Question about HP PSC 1210 All-In-One InkJet Printer
Printing bussiness cards
The printer was working fine till ,then all of a sudden i can,t print my bussiness cards any more .printing on normal paper is fine.
  • 3 Answers
Not useful. I use CardFila.com to collect all business cards on Iphone. You can do this on Android, computer, laptop.
So easy to collect, find and use any contact at any time.
You can access the contacts everywhere without Internet connection by using CardFila for Mobile
Posted on Oct 22, 2012
Printer software/driver of psc 1210 printer
Posted on Mar 10, 2008
I have an HP Photosmart A646 printer that I bought in the hopes of printing to 5x7 card stock. We have pre-printed card stock that we use for gift certificates and we need to be able to feed the card stock...
Thanks for visiting FixYa!
Depending on the program you are using to print your gift certificates, try this-
1) Open the program and open the file you use for your gift certificate.
2) Click on 'Layout' then 'Page Set Up' (probably found in the top menu bar by the right side of, FILE.)
3) Select 'Landscape' and then select, 'Custom'.
4) Enter 5x7 for height and width.
5) Enter the information you need in the data field, (ie, name address, etc.)
6) Select, Print.
7) When the 'Print Manager' box opens, click on, 'Properties'.
8) Click on, 'Type' and choose, "Envelope'.
9) Click on, 'Size' and choose 5x7. - and click, OK.
Your printer should have a slide where the paper is inserted. Place one of the 5x7 cards in the slot just as you would an envelope and slide the slider until it is 'close' to the card but not directly against the card.
Click, 'Print'. The printer should recognize the card (due to its thickness) as an envelope and print it.
Mar 19, 2011 | Office Equipment & Supplies
My hp officejet 7410 printer which has been working fine for a year suddenly will not print. after putting in new cartridges it printed out an alignment page. But still will not print a normal page. ...
Click on the Setup button,
Scroll till you find Tools - Press OK
Scroll till you find Clean Cartridge - Press OK
It will print an alignment sheet. Align the printer
If this does not work - try the Align Printer Option from Tools of Setup menu again from Printer front panel.
Let me know if none of these work.
Regards,
Shawn
Jan 31, 2011 | HP OfficeJet 7410 All-In-One InkJet...
Will not print evenly on cardstock business cards
This can be caused by the cardstock slipping to one side as it prints. Make sure when you print you are using the card stock settings found under your printer setup - paper type. Check to make sure that the paper you are usng is meant for your printer, most printers are meant for up to a certain pound of paper eg 120lbs. and going over this could mean that the paper is too heavy for your printer which causes the rollers to slip as it pulls the paper through your printer.
May 30, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Brother laser printer wont print on cardstock My brother printer won't feed teh card stock paper. It used to work but now it won't feed it, normal paper works fine. Even if i nudge the card stock paper,...
If there printer is not able to print on card stock then check the recommend
card stock paper thickness, if the printer works with normal paper but not card stock then there is problem in the card stock and by using this paper may also damage the rollers on the printer and make the printer useless ...
Good luck...
Feb 09, 2009 | Brother MFC-5840CN All-In-One InkJet...
I have a Dell 946 printer and Im trying to print Avery 8871 business card sheets. When I press print the printer will not feed the sheet through and it says there is no paper. I tried to adjust the...
I looked up the user guide at Dell's website and looked up printing cards.
  • The print side of the cards faces down.
  • The cards are centered on the paper exit tray.
  • You select Automatic, Normal, or Photo print quality.
  • Apparently you need to feed the card stock one page at a time into the printer on TOP of the paper exit try (The card stock will feed in from above the normal paper load try [remove paper from the paper tray] and once printed come back to the same spot.
    Jan 26, 2009 | Computers & Internet
    Epson RX500, Paper Jam - printing couldn't start
    Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button, applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time. Worth a try. I have fixed a number of printers this way saving costly repairs. Bud
    Jan 06, 2009 | Epson Stylus RX500 All-In-One InkJet...
    My printer has suddenly started printing terrible quality photos
    I discovered I had switched photo paper in the process. The new paper obviously isn't compatible with this printer. I went and purchased more of my regular paper and the pictures began printing well again.
    Dec 17, 2008 | HP Photosmart C5180 All-In-One InkJet...
    I cant print on cds
    clare.... are you putting the actual cd into the printer ?
    Robert
    Sep 18, 2008 | Epson Printer
    Dell 924 All-In-One printer
    Below are the various sizes and types of paper supported by your printer. Make sure you donnot load the tray beyond the maximum limit , otherwise the rollers may not pull the paper correctly
    • Letter*
    • Legal
    • B5
    • A4
    • A5
    • 3x6
    • 4x6
    • L
    • 2L
    • 5x7
    • Hagaki
    • 10x15 cm
    • 13x18 cm
    25 greeting cards,
    index cards,
    postcards, or photo
    cards
    • The print side of the cards faces up.
    • The cards are centered on the paper support, in between the left and right
    paper guides.
    • The paper guide rests against the left edge of the cards.
    • You select Normal or Photo print quality.
    25 sheets of photo
    or glossy paper
    • The glossy side of the paper faces up.
    • The paper is centered on the paper support, in between the left and right
    paper guides.
    • The paper is loaded vertically against the right side of the paper support.
    10 iron-on transfers • You follow the loading instructions on the packaging.
    • The blank side of the transfer faces up.
    • The transfer is centered on the paper support, in between the left and right
    paper guides.
    NOTE: For best results, iron-on transfers should be fed one sheet at a time.
    50 transparencies • The rough side of the transparencies faces up.
    • The transparencies are centered on the paper support, in between the left and
    right paper guides.
    NOTE: You can load a single transparency into the paper support without
    removing plain paper.
    Apr 15, 2008 | Dell 924 All-in-One InkJet Printer
    Paper will not feed properly/one side of paper not feeding in straight
    hi,
    CANON PIXMA MP160 All-In-One InkJet Printer
    has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
    http://www.canon.com/printer/prob676ijt65/solution
    542
    Dec 04, 2007 | Canon PIXMA MP160 All-In-One InkJet...
    HP PSC 1210 All-In-One InkJet Printer Logo
    54 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
