Question about Canon PIXMA MP530 All-In-One InkJet Printer
Cant install driver cd rom on computer
My cd rom drive wont open so i cant open it to install the driver on my computer for my new printer. Ive been trying to find a downloadable driver and software on the internet. The canon website doesnt have it there. I dont know how to install my printer without putting the cd in which i cant do. What do i do? If u look on the canon website it will have my printer but when i try to download the driver from the list there is no option there for me to pick which operating system i have. I'm out of options at the moment.
  • Meagan T Feb 11, 2008
    I went to that website on canon but when i press on the button to pull down a list of OS, just a blank white list comes down. There are no choices there for me to pick. The page doesnt refresh with options either.
  • SeekPCRepair DotCom
    SeekPCRepair DotCom May 11, 2010
    Hi Meagan:
    Pleas elet me know what model you have. I may be able to help.
    SeekPCRepair
    Brigadier General:
  • 6,966 Answers
Assuming that you have a Canon PIXMA MP530 multi purpose printer, to get hold of the driver/installer, pls click here. New window will show several guide files and "No firmware updates are available for this product." Nonetheless Select OS and click on your Operating System. Page will refresh with drivers, file name mp530vst110ej.exe. You must have Java installed and enable in your browser for this to work. Download and save in your PC. Click to open and install. Follow on screen instructions.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kindest regards.
Posted on Feb 10, 2008
  • Louie  Role
    Louie Role Feb 12, 2008
    Hi again,
    Did you install/enabled the Java plug-in for your browser?
    Pls try again and click here. Below is how it should look like
    If for some reason you cannot still access the file from the Toshiba
    website, the driver is also available from DriversGuide.com and
    membership is free (simply join). The filename is still mp530vst110ej.exe .
    Cheers.
Cd rom on windows XP wont work?
how old is the computer cd rom might be time for new one
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
or
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it if this fails you might try cleaning the lens it's already gone bad there is no harm in trying If you take a little risk can solve . follow the instruction: Don't panic its very simply. 1. When running your pc , open the drawer.> 2. switch off the ac power 3. remove power cable & sata or pata cable 4. remove all the screw from the back side 5. press clip to open the font panel 6. reverse the cd/dvd rw 7. just remove the cover 8. clean the optical lance 9. use a little( not much )oil place on two steel shaft 10.cover all the equipment 11.now you can fit to your pc Ifit does the same problem please change the cd/dvd rw because the lance has defected
hope this helps
Jun 12, 2012 | Computers & Internet
My ts-h652d driver wont read any dsks and my computer cant recognise the drive. when i go into computer managment the cd/dvdw drive has a yellow exclamation mark beside it, i tried uninstall and it trys to...
you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver roll back driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options update driver roll back driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer Close all open programs Click Start, Run, and type regedit and press Enter
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jun 10, 2011 | Computers & Internet
When i put in a cd or dvd my disc drive wont run it,i am trying to install a webcm but i cant.
you might have to physically unplug the leads for this cd/dvd drive restart your computer then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
click start control panel view devices and printers you should see your webcam from there
if you are have trouble with your webcam
click start control panel administrive tools ,computer management ,device manager scroll down image devices you could see a yellow question mark?
right click to reinstall drivers or update driver
hope this helps
Jun 05, 2011 | HP (228746-001) CD ROM Drives
Ive bought a dvd rom rw cge-8527b but when i put a cd in (dvd movie or dvd rom nothing happens the disc turn and stop no sign of it the icon stays the same
make sure that the cd rw is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rw then plug them back in this will activate found new hardware wizard
hope this helps or
you might have to uninstall then restart your computer then reinstall your cd rom or uninstall the driver then reinstall for this device
also
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives right click you can you will have options to update driver roll back driver select properties general troubleshoot select driver click to reinstall drivers click update driver uninstall then reinstall
you need only do the registry check if you cant see the drive/s in windows explorer/my computer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Mar 27, 2011 | LG (GCE-8527B) CD-RW Burner
My cd rom drive will not open ive tried the paper clip method and still wont open anything i can do please help
make sure that the cd rom is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
or it might be a registry problem
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
if you mean a driver for cd/dvd driver
if your computer came with a disk all the drivers should be on it (motherboard disc)
hope this helps
Jan 06, 2011 | Compaq (120192-B21) CD-ROM Drive
Need software to install hplaserjet p1006
Kindly insert the PROGRAM CD in the CD ROM drive and auto run the aplication CD without connecting the printer,in few minutes of installation progress you will get alert to connect the printer and then printer is configured by OS Above is the normal procedure,
very minute but technical tip is to
connect the printer first and insert program CD for printer in the ROM drive and open device manager and scan for hardware changes ,you will get alert on task bar that new hardware is found and new window for device installation ,click continue with browsing file path for CD in drive and continue installation ,in next few minutes your device shall be ready to use. In case there is problem with installation with CD kindly go to manufacturers website and download windows compatible drivers.
For Safe Computing Kindly keep your antivirus updated and firewall is on.
Thanks And Regards
Kindly rate this solution
Mar 03, 2010 | HP LASERJET P1006 Printer
Toshiba tecra m2v s330
Try borrowing a compatible HDD instead of buying a third one for testing and check if the same error exists. Try also using an external DVD drive to see if your internal CD-ROM is defective. Try also using another Windows XP CD installer. You can also use other OS installation CD to check it. Otherwise, there is something wrong with your lappy's motherboard due to tear and wear, heat, vibration, misuse and shock.
Mar 20, 2009 | Toshiba Tecra M2V-S330 Notebook
Brother DCP-130C printer
download the whole mfl-pro suite drivers at www.brother.com choose your country and your dcp. After downloading install. You cant run paperport due to the fact that it is part of the cd. But all needed drivers will be installed..
Apr 08, 2008 | Brother DCP 130C All-In-One InkJet Printer
Windows
hard drives dont read cd's
does the door close?
if not close it.
1)left clik my computer
2)double clik the cd rom drive, making sure theres a disk in it.
3)right clik on my computer
device manager
look for a yellow exclamation point or red X where the cd-rom is.
high light the cd-rom
right clik
uninstall
restart the computer
windows will detect and re-install the cd-rom drive.
try a cd
if that doesnt work update windows
also buy a cd-rom cleaner at your local electronics store
clean the drive w/th cleaner
try a cd
if updating your driver for the cd rom drive and all ive suggested then its time for a new cdrom drive
Dec 09, 2007 | Dell OptiPlex GX260 PC Desktop
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
185 people viewed this question
old marine
old marine
