posted by RAMOSL on Feb 09, 2008
Hi all,
I am trying to rescue an old Dell Dimension XPS 650r from what looks to be a virus. I was able to boot the machine with a startup disk but I am currently in the command line a:\. The drive C is not recognized and I wonder how can I configure some parameters at the autoexec.bat or config.sys to be able to access drive c:\ once the machine boots through drive a:
Help is appreciated. Tks!
Solution #1
posted on Feb 10, 2008
Hi there check that the drive is found in the bios setting press del. as the computer boots. this will take you to bios you need to check that the HDD is found there first if so then once at a:\ type c:\ then press enter this will access the c:
thanks j
thanks j
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Quantum Fireball 20.5 GB Hard Drive
Email this problem
Email this problem
Can you Help with these Hard Drives problems?
Repair Service
Find Hard Drive Repairman Near You:
