Question about V-Stream Xpert USB 2.0 DVD Maker (TVKWUSB2800D)
USB 1.0 or 2.0
I have a PC with Win XP built around march 2002. (1) How can I tell if I have USB 1.1 or 2.0 . (2) In device manager the u s b has a ? and drop down ... line and another ? (3) What does that mean
can you help
thanks
Len
  • 112 Answers
Just get a pci card at walmart or any computer store. They are cheap and usually have 3 to 5 usb 2.0 ports. most come with the drivers you need. Put it in the white pci slot inside your computer, like where a dialup modem would go.
Posted on Feb 10, 2008
Quick way to find out is plug in device such as phone or usb flash drive, mine tells me that flash drive can preform faster with 2.0 so I'm guessing that mine is 1.0....
Posted on Feb 09, 2008
No webcam detected. If you are using an integrated camera, make sure that it is turned on
You are using a device which works only with Win-Seven OS or higher. I've got the same problem with my optical mouse (without cable) .... Try to re-install your camera's driver in your pc... if this doesn't works... try to install your camera in a PC or Laptop with Win-Seven OS
#NZ
Nov 10, 2013 | Averatec Computers & Internet
Wound up reformatting the hard drive and installed Windows XP Pro 64-bit. But am missing correct drivers for the modem. It does not even show up in device manager
Hi activebiz,
I see you re-installed Windows on the machine with Win XP Pro 64bit but you are having issue with the driver as mentioned.
If I may ask before you installed win XP 64bit did you have win XP 32bit?
If so then try downloading a driver for a 64bit version to make the Modem driver work, having an Incorrect version of the driver will really not show up in device manager, and make sure the driver you are downloading is the correct driver.
You did not mentioned the Brand of the Machine or Motherboard that you have and the modem that you need a driver for is that a built in Modem on the Motherboard or is that a modem external provided by your Internet Provider.
Jul 17, 2011 | Computers & Internet
My usb ports are not recognizing any devices such as my iphone, ipod, etc. I have a dell dimension 4700 runnning win xp sp3
It seems that many people are still getting the 'USB Device not Recognized' problem from time to time. Unfortunately there is no easy fix.
Firstly, it's recommended that you make sure every one of your motherboard drivers are completely up-to-date, but you probably already knew that.
In XP, after a USB port isn't used for a long while the USB driver built into the OS sets the OHCI controller to suspend. When you plug a device back in, it can sometimes fail to 'wake up' properly. This problem was supposedly fixed in SP1 but there is a related registry hack that may still be able to help.
Run regedt32.exe and navigate to;
HKEY_LOCAL_Machine\SYSTEM\CurrentControlSet\Services\Usb
Create the Usb key if it doesn't already exist. Under this key, create a new DWORD value called DisableSelectiveSuspend and give it a value of 1. Then restart the PC.
A long shot perhaps, but I recall having similar problems with a USB hub built into my Microsoft keyboard and adding this key seemed to solve it. It wouldn't hurt in trying icon_smile.png.
Alternatively, removing all entries relating to USB in Device Manager and all associated USB drivers will force XP into refreshing the USB driver stack.
Begin by unplugging all USB devices, then use Add/Remove Programs in Control Panel to uninstall any USB driver software. Next, boot up into safe mode and go to Device Manager. Once in device manager make sure 'Show hidden devices' is checked under the View menu. Uninstall all device entries in this order;
1. USB peripheral devices (printers etc.)
2. HID and/or Composite USB (Human Interface Devices) You're using PS/2 input devices so you may not have this entry.
3. USB Root Hub(s)
4. USB Host Controller(s) (Universal or Enhanced Host Controllers)
Then boot back into Windows (not safe mode) and it should populate the Root Hubs & Host controllers again. Proceed to plug your USB devices back in, starting with your powered hub. Be aware that most USB printers and scanners need to have their drivers installed first before you plug them in.
