov 24, 2009 | Onkyo TX-NR1000 Receiver
I have a Polk home surround sound system problem
Need to know the model no of the Polk sound system to assist.
Jun 21, 2009 | Polk Audio SurroundBar Center Speaker
I purchased onkyo 606 receiver and Polk RM85 speakers and Polk PSW110 subwoofer. When I turned the volume on my receiver to max, the system shutdown. When I turned it back on, the sound is very low from...
Sounds like you popped the voice coils in the speakers when you overloaded the old receiver. The system shut down to protect the speakers, but it didn't shut down in time.
Time for new speakers or to have the old ones re-coned.
Good luck
Jan 04, 2009 | Audio Players & Recorders
Yamaha RX-V2700 skipping when playing a DVD on Toshiba D-R400
Sounds like a poor grounding issue between the units OR maybe they're not as compatible as the Mfg's say.
Could be a bad HDMI cable also. Most are made in the land of Nanking
Jan 18, 2008 | Yamaha RX-V2700 Receiver
Onkyo TX-SR304
Onkyo offers access to manuals at their web site. HERE is a link to the receiver line.
Personally, I'd connect the speakers to main left/right. The subwoofer to subwoofer out. The Go VIdeo unit to VCR/Video 1, the cable box to Video 2 and the video output to the Sony TV composite input. No need to connect the TV audio out to the receiver since the audio feed comes from the cable box.
Jan 13, 2008 | Onkyo TX-SR304 Receiver
Setting up a Yamaha RX-V690 home theater system
you almost have the exact same situation i am in. i have the same receiver, and going to purchase a panasonic 50" (th50px75u). i think what i will be doing is running a hdmi from my hd cable box to my tv, and installing an audio cable (red/white) from my tv to the receiver. i believe there is an audio input below the hdmi insert. i have polk audio, but theyare about 10 years old, they sound great, but just too large....and may be purchasing a harman kardon system. which models do you have from polk? i have the rt16's, cs350ls center, and fx/500 rears. let me know what you have come up with as well...as it has been a while since you posted this.
cheers,
sean
Nov 05, 2007 | Yamaha RX-V690 Receiver
Static and crackling sounds
Sorry to burst your bubble my freind but things do wear out as you had plenty of life out of this unit.. Your problem is a transistor or a driver IC is breaking down under a load and heat and will get worse to where you wont be able to use the unit.. It will probable cost you in a range of 200 bucks or .more!as there is no quick fix for a solid state unit that has no user serviceable parts inside. Its just not replacing the bad part , its the hooking up to the load resistors then seeing that several other parts are not up par and having to start rebuilding the amp statges of your reciver.. If its more then 8 years old Time to landfill it and get a new one .. Put it to rest. It dosent owe you anything as its been loyal to you all these years!! Good Luck
Jul 27, 2006 | Pioneer VSX-D3S Receiver
Denon AVR588 Receiver Logo
60 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
