Question about Durabrand Portable DVD
Fuse Keeps Blowing In Car Plug
As soon as I plug it into the 12v outlet in either of my cars the fuse blows. The fuses are 250v 2.5 A (recommended kind) but it isn't working. We bought the unit new and used it for a few hours on vacation (one day) and after that it would blow the fuse every time we plugged it in.
House outlet works fine (of course, no fuse there).
    Champion:
  • 303 Answers
Try using a 3a or high fuse
You can buy a new car adapter by clicking on the hyperlink:
buy replacement car adapter power charger cord for Durabrand DUAL 7" dvd player
Posted on Jun 01, 2009
2004 Chevrolet Aveo hatchback - lighter/12v outlet fuse blows
it sound to me like the lighter plug itself is loose and when you released the parking brake wiggled the plug enough to short out and blow the fuse . check to see if the plug is loose .
Apr 20, 2013 | 2004 Chevrolet Aveo
KLH ASW8 Powered subwoofer keeps blowing 3A-250V fuses
The transistors at the output stage of the sub amplifier circuit might be shorted so each time you power on, the circuit draws a very high amount of current which causes the fuse to blow. It's definitely a problem with the circuit so using a higher current rated fuse would probably just result in damaging the amp even more. You should ask a qualified electronics technician to take a look at it. I hope you can fix it.
Oct 17, 2012 | KLH ASW8100 Subwoofer
Number 21 fuse keeps blowing vw tiguan 2009
check the bulb it may be shorted out try new bulb and see if fuse stops poping if it does not the you have a shorted wire
Aug 25, 2017 | Cars & Trucks
Panasonic DMR-EZ48V keeps blowing fuses.
I don';t like to replace fuses with the power on. the fuse is meant to protect valuable parts; this error mode indicates a probable fault internnaly. NEEDS to be serviced.
Apr 07, 2012 | Panasonic DMR-E55 DVD Recorder
Sonance ASAP1 2 channel amp/switcher keeps blowing fuses. I'm using the 1A-250V slow burn fuses like it states on the rear panel. I plug it in and it instantly blows the fuse.
If fuzes burn out at connection to computer , that necessary to check:
1 Presence of the earth between body PC and amplifier.
2 Levels of the signal at the input amplifier must be minimum.
Jan 03, 2011 | Sonance ASAP1 2-Channel Amplifier
12v outlet fuses keep blowing.
Faulty reciever ,,, Worth checking the plug assy for internal damage . Check that the sat receiver is within the power capabilities of the vehicles acessory plugs < 10amp .
Dec 23, 2009 | 2004 Ford Ranger
The fuse keeps blowing in my marantz pm-57 amplifier. It says it takes a T 2.5A 250V fuse. I can only find 2.5A 250V fuses. What relevance is the ''T''.
Goo day sir, the T on the fuse has nothing to do on you marantz fuse blowing up, chances are you amplifier is shorted, check you IC amplifier/power transistor for shorts. Check also your speaker impedance. usually they are 8 ohms. You can use a technician's multitester device to check the impeadance. An imbalance or mismatch speaker can cause a fuse to blow and destroy your amplifier. hope this helps.
Jul 31, 2009 | Marantz PM-15S1 2-Channel Amplifier
12v fuse keeps blowing
one of the power wires for either device is grounding out. trace the positive 12v wire and you will find a crimp, cut, or missing insulation im sure.
do you have anything cut in to that circuit that isnt factory installed? That could cause a circuit overload.
Mar 03, 2009 | 1994 Ford Mustang
Durabrand Portable DVD Logo
332 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