Any doubts you can get the help of a technician through
www.thebestpcdoctor.com
Toll free: 877 407 9229
Dec 04, 2010 | Dell Dimension 4700 PC Desktop
I have a sony laptop. The dvd drive only works sometime.I want to disable it and use one with my USB any help appreciated. James
You can go into the device manager (right click on my computer/manage/device manager)
Uninstall the dvd drive, when it tries to re install the drive stop it and you should be able to tick a box telling it not to ask to install this device again.
You can always remove the drive, this is usually just 1 or 2 screws under the base and pull it out
Jul 11, 2010 | Sony VAIO Notebook
I have TRANSCEND JETFLASH V10 (TS8GJFV10) 8GB USB, recently i have updated pc with win xp sp3 and it is not showing any flash derives when connected with PC..
1. Go to Start>> Right click My Computer>> Manage>> Device Manager 2. Expand the USB Controller section 3. Right click and Uninstall all of the listed USB devices 4. Reboot the system
Mar 02, 2010 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
Base system device and network controller driver error in device manager at win XP
"Base System Device" is your card reader, I had the same problem. If you dont use it jst disable the device, otherwise the drivers should be on your alienware Master CD, if not get a tech support guy to send 'em to you.
May 25, 2009 | Lenovo 3000 N100 CoreDT2080 VB PC Notebook
PCMICA/USB 2.0 not recognising usb devices
if it works on the onboard usb.
Theres a chance that either the pcmcia slot drivers are incorrect, or the actual slot is faulty.
Try it in another slot, if you have 1.
update any onboard device drivers. if applicable. try the card in a different laptop. to eliminate the card. alternatively, try a different card in the slot. wifi card et,c.
Mike @ compurepair.
Dec 16, 2008 | Compaq Armada M700 Notebook
USB not working on HP NX7010
Could be another issue dragging the data circuit down for USB functions. If you plug a USB device in with an LED on it does the light come in? If you have electronics or basic electrical knowledge also look to be sure the 5V supply is present. Ive seen Integrated modem/audio chips kill USB function as well as embedded controller chipset issues. Everything shows working in device manager? Try not mapping thru Modem and see if USB returns.. Yell back..
Feb 06, 2008 | HP Compaq nx7010 Notebook
Usb device not recognised
First try this OPTION:
Possibilities:
1) One of your USB devices have faulted, or is causing a resource conflict (or similar)
-- Remove all USB devices, and reboot.
2) Your USB chip/ports have been damaged.
-- Find a spare HardDisk or bacjup your data and re-install Windows and see how that goes.
3) Your Power Supply Unit (PSU) isnt supplying enough power to your PC (usually caused by a Video card upgrade). Try a more powerful PSU ... 400watts should do the trick
4) Bad memory (RAM) can cause wierd problems. run memtest for an hour to make sure your memory is ok
A long shot perhaps, but I recall having similar problems with a USB hub built into my Microsoft keyboard and adding this key seemed to solve it. It wouldn't hurt in trying .
3. USB Root Hub(s)
Hopefully some of this may be of help, let us know how you get on.
IF STILL NOT WORKING JUST BUY NEW EXTERNAL ( JUST EXTERNAL NOT HDD )
And rate me as fixya if u got help!
Dec 21, 2007 | Western Digital 500GB My Book World...
Averatec USB ports
Hi, A couple of things you can try: 1. In your Device Manager, un-install all USB instances then reboot. Win XP will auto detect and auto install back the USB drivers; 2. On reboot, again in your Device Manager, all instances of USB Root HUB, right click, click on Properties, Power Management tab, un-check "Allow the computer to turn off this device to save power." 3. Download, install and use to format flash drives the HP Drive Key Boot Utility (cp006049.exe) available at http://h18023.www1.hp.com/support/files/server/us/download/23839.html If for some reason none of the above will for you, you may need to install an external/powered multi-port USB 2.0 Hub. Hope this be of some idea/help. Post back how things turned up or should you need additional information. Good luck and kind regards.
Oct 05, 2007 | Averatec Notebook
Televison & Video Logo
133 people viewed this question
Top V-Stream Televison & Video Experts
Marvin
Marvin
Are you a V-Stream Televison and Video Expert? Answer questions, earn points and help others
