Question about Nintendo Wii Console
Console the problem?
Had the Wii for 4 weeks i know the remote works the sensor works and the cables are working as used a friends console to test it. But when i plug my console in the reomote doesn't register, please help very frustrating what is my problem?.....
And yes i've tried sync the console and the remote.
Game stuck in wii system
Posted on Feb 09, 2008
Wii controller is not working, no lights at all coming on
Try this following steps: 1. Check to make sure the Sensor Bar cord is inserted into the back of the Wii console and the Sensor Bar is centered above or below your TV screen. 2. Make sure you are using fresh batteries in the Wii Remote. 3. The Wii Remote Controller should be used between 3 to 10 feet from the TV. 4. Make sure no objects are blocking the signals between the Sensor Bar, the Wii console, and the Wii Remote. 5. Check for interference from infra-red light sources, such as candles, sunlight, fireplaces, and stoves. 6. Radio frequency interference may cause the Wii Remote to work erratically.
Mar 30, 2011 | Nintendo Wii Remote Controller
Our Wii remote hand is not appearing on the screen. We don't know what to do?
Make sure all devices are connected to the Wii Station correctly and securely. Make sure the batteries in the wii-mote are working and the light is on.
Trying moving the wii-mote sensor to the top of the TV if its on the bottom or vice versa and try again.
If none of that works try bringing the wii-mote to a friend who has a console and trying it there, if it doesn't work then there might be something wrong with that wii-mote. If it works then ask someone to bring a wii-mote to your console and try it, if that doesn't work then there might be something wrong with the console or the receiver.
Good Luck!
Mar 11, 2011 | Nintendo Wii Console
Wii hand will not show up we tried syncing, taking out batteries, unplugging and plugging sensor bar and nothig works
Synchronizing the Wii Remote with the Wii Console Synchronizing the Wii Remote to a Wii console allows the Wii Remote to communicate with the console. The Wii Remote included with your system should already be synchronized to your console. However, all additional Wii Remotes you use with your system also need to be synced in order to function properly..
There are two different modes of synchronizing (syncing):
  • STANDARD MODE - The Standard Mode procedure is used when adding additional Wii Remotes to your system or if you want to re-synchronize your original Wii Remote. Once synchronized, the Wii Remote will stay synced to the console unless you overwrite the settings by syncing the remote to a different console. For instructions on Standard Mode syncing, please click here.
  • ONE TIME MODE - This mode allows you to temporarily use your remote on a Wii console other than your own, or to use a friend's remote on your console. It can also be used to change the order of the Wii Remotes, without the need to turn off the Wii console. One Time Mode does not delete the Standard Mode setting stored in the Wii Remote. In this mode, the Wii Remote will only communicate with the Wii console while the power is on. When the power is turned off, the Wii Remote will lose its sync with the Wii Console. For instructions on One Time Mode setup, please click here.
Note: Only a Wii Remote in Standard Mode can turn the Wii console power ON or OFF.
    Standard Mode Synchronization
    Note: Make sure you have placed batteries in the Wii Remote (how to).
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED will blink. Quickly press and release the SYNC button on the inside of the SD Card compartment on the console.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
  5. wiiremotesynchstandard.gifThis procedure must be followed for each additional Wii Remote added to your system.
    Go to the Next Step (Playing Game Discs) >
    One Time Mode SynchronizationNote: This mode temporarily removes Standard Mode synchronization setup for all Wii Remotes until the power of the Wii console is turned off. When the power is turned back on again, the Standard Mode settings will return.
  1. Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
  3. Select the Wii Remote Settings option from the Home Button menu.
  5. Select the Reconnect Option.
  7. Press the 1 and 2 Buttons at the same time on the Wii Remote that you want to synchronize with the console. If you are syncing multiple Wii Remotes, press the 1 and 2 Buttons on each Wii Remote immediately (without a significant pause) in the order you want them synced. The order in which you synchronize Wii Remotes determines the player order (1 through 4) for multiplayer games. The Player LED will blink during the syncing process. When the blinking stops, the connection is complete.
Jan 27, 2011 | Nintendo Wii Console
My handsets wont sincronise with the system, I have fitted new batteries
Follow this procedure:
1. Turn the Wii console on and wait until the "Health & Safety" screen appears (don't press A).
2. Open the SD Card slot cover on the front of the Wii console, just below the disc drive, and press and hold the red SYNC button for 15 seconds. This will clear all synced Wii Remotes from the console.
3. Resync the Wii Remote by removing the battery cover and pressing the red "SYNC" button. Do this for all Wii Remotes you wish to use, and test for proper response.
4. If the steps above do not work, remove the batteries of the Wii Remote and leave them out for at least 2 or 3 minutes. Reinsert the batteries and sync the Wii Remote again. Test for proper response.
If after removing the batteries for several minutes, and resyncing the Wii Remote, your still unable to get the Wii Remotes to work, try syncing another Wii Remote if available.
* If another Wii Remote works, then your previous Wii Remote will need to be repaired.
* If multiple Wii Remotes do not work, or you only have one Wii Remote, a repair of the Wii console is necessary.
Oct 20, 2009 | Nintendo Wii Console
Wii Remotes will not resync after using friends Fit Board
there is a flap in the wii open it up. open the spot where the batteries go on the controller. the controller and the wii should have a orange butten press them both at the same time.
Aug 20, 2009 | Nintendo Wii Console
Wii remote will not follow command.
It's problem a radio interference, since the wii controller uses radio frequences to contact the device, try to resync the wii controller.
Feb 09, 2009 | Nintendo Wii Console
Wii Console doesn't have any sound
Isn't there a menu for your remotes...my 5 year old likes to jack with the Wii alot and I have to "restore" it frequently...try it....
Jul 29, 2008 | Nintendo Wii Console
Remote malfunction
Do the LEDs light up when you press the buttons on the Wii Remote? Try simply turning off the console, and pressing the power button a couple times firmly on the Wii Remote. If it turns on the Wii, the connection should be established. If it doesn't turn on the Wii, some hardware is defective. Recommend calling Nintendo Support if this happens.
Aug 14, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
91 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
