This is a problem occurring in all the play station 3consoles....... .....as a result it leads to the damage internal softwaresystem ......................it will heat up ur entire system ... its better todownload this Repair Guide for further information .........
CLICK HERE to download
Www.mrrepairit.com 407-668-3751 repairs blu-ray DVD discs & ps3 consoles.. Good luck!
SOURCE: ps3 jammed disc
Unfortunately their is no step by step or guaranteed method to fix this. Here are a few things you could try: turning it off and on, press/hold the eject button, resetting while holding the eject button, shaking or tapping it a little while trying to eject it, holding it different ways ex. face disc opening down towards floor while gently tapping and pressing the eject button. Essentially do whatever you can to get the disc to jar loose, >but whatever you do, don't for any reason stick anything in the slot or try to open the case <Doing this will void the warranty for sure! If none of these work your last resort would be to return it for a new one (providing you still have your receipt and it's less than a year old) or take it to a costly repair guy.
SOURCE: My PS3 won't play PS3 Games
I called Sony and they helped me resolved this same problem...
1. Turn off the ps3.
2. press down on the on/off button on the front of ps3 while turning on the button from the back. DO not let it go until you hear 2 beeps and will show a red light.
3. press the on/off button again and do not let it go until you hear 1 beep, paused, and two beeps. Let it go.
4. There should be a prompt asking you what to do. If you have hdmi, answer all the question yes etc.
5 there should be a menu list asking what you need done.. setting wise..
6. Choose the # 3rd list (not sure how many they were).
7. IF it tells you that your data is corrupted etc.. just click ok
8. wait till progress ends ( if it tells your your data is corrupted again, just click ok again).
9. It's going to do some loading again...
10.. end of restoring and you should see your ps3 menu..
