Question about RCA R52WM24 52" HDTV Projection Television
Tv model r52wm24
Fuse link f231 keeps blowing how do i find and fix problem
  • tonica3535 Jul 10, 2008
    when the tv turns on everything is skewed and triples in red blue and green
  • BALLGAME13 Aug 15, 2008
    i also have this same problem tv is only 16 months old!!! mine is chassis #itc222 s# g2750no55 have talked to a rca repair guy and he said could be with parts and labor and his road trip about 250 bucks but if it is also the power supply then were in the 450 range, as of tonight my tv now turns on and off when it is left on for a hour or so, any help would be great,paid 900 bucks for it in 2006 but i hate to spend 400 bucks to fix it and have problems down the road with it, and rca was no help just gave me a number to a service center,hate to just pitch it, but that looks like whats going to happen.
  • RCA Master
  • 8,617 Answers
RCA tvs have to be diagnosed by the Chassis number. Please repost the chassis number and I may be able to help you out.
Posted on Feb 09, 2008
My screen shows 3 colors what do i do?
you haveing convergence issues. first question. in your customer menu under setup. do you have the conergence option if you dont i suspect the f231 fuse problem.. read this... http://www.fixya.com/support/r1062030-fl231_problem_convergence_not_in if this dont apply you may have to replace some faulty components in the convergence curcitry. let me know how it goes
Oct 22, 2010 | RCA R52WM24 52" HDTV Projection Television
Need part number for f231 fuse HD52W59 TV set
you can get the FL231 at the following link.
http://servicemanuals.vstore.ca/
But you will also need DL231 and CL230 or the new FL231 will blow shortly after installing it.
Aug 02, 2009 | RCA R52WM24 52" HDTV Projection Television
RCA R52WM24 52 in TV
the RCA service bulletin says to replace FL231, DL231 and CL230 all at the same time then reflow the solder on the flyback and the vertical output IC
Feb 07, 2009 | RCA R52WM24 52" HDTV Projection Television
Fuse keeps blowing R52 WM24 tv
you need to replace DL231, FL231 and CL230 all at the same time then resolder the flyback and vertical IC, You can get the parts under the RCA category at the following link, and they provide instructions on how to do the repair.
Did you get an aswser on the IC's?
THe rca itc222 chasis has No convergence ics it uses a series of transistors to do the same. YOU replaced the Fl231 fuse and it blew. Did you resolder flyback connections. this is why the fuses blow. check out the article under the tips and tricks section written by me willtab ... see if this helps if not let me know .. i see alot of these at the shop ( i got one right now in front of me with the FL231 probelem LOL) if can let me know i give you help
Sep 15, 2008 | RCA R52WM24 52" HDTV Projection Television
Tv model r52wm24
You most likely need a new convergence power supply board if fl231 keeps blowing thats the most likely cause, also check for shorthed capacitor cp231. If you need a link to get a replacement convergence power supply board, let me know I know where you can get them.
Jul 19, 2008 | RCA R52WM24 52" HDTV Projection Television
Blurry screen replacing f231 fuse link
i have the same problem does anyone have a solution????
Jun 09, 2008 | RCA R52WM24 52" HDTV Projection Television
Location of convergence IC's in R52WM24
i have the same problem where is the fusible link i replace 2 boards and a connector (t.v. repair man can and diagnoised the problem but did not fix it)
Feb 02, 2008 | RCA R52WM24 52" HDTV Projection Television
I have three
I had the same problem. Thanks to the many posts on this site I was able to deduct that it was the Fusible Link F231. (See other posts about convergence problems) Was able to purchase them at mouser.com. Part# 576-3960400000 Littelfuse Fuses - A 125V UL TL LL .400A . They are only 55 cents plus shipping. I bought 5 for under $10 shipped. Only took 2 days to get them. Replaced it (needs to be re-soldered to board) and TV works like a charm!! I couldn't believe it. What a lifesaver!! Now I'm set if the fuse goes again...
Good Luck!
Jan 01, 2008 | RCA R52WM24 52" HDTV Projection Television
Double vision and no convergence
I have found that fusible link FL231 is the main cause of this problem. It's located by the high voltage transformer and looks like a square coil.
Check it with an ohm meter and if it checks bad, then, replace it and you should not have to realign the convergence.
Any questions or comments, respond to this post and I will reply.
RCA R52WM24 52" HDTV Projection Television Logo
152 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
